Dear Team,
I have DWM3001C module which has nRF52833 chip and multiple sensors (IMU,accelerometer ,magnetometer,etc). But currently with my code, I am not able to read the data (of lis2dh12 accelerometer). I think it might be because of wrong configuration values of scl,sda and sensor address. I am attaching my code. I am getting this error :
00> <error> app: ERROR 33281 [NRF_ERROR_DRV_TWI_ERR_ANACK] at D:\nRF5_SDK_17.1.0_ddde560\nRF5_SDK_17.1.0_ddde560\examples\Myprojects\twi_scanner\main.c:88
00>
00> PC at: 0x00000623
00>
00> <error> app: End of error report
Please let me know if anyone finds the issue in the code or provide the code which directly reads the data of lis2dh12 sensor.
Thank you
#include <stdbool.h> #include <stdint.h> #include "nrf_delay.h" #include "nrf_gpio.h" #include "boards.h" #include "app_util_platform.h" #include "app_error.h" #include "nrf_drv_twi.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #define TWI_INSTANCE_ID 0 #define LIS2DH12_ADDR 0x19 // I2C address of LIS2DH12 #define LIS2DH12_REG_WHO_AM_I 0x33 // Who Am I register #define LIS2DH12_REG_CTRL_REG1 0x20 // Control Register 1 #define LIS2DH12_REG_OUT_X_L 0x28 // Output X Low register #define LIS2DH12_REG_OUT_X_H 0x29 #include "lis2dh12.h" #include "lis2dh12_internal.h" static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID); // TWI instance // Function for TWI initialization void twi_init (void) { ret_code_t err_code; const nrf_drv_twi_config_t twi_config = { .scl = SCL_PIN, .sda = SDA_PIN, .frequency = NRF_DRV_TWI_FREQ_400K, .interrupt_priority = APP_IRQ_PRIORITY_HIGH, .clear_bus_init = false }; err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL); APP_ERROR_CHECK(err_code); nrf_drv_twi_enable(&m_twi); } static volatile bool m_xfer_done = false; void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context) { m_xfer_done = true; } // Function for reading data from LIS2DH12 accelerometer void lis2dh12_read_acceleration(int16_t *x, int16_t *y, int16_t *z) { ret_code_t err_code; uint8_t data[6]; // Set the address from which to read accelerometer data uint8_t reg_address = LIS2DH12_REG_OUT_X_L; // Send the register address over TWI to the accelerometer err_code = nrf_drv_twi_tx(&m_twi, LIS2DH12_ADDR, ®_address, 1, true); APP_ERROR_CHECK(err_code); // Receive accelerometer data over TWI err_code = nrf_drv_twi_rx(&m_twi, LIS2DH12_ADDR, data, sizeof(data)); APP_ERROR_CHECK(err_code); // Extract accelerometer data from received buffer *x = (int16_t)((data[1] << 8) | data[0]); *y = (int16_t)((data[3] << 8) | data[2]); *z = (int16_t)((data[5] << 8) | data[4]); } int main(void) { ret_code_t err_code; int16_t accel_x, accel_y, accel_z; // Initialize logging APP_ERROR_CHECK(NRF_LOG_INIT(NULL)); NRF_LOG_DEFAULT_BACKENDS_INIT(); // Initialize TWI (I2C) twi_init(); // Verify connection to LIS2DH12 uint8_t who_am_i; err_code = nrf_drv_twi_rx(&m_twi, LIS2DH12_ADDR, &who_am_i, 1); APP_ERROR_CHECK(err_code); nrf_delay_ms(2); if (who_am_i != 0x33) { printf("Failed to connect to LIS2DH12\r\n"); while (true); } // Configure accelerometer uint8_t ctrl_reg1_data = 0x57; // Normal mode, XYZ axes enabled, 50Hz data rate uint8_t reg_address = LIS2DH12_REG_CTRL_REG1; // Send control register address over TWI to the accelerometer err_code = nrf_drv_twi_tx(&m_twi, LIS2DH12_ADDR, ®_address, 1, true); APP_ERROR_CHECK(err_code); // Write control register data err_code = nrf_drv_twi_tx(&m_twi, LIS2DH12_ADDR, &ctrl_reg1_data, 1, false); APP_ERROR_CHECK(err_code); printf("LIS2DH12 Accelerometer Initialized!\r\n"); // Main loop while (true) { lis2dh12_read_acceleration(&accel_x, &accel_y, &accel_z); printf("Acceleration: X=%d, Y=%d, Z=%d\r\n", accel_x, accel_y, accel_z); nrf_delay_ms(1000); // Delay between readings } }
