SPI communication with Lis3dh sensor (nrfConnect SDK)
I'm encountering an issue while configuring the SPI bus to communicate with a LIS3DH sensor using nrf52832. I'm working with Visual Studio Code using nrfConnect SDK (Zephyr).
Here's the Device Tree Source (DTS):
// Copyright (c) 2024 Nordic Semiconductor ASA
// SPDX-License-Identifier: Apache-2.0
/dts-v1/;
#include <nordic/nrf52832_qfaa.dtsi>
    model = "xxx";
    compatible = "xxx";
    aliases {
        led0 = &led0;
        led1 = &led1;
        led2 = &led2;
    chosen {
        zephyr,sram = &sram0;
        zephyr,flash = &flash0;
        zephyr,code-partition = &slot0_partition;
    leds{
        compatible = "gpio-leds";
        led0: led_0{
            gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
            label = "Blue LED 0";
        led1: led_1{
            gpios = <&gpio0 9 GPIO_ACTIVE_LOW>;
            label = "Green LED 1";
        led2: led_2{
            gpios = <&gpio0 8 GPIO_ACTIVE_LOW>;
            label = "Red LED 2";
&flash0 {
    partitions {
        #address-cells = <1>;
        #size-cells = <1>;
        boot_partition: partition@0 {
            label = "mcuboot";
            reg = <0x0 0xc000>;
        slot0_partition: partition@c000 {
            label = "image-0";
            reg = <0xc000 0x32000>;
        slot1_partition: partition@3e000 {
            label = "image-1";
            reg = <0x3e000 0x32000>;
        scratch_partition: partition@70000 {
            label = "image-scratch";
            reg = <0x70000 0xa000>;
        storage_partition: partition@7a000 {
            label = "storage";
            reg = <0x7a000 0x6000>;
&gpio0 {
    status = "okay";
&gpiote {
    status = "okay";
lis3dh_spi_master: &spi0 {
    compatible = "nordic,nrf-spi";
    status = "okay";
    pinctrl-0 = <&spi0_default>;
    pinctrl-1 = <&spi0_sleep>;
    pinctrl-names = "default","sleep";
    cs-gpios = <&gpio0 18 GPIO_ACTIVE_LOW>;
    reg_lis3dh: lis3dh@0{
        compatible = "st,lis2dh";
        reg = <0>;
        irq-gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>, <&gpio0 17 GPIO_ACTIVE_HIGH>;
        spi-max-frequency = <8000000>;
&pinctrl {
    spi0_default: spi0_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 15)>,
                    <NRF_PSEL(SPIM_MOSI, 0, 20)>,
                    <NRF_PSEL(SPIM_MISO, 0, 19)>;
    spi0_sleep: spi0_sleep {
        group1 {
            low-power-enable;
The spi_file is :
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/spi.h>
#define LIS3DH_OUT_X_L                  0x28
#define LIS3DH_OUT_X_H                  0x29
#define LIS3DH_SPI_MASTER DT_NODELABEL(lis3dh_spi_master)
// SPI master functionality
const struct device *spi_dev;
struct spi_cs_control spim_cs = {
    .gpio = SPI_CS_GPIOS_DT_SPEC_GET(DT_NODELABEL(reg_lis3dh)),
    .delay = 0,
static const struct spi_config spi_cfg = {
    .operation = SPI_OP_MODE_MASTER | SPI_WORD_SET(8) | SPI_TRANSFER_MSB,
    .frequency = 8000000,
    .slave = 0,
    .cs = &spim_cs,
void spi_init(void)
    spi_dev = DEVICE_DT_GET(LIS3DH_SPI_MASTER);
    if(!device_is_ready(spi_dev)) {
        printk("SPI master device not ready!\n");
    if(!device_is_ready(spim_cs.gpio.port)){
        printk("SPI master chip select device not ready!\n");
uint8_t test_spi(void)
    int err;
    static uint8_t tx_buf[1];
    static uint8_t rx_buf[1];
    const struct spi_buf_set tx = {
        .buffers = &tx_buf,
        .count = 1
    const struct spi_buf_set rx = {
        .buffers = &rx_buf,
        .count = 1
    tx_buf[0] = LIS3DH_OUT_X_L;
    err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
    if (err < 0) {
        printk("spi_transceive_dt() failed, err: %d", err);
        return err;
    printk("\nTx data : %d, Tx data : %d",tx_buf[0], rx_buf[0]);
And the main calls spi_init() and test_spi().
