Using nrf5340dk with the nrf21540 EK
Hey I have a question regarding the setup described in the title. I have an application built upon the "Throughput Sample" of Nordic Semiconductor. To get a farther Distance, the Receiver gets an nrf21540 EK, connected via the Arduino Headers and a SMA cable. Now I added the Shield via Extra C-Make option in The VS Code Extension:
-DSHIELD=nrf21540ek and
-Dhci_ipc_SHIELD=nrf21540ek
However, this is the only thing I did so far. The resources online are diverse and I don't know where to start. Can i just plug it in now and it automatically
works? Do i need to change something in my code for it to work?
I use the 2.6.0 SDK in Visual Studio Code
An answer would help a lot! Thanks!
  • Sorry, it still isn't quite clear to me how to calibrate it as it does not make sense to me how to apply it. I want to have the FEM provide a 13dbm output power for Bluetooth LE. Can I just set the CONFIG_BT_CTLR_TX_PWR_ANTENNA to 13, and the CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB to 20 as default? Will that ensure me the desired output? All these different Config variables seem conflicting to me, I apologise that i have to ask again.
    I don't need to change the output power dynamically, I only want to set it once statically.
    Regarding the antenna diversity: As i Understand, this is only for 802.15.4? This won't work for Bluetooth LE right?
    Thanks and again sorry for the many questions
  • I agree that it can be confusing what configuration settings to use with the FEM. I don't think you need to change the factory calibration, I just wanted to mention it is an option.
    Yes, the RADIO.TXPOWER register will then be set to -7 to acheive the desired output. Note that +10 dBm is the max. output power permitted for BLE in Europe.
    Correct. Antenna diversity isn't that useful for BLE due to channel hopping and short preamble. I haven't seen anyone using it with BLE.
