asset_tracker_v2 booting with V2.5.0
I have a nRF9160DK board running asset_tracker_v2 on a nRF9160 custom board. V1.7.0 loads and boots fine but when I use V2.5.0 the boot fails as shown below. The only change I have made to the V2.5.0 asset_tracker_v2 code was to change the 2 lines in prj.conf that had my AWS information. This code loads fine in a nrf9160DK board but fails when I use the V2.5.0 version in the custom board. The V1.7.0 version loads in the custom board and had been running for several years. any ideas what I am doing wrong? any way to get more information on why the boot is failing? any help would be greatly appreciated. We have V1.7.0 out in the filed in many sites for years and it is working perfectly. The decision was made to upgrade to V2.5.0 so I am stuck until I can get this to boot correctly.
I noticed there are 2 new lines in the V2.5.0 code that are not in the V1.7.0 code. since these related to boot I commented them out. below are the 2 extra lines in V2.5.0 and the error message.
CONFIG_SECURE_BOOT=y
CONFIG_BUILD_S1_VARIANT=y
when I tried to build with these commented out I got the following error message.
C:/Nordic1/v2.5.0/nrf/modules/tfm/tfm/boards/common/assert.c:16:9: note: '#pragma message:
!!!Partition alignment error!!!
The non-secure start address in pm_static.yml or generated partition.yml is: 0x1be00
which is not aligned with the SPU region size.
Refer to the documentation section 'TF-M partition alignment requirements'
for more information.
16 | #pragma message "\n\n!!!Partition alignment error!!!"\
C:/Nordic1/v2.5.0/nrf/modules/tfm/tfm/boards/common/assert.c:22:2: error: #error "TF-M non-secure start address is not aligned on SPU region size"
22 | #error "TF-M non-secure start address is not aligned on SPU region size"
*** Booting nRF Connect SDK v2.5.0 ***
Attempting to boot slot 0.
Attempting to boot from address 0x8200.
Verifying signature against key 0.
Hash: 0xc0...9e
Firmware signature verified.
Firmware version 1
Booting (0x8200).
  • If you use a programmer to flash the new version, including the bootloader, the problem is not the flash partitions.
    Here's the documentation for how to get a static partitioning configuration, as that that is something you will need when you start looking at how to upgrade your deployed devices: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/scripts/partition_manager/partition_manager.html#static_configuration
    Do you have custom board files for your board, or are you building for the DK when building for your custom board?
    In NCS v2.5.0, the default version of the DK was changed from 0.7.0 to 0.14.0. The main difference is that the 0.14.0 revisions and newer have an external flash. If your custom board does not have that external flash, that might be the problem.
    The solution in this case would be to either create a custom board definition for your board, or to build for the 0.7.0 revision of the DK.
  • Didrik
    I have some additional information with our custom board. A colleague found if I use the following command to build it will build and boot every time after a flash and with a software reset.
     west build -b nrf9160dk_nrf9160_ns@0.7.0 -- pristine -DDTC_OVERLAY_FILE=boards/nrf9160dk_nrf9160_ns.overlay
    This has the following memory layout
    Memory region Used Size Region Size %age Used
    FLASH: 272408 B 384 KB 69.28%
    RAM: 164940 B 211608 B 77.95%
    IDT_LIST: 0 GB 2 KB 0.00%
    if I use the default 0.14.0 below to build
    west build -b nrf9160dk_nrf9160_ns -- pristine -DDTC_OVERLAY_FILE=boards/nrf9160dk_nrf9160_ns.overlay
    this has the following memory layout and will not boot after a flash or with software reset. I must power cycle in order to get it to boot. Both binaries do run once started.
    FLASH: 275576 B 736 KB 36.56%
    RAM: 165228 B 211608 B 78.08%
    I have attached my overlay file and my prj.conf file. I am not an expert in setting of the configuration so maybe I messed something up. Can you look at my files and let me know if I have made some mistakes. I have 2 questions.
    1. why should one version (0.7.0) boot and not the other (0.14.0).
    2. why is there a memory difference in the versions. The nRF9160 has 1 MB of flash correct? why is there such a difference.
    summary: if I use 0.7.0 I can get it to boot and run automatically but I have a lot less memory to work with. I am adding code and sensor drivers daily. I may need all of the memory possible.
    0160.nrf9160dk_nrf9160_ns.overlay2146.prj.conf
    The difference between the 0.7.0 revision and the 0.14.0 revision is that the 0.14.0 revision has an external flash.
    The asset_tracker_v2 will use the external flash for MCUBoot's secondary slot. This frees up space on the internal flash, which can then be allocated to the primary slot.
    I don't know why it doesn't boot though.
  • Didrik
    so should I continue to use the 0.7.0 or is there a way to disable the external flash. my custom board does NOT have the external flash it is expecting on the nRF9160DK board.
    also why the difference in Flash usage. How do I get the extra memory back.
    The flash usage is almost the same in both cases, but a bit higher when you build for 0.14.0.
    The reason for why you have more flash "available" is that you use the external flash for the secondary slot for MCUBoot.
    So instead of the flash layout beeing something like
    <| MCUBoot | MCUBoot primary | MCUBoot secondary |> (TF-M and the application must share the MCUBoot primary partition)
    You get something like
    <| MCUBoot | MCUBoot primary                                         |> and on the external flash <| MCBoot secondary |>
    You can disable the extra config options and device tree node that the 0.14.0 adds. However, this doesn't really have any benefits over using 0.7.0 other than not having to specify the board revision.
