Memory allocation
Hi
I'm trying to figure out how to manage my memory on the nrf9160 sip. Currently my application crashes on a specific lines where I try to allocate a large C++ string (the crash happens at around a string size of 10 kB see call stack below).
I've tried playing around with the config file and use different sizes, but nothing seems to help.
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=32000
CONFIG_MAIN_STACK_SIZE=32000
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=32000
I can see when I'm building my application I get this memory report, which also indicates that I lots of unused memory:
I also found the thread analyzer function to print out the stack usage of all threads, which reports runtime that there is lots of memory left:
[00:04:20.621,856] <inf> thread_analyzer: Thread analyze:
[00:04:20.622,406] <inf> thread_analyzer:  0x20011310          : STACK: unused 496 usage 272 / 768 (35 %); CPU: 0 %
[00:04:20.623,046] <inf> thread_analyzer:       : Total CPU cycles used: 51217
[00:04:20.623,718] <inf> thread_analyzer:  0x200113b8          : STACK: unused 848 usage 176 / 1024 (17 %); CPU: 0 %
[00:04:20.624,389] <inf> thread_analyzer:       : Total CPU cycles used: 1
[00:04:20.628,845] <inf> thread_analyzer:  0x20011660          : STACK: unused 31368 usage 752 / 32120 (2 %); CPU: 0 %
[00:04:20.629,547] <inf> thread_analyzer:       : Total CPU cycles used: 1188
[00:04:20.630,126] <inf> thread_analyzer:  0x200114b0          : STACK: unused 236 usage 84 / 320 (26 %); CPU: 58 %
[00:04:20.630,767] <inf> thread_analyzer:       : Total CPU cycles used: 4950365
[00:04:20.634,155] <inf> thread_analyzer:  0x20011558          : STACK: unused 22480 usage 9640 / 32120 (30 %); CPU: 41 %
[00:04:20.634,857] <inf> thread_analyzer:       : Total CPU cycles used: 3513906
[00:04:20.635,559] <inf> thread_analyzer:  ISR0                : STACK: unused 1672 usage 376 / 2048 (18 %)
I do not use dynamic allocation (or atleast not that I'm aware of) so the heap should be unsed.
Is this a memory issue? And is there any way to get more information about my memory usage runtime?
  • That is an undefined symbol in my project. When was it added? I'm using nRF version 2.4.0 and toolchain 2.4.0
    https://github.com/nrfconnect/sdk-zephyr/blob/v2.4.0-ncs-branch/samples/cpp_synchronization/prj.conf
    It should be available for NCS 2.4.0. Are you able to build the linked sample?
  • Hello Hakon,
    Yes, I'm able to build the linked sample, but it's using the CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE symbol and not the CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE symbol. This also requires MINIMAL_LIBC_MALLOC and  MINIMAL_LIBC to be set
  • Anyway, the default value for this is -1, meaning the rest of the RAM is used as malloc() space. Meaning the best you can achieve is by keeping the default value and not changing anything. I tested this, and changing CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE does affect the amount of space that can be allocated for std::string.
  • Okay, so since i'm not setting the CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE it must be -1 and then I already have the maximum amount of space for std::string? Im just curious to why i'm only able to allocate ~5000 bytes when the nrf9160 have 256kb ram. I must allocate the ram to something else?
    This is my current prj.conf
    # Cpp
    CONFIG_CPP=y
    CONFIG_STD_CPP20=y
    CONFIG_MINIMAL_LIBCPP=n
    CONFIG_CPP_MAIN=y
    CONFIG_GLIBCXX_LIBCPP=y
    CONFIG_CPP_EXCEPTIONS=y
    # Peripherals
    CONFIG_I2C=y
    CONFIG_PWM=y
    # NEWLIB C
    CONFIG_NEWLIB_LIBC=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_NETWORK_MODE_LTE_M=y
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    # AT Host
    CONFIG_AT_HOST_LIBRARY=y
    # Azure IoT Hub library
    CONFIG_AZURE_IOT_HUB=y
    # Host name is set by DPS
    CONFIG_AZURE_IOT_HUB_HOSTNAME=""
    CONFIG_MQTT_HELPER_SEC_TAG=11
    CONFIG_MQTT_HELPER_SECONDARY_SEC_TAG=10
    # MQTT - Maximum MQTT keepalive timeout specified by Azure IoT Hub
    CONFIG_MQTT_KEEPALIVE=60
    # LED control
    CONFIG_DK_LIBRARY=y
    # Heap and stacks
    CONFIG_HEAP_MEM_POOL_SIZE=10000
    CONFIG_MAIN_STACK_SIZE=10000
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8000
    # Settings, needed for Azure Device Provisioning Service
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_FCB=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_FCB=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_AZURE_IOT_HUB_DPS=y
    # The ID scope can be omitted and provided at run time
    CONFIG_AZURE_IOT_HUB_DPS_ID_SCOPE="xxxxxxxxxx"
    CONFIG_HW_ID_LIBRARY=y
    CONFIG_HWINFO=y
    CONFIG_NEWLIB_LIBC_NANO=n
    CONFIG_REBOOT=y
    # Watchdog
    CONFIG_WATCHDOG=y
    CONFIG_WDT_DISABLE_AT_BOOT=n
    #FOTA
    CONFIG_AZURE_FOTA=y
    CONFIG_AZURE_FOTA_APP_VERSION_AUTO=y
    CONFIG_AZURE_FOTA_TLS=y
    CONFIG_AZURE_FOTA_SEC_TAG=11
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2300
    # DFU Target
    CONFIG_DFU_TARGET=y
    # Application update support
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Image manager
    CONFIG_IMG_MANAGER=y
    CONFIG_STREAM_FLASH=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    I also use these to define some memory regions in my code, but that's only like ~5 kB combined memory:
    K_MSGQ_DEFINE(uart_msgq, 255, 10, 4),
    K_THREAD_STACK_DEFINE(application_stack_area, KB(2));
    K_THREAD_STACK_DEFINE(threadStack, 512);
    I'm building it for the nrf9160dk_nrf9160_ns board.
    Can you see anything here that should reduce the available heap size for std::string?