I'm encountering this error during spi_transceive() function :
Bluetooth initialized
Advertising successfully started
BEACON START
[00:00:01.005,676] <err> os: ***** Reserved Exception ( -16) *****
[00:00:01.005,706] <err> os: r0/a1: 0x20006f00 r1/a2: 0x00016a0d r2/a3: 0x0002e2bf
[00:00:01.005,706] <err> os: r3/a4: 0x000169f9 r12/ip: 0x000169f9 r14/lr: 0x000169f9
[00:00:01.005,737] <err> os: xpsr: 0x00000000
[00:00:01.005,737] <err> os: s[ 0]: 0x00000000 s[ 1]: 0x00000000 s[ 2]: 0x00000000 s[ 3]: 0x00016c09
[00:00:01.005,767] <err> os: s[ 4]: 0x000169f9 s[ 5]: 0x00000000 s[ 6]: 0x00016b69 s[ 7]: 0x000169f9
[00:00:01.005,767] <err> os: s[ 8]: 0x00016f15 s[ 9]: 0x00031ed3 s[10]: 0x00016f15 s[11]: 0x00016f15
[00:00:01.005,798] <err> os: s[12]: 0x00016f15 s[13]: 0x00016f15 s[14]: 0x00016f15 s[15]: 0x00016f15
[00:00:01.005,798] <err> os: fpscr: 0x00031e89
[00:00:01.005,798] <err> os: Faulting instruction address (r15/pc): 0x000169f9
[00:00:01.005,859] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
[00:00:01.005,889] <err> os: Current thread: 0x20003030 (unknown)
[00:00:01.391,052] <err> fatal_error: Resetting system
Thank for you help
  • Hi Helsing,
    I'am using nRF Connect SDK v2.6.0. Here the prf.config :
    # SPI
    CONFIG_SPI=y
    CONFIG_SPI_NRFX=y
    CONFIG_NRFX_SPI0=y
    CONFIG_SPI_ASYNC=y
    CONFIG_CONSOLE=y
    I have checked the MOSI, MISO, and SCK lines with an oscilloscope and compared them with the previous code under FreeRTOS I don't see any differences, the data is good but I don't have acces on the CS line, so I believe the issue is coming from the CS (Chip Select) line, as indicated by the error message.
    *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    SPI TX: 0x8f
    SPI RX: 0xff
    I'm spi_init() and after spi_write_test_msg() on the main function.
    Here is my updated code:
     * Copyright (c) 2016 Intel Corporation
    /* 1000 msec = 1 sec */
    #define SLEEP_TIME_MS   1000
    #define MY_SPI_MASTER DT_NODELABEL(lis3dh_spi_master)
    #define MY_SPI_MASTER_CS_DT_SPEC SPI_CS_GPIOS_DT_SPEC_GET(DT_NODELABEL(reg_lis3dh_master))
    #define SPI_BUFSIZE  8   //SPI Communication buffer size
    uint8_t   spi_tx_buf[SPI_BUFSIZE]; // spitx buffer
    uint8_t   spi_rx_buf[SPI_BUFSIZE]; // spirx buffer
    #define ADD_REG_WHO_AM_I                0x0F
    #define UC_WHO_AM_I_DEFAULT_VALUE       0x3F
    /* set read single command. Attention: command must be 0x3F at most */
    #define SET_READ_SINGLE_CMD(x)         (x |0x80)
    static struct k_poll_signal spi_done_sig = K_POLL_SIGNAL_INITIALIZER(spi_done_sig);
    void printbuffers()
        printk("SPI TX: ");
        for (int j = 0; j<sizeof(spi_tx_buf); j++)
            printk(" %x",spi_tx_buf[j]);
        printk("\r\nSPI RX: ");
        for (int j = 0; j<sizeof(spi_rx_buf); j++)
            printk(" %x",spi_rx_buf[j]);
        printk("\r\n");
    void spi_init(void)
        spi_dev = DEVICE_DT_GET(MY_SPI_MASTER);
        struct gpio_dt_spec spim_cs_gpio = MY_SPI_MASTER_CS_DT_SPEC;
        if(!device_is_ready(spim_cs_gpio.port)){
    static struct spi_config spi_cfg = {
        .operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_MODE_CPOL | SPI_MODE_CPHA,
        .slave = 0,
        .cs = {.gpio = MY_SPI_MASTER_CS_DT_SPEC, .delay = 2},
    int spi_write_test_msg(void)
        const struct spi_buf tx_buf = {
            .buf = spi_tx_buf,
            .len = sizeof(spi_tx_buf)
            .buffers = &tx_buf,
            .count = 1
