Using high precision measurement in Nordic Distance Toolbox
Hey,
I watched webinar with presentation of NDT and a Lidar as a reference data and if looks quite impressive for high precision calc method.
We are using 7002 DK and we would like to really see how it works. Currently we did some testing for IFFT method from nrf-sdk samples, but as it was said in webinar these result are not trustworthy for wide measurement ranges.
However, i haven't seen example usage of nrf_dm_high_precision_calc() function in sdk, or github.
I know that there is a need of calling nrf_dm_populate_report but i still fail using this with sdk 2.5.0.
Could you maybe share a piece of code, where you present how to properly use these tools for high precision distance measurement?
It could be for other target or SDK version, i just need a start point.It could be the code, that you use for webinar measurement with roll camera :)
We are eager to test it and try to auto-map 5x5 nrf device matrix in large space with coodrdinates, but for this purpose we need as precise result as possible.
Of course, we could share our results of this experiments.
Thanks!
  • Dymek117 said:
    Actually I am, but should I define in code Reflector and Initiator roles for each devices?
    They have different roles, but I think what role is selected automatically. Just flash the same code to both.
  • Hey, I did some measurements today. I used nrf7002 and nrf52840 devkits in different combinations. Unfortunatelly results are pretty much the same not matter the hardware. I used same sample code build on linux with sdk 2.5.0. Here are the observations:
    Up to 2m distance high precision seems to work fine (only sometimes NaN happens).
    Increasing distance, increases also NaN ratio very fast. With 4m its almost 100%. I got only few right measurements during the test.
    As you can see below, IFTT and phase slope are quite ok. Especially the ifft seems to give very probable results.
    RSSI_Openspace is completely off earth. It gives few hundreds meters when im 10m away from second device. But maybe this is expected as this is rssi measurement, im not sure :)
    Measurement result:
    Addr: D1:3F:48:6B:7E:92 (random)
    Quality: ok
    Distance estimates: mcpd: high_precision=nan ifft=7.91 phase_slope=8.77 rssi_openspace=19.95 best=7.91
    Test was performed in open space, outside the building to minimize interferations.
    Do you have any insights? Are you sure that i should set anything in sample code? This one wasn't modified, just build from sdk directory.
    Thanks!
  • Confirmed also on 2.4.0 and 2.6.1 sdk fresh install on windows.
    For sure hardware and sdk installation are not a case here.
    This does sound worse than what I've gotten on my side, though to be fair I haven't tried anything longer than 4m. Though I've never seen a single Nan myself.
    According to the R&D team responsible for the distance toolbox, it has been tested to about 18 meters, though at 18 meters we have seen that fewer rangings are successful compared to close range. We have also seen that the high precision algorithm is less robust than other algorithms when some of the IQ measurements are missing or corrupted. If you want to get more results from the high accuracy algorithm you could try overwriting the sinr indicators with NRF_DM_SINR_INDICATOR_HIGH in the  nrf_dm_report_t before you run nrf_dm_high_precision_calc. Though I wouldn't say that this solution is recommended. Its returning Nan because multiple tones are of a quality worse than medium, so it wouldn't really be a high precision result.
    I would rather recommend this fallback approach: if the high precision does not give a valid result you can still call the regular calculate.
    Having a look at the levels of these tone_sinr_indicators to figure out what the quality of the measurements are might either way be interesting to you.
    Maybe that is a bit much.., but RSSI is expected to perform awfully, especially so over longer distances. Have a look at this webinar in case you haven't yet. Though I guess it can be somewhat useful at very short distances. I've gotten the impression that if you want to get something that performs well you'd not just try to add a Kalman filter on top of these, but for instance use the different ways of measuring the distance in the situations in which they are trustworthy. Eg. not trusting RSSI over distances larger than a meter or two, or using the phase slope as a maximum.
    Maybe you'll be able to create an algorithm based on the regular results that you prefer. And there is also always the option of creating everything regarding the algorithm on your own using the IQ samples.
    Elfving
  • Hey Elfving,
    As we need to have NRF DM Toolbox measured i am going to perform detailed testing anyway. What I'm gonna do is exactly what you described - use high precision if available and IFFT in other case.
    I'm going to do some openspace test and some other with walls in between. Hopefully it will be good enough.
    But anyway i'm wondering why my measurements are so bad quality, which is the reason of these NaNs. Is it regular situations on devkits? I tried to move away from any other signal sources. Maybe there is something wrong in my setup, shouldn't I use some external antenna, etc?
    It really does not look good - high precision works only on desk setup, moving anywhere blocks any results.
