Problem bringing up custom board with custom board file
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect using the nRF9160DK_NRF9160 Non Secure board files. This is working both on the DK board and on my custom hardware board.
I have copied the nRF9160DK_NRF9160 board to my own board and renamed files and definitions to match my own board.
I can see that when using the DK board package I get a nrf9160dk_nrf9160_ns.conf file with some configuration that I do not find I my board files. I have copied these definitions into my prj.conf file.
When debugging my board using my custom board files (NS) I get this output on J-Link RTT:
00> *** Booting nRF Connect SDK v3.5.99-ncs1 ***
00> I: Starting bootloader
00> I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
00> I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
00> I: Boot source: none
00> I: Image index: 0, Swap type: none
00> I: Bootloader chainload address offset: 0x10000
00> I: Jumping to the first image slot
But when using the board definition for nRF9160DK_NRF9160 Non Secure I get this:
00> [00:00:16.895,935] <inf> azure_iot_hub_sample: Azure IoT Hub sample started
00> [00:00:16.895,965] <inf> azure_iot_hub_sample: Bringing network interface up and connecting to the network
00> [00:00:17.124,908] <inf> nrf_modem_lib_trace: Trace thread ready
.... connecting and running.
What am I missing for my own board definition. I am working in the same project file with just the above two build definitions...
  • Now I have tried adding
    chosen {
      ncs,at-host-uart = &uart2;
    And declared uart2 in the DTS, then I can compile. So that seems to remove last reference to uart0,
    So I found out that CONFIG_AT_HOST_LIBRARY removes this dependency.
    So I have removed the AT host library and is trying to reintroduce the use of uart0 in my application.
  • Try to  use the VS Code DeviceTree editor, find ncs,at-host-uart under  "chosen" and delete  it there. Then you can see how that looks in the overlay file
  • I am currently again at continues reboot:
    I am experimenting with uart settings but do not find any setting where I can use a serial port for rs485 modbus and optionally another one for console (not in current hardware, but pins are free).
    I have the following in the pinmux, and this is not changed during experimenting:
        uart_rs485_default: uart_rs485_default {
            group1 {
                psels = <NRF_PSEL(UART_TX, 0, 9)>;
            group2 {
                psels = <NRF_PSEL(UART_RX, 0, 10)>;
                bias-pull-up;
        uart_rs485_sleep: uart_rs485_sleep {
            group1 {
                psels = <NRF_PSEL(UART_TX, 0, 9)>,
                low-power-enable;
        uart_console_default: uart_console_default {
            group1 {
                psels = <NRF_PSEL(UART_TX, 0, 29)>;
            group2 {
                psels = <NRF_PSEL(UART_RX, 0, 28)>;
                bias-pull-up;
        uart_console_sleep: uart_console_sleep {
            group1 {
                psels = <NRF_PSEL(UART_TX, 0, 29)>,
                low-power-enable;
    Then experimeting with dtsi and config settings. Current test that causes continous reboot is caused by:
        chosen {
            zephyr,console = &uart0;
            zephyr,shell-uart = &uart0;
            zephyr,uart-mcumgr = &uart0;
            ncs,at-host-uart = &uart0;
    &uart2 {
        status = "okay";
        current-speed = <9600>;
        pinctrl-0 = <&uart_rs485_default>;
        pinctrl-1 = <&uart_rs485_sleep>;
        modbus0 {
            compatible = "zephyr,modbus-serial";
            status = "okay";
            de-gpios = < &gpio0 8 GPIO_ACTIVE_HIGH>;
    &uart0 {
        status = "okay";
        current-speed = <115200>;
        pinctrl-0 = <&uart_console_default>;
        pinctrl-1 = <&uart_console_sleep>;
    Some serial things from config:
    # Enable uart driver
    CONFIG_SERIAL=y
    # enable console
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_LOG=y
    CONFIG_LOG_MODE_DEFERRED=y
    CONFIG_LOG_DEFAULT_LEVEL=4
    # Modem
    CONFIG_NRF_MODEM_LIB_TRACE=n
    #CONFIG_AT_HOST_LIBRARY=y
    CONFIG_MODEM_KEY_MGMT=y
    # Modbus and serial
    CONFIG_UART_LINE_CTRL=n
    CONFIG_TFM_LOG_LEVEL_SILENCE=y
    CONFIG_MODBUS=y
    CONFIG_MODBUS_ROLE_CLIENT=y
    CONFIG_PINCTRL=y
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    And in my application I am opening modbus port with the following:
    #define MODBUS_NODE DT_COMPAT_GET_ANY_STATUS_OKAY(zephyr_modbus_serial)
    #define MODBUS_STACK_SIZE 1024
    #define MODBUS_PRIORITY 5
    K_THREAD_DEFINE(modbus_tid, MODBUS_STACK_SIZE,
                    ModbusClientThread, NULL, NULL, NULL,
                    MODBUS_PRIORITY, 0, 0);
    static int init_modbus_client(void)
        const char iface_name[] = {DEVICE_DT_NAME(MODBUS_NODE)};
        client_iface = modbus_iface_get_by_name(iface_name);
        return modbus_init_client(client_iface, client_param);
  • Are you able to build a project with this error for a Development Kit?
    If so, I could test it on my end.
  • azure_iot_hub_2.zippmi8004a1_nrf9160.zipYes - I does not compile directly to DK because the modbus is missing in the device tree for the DK. My my board definition can be loaded into the DK and seems to do same but of course modbus is not available but can be compiled in and activated.
    I will attach both my board and my project.