        struct spi_buf rx_buf = {
            .buf = spi_rx_buf,
            .len = sizeof(spi_rx_buf),
            .buffers = &rx_buf,
            .count = 1
        // Update the TX buffer with a rolling counter
        spi_tx_buf[0] = SET_READ_SINGLE_CMD(ADD_REG_WHO_AM_I);
        printk("SPI TX: 0x%.2x\n", spi_tx_buf[0]);
        // Reset signal
        k_poll_signal_reset(&spi_done_sig);
        // Start transaction
        int error = spi_transceive_signal(spi_dev, &spi_cfg, &tx, &rx, &spi_done_sig);
        if(error != 0){
            printk("SPI transceive error: %i\n", error);
            return error;
        // Wait for the done signal to be raised and log the rx buffer
        int spi_signaled, spi_result;
        do{
            k_poll_signal_check(&spi_done_sig, &spi_signaled, &spi_result);
        } while(spi_signaled == 0);
        printk("SPI RX: 0x%.2x\n", spi_rx_buf[1]);
        if (spi_rx_buf[1] == UC_WHO_AM_I_DEFAULT_VALUE)
            printk("LIS3DSH detected rn");
        return 0;
    Again the DTS file :
    /dts-v1/;
    	model = "x";
    	compatible = "x,x";
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    	chosen {
    	leds{
    		led0: led_0{
    		led1: led_1{
    		led2: led_2{
    	reserved-memory {
    		#size-cells = <1>;
    		ranges;
    		memory: memory@20000000 {
    			reg = <0x20000000 0x10000>;
    &flash0 {
    	partitions {
    		#size-cells = <1>;
    			label = "mcuboot";
    			reg = <0x0 0xc000>;
    			label = "image-0";
    			label = "image-1";
    			label = "storage";
    &gpio0 {
    	status = "okay";
    &gpiote {
        status = "okay";
        status = "okay";
            reg = <0>;
    &pinctrl {
            group1 {
    		group1 {
    			low-power-enable;
    &temp {
    	status = "disabled";
    Do you have some ideas ?
    It's was a DTS file issue.
    Here the good one :
    /dts-v1/;
    	model = "x_x";
    	compatible = "x,x";
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    	chosen {
    	leds{
    		led0: led_0{
    		led1: led_1{
    		led2: led_2{
    &flash0 {
    	partitions {
    		#size-cells = <1>;
    			label = "mcuboot";
    			reg = <0x0 0xc000>;
    			label = "image-0";
    			label = "image-1";
    			label = "storage";
    &gpio0 {
    	status = "okay";
    &gpiote {
        status = "okay";
    &pinctrl {
    	spi_master_default: spi_master_default {
    		group1 {
    	spi_master_sleep: spi_master_sleep {
    		group1 {
    			low-power-enable;
    lis3dh_spi_master: &spi1 {
        status = "okay";
    	pinctrl-0 = <&spi_master_default>;
    	pinctrl-1 = <&spi_master_sleep>;
        reg_lis3dh_master: lis3dh@0{
            reg = <0>;
  • Hi Guillaume,
    Great to hear that it is now working. Thank you for posting the solution.
    Håkon
  • Hi Guillaume,
    Thanks for posting the solution.
    I am quite confused, I noticed only one major change, changed SPI0 to SPI1 are there any issues in that?
    Thanks
    S.M
  • Hi S.M,
    Certain peripherals share resources and cannot be used simultaneously. For example, the SPI0 and I2C0 peripherals share the same resource, meaning that if I2C0 is enabled, SPI0 cannot be used at the same time, and vice versa. This is why, if I2C0 is being used, you would need to use SPI1 instead of SPI0.
    If Guillaume is building for nrf52dk_nrf52832 then i2c0 is enabled by default.
    If you have an issue that you would like to discuss further, please create a new ticket, and we will be happy to assist you.
