BLE disconnects when LTE publish data in Fanstel module PKBLG840F
I am developing an application where the nrf52840dk acts as peripheral device and sends data to nrf52840 of fanstel module. The fanstel nrf52840 acts as an central device. The data is relayed via UART to fanstel nrf9160.
A note: I am using fanstel module BLG840F which has nRF52840 and nRF9160.
I have used BLE central and peripheral example from nRF52840 sdk with no modification in the central and slight modification for constantly sending data in peripheral.
For nrf9160, I have used mqtt example from nRF sdk connect with slight modification where in I added workqueue for UART. The workqueue then post the received data via mqtt.
Currently what is happening is when the Fanstel's nRF9160 is publishing the data, the BLE connection is lost between nrf52840dk and Fanstel nrf52840. After the data is published it tries to connect again. This keeps on happening whenever Fanstel's nRF9160 publishes data via mqtt.
I am not sure what is happening and would greatly appreciate help.
The codes:
 * Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                        /**< BLE GATT Queue instance. */
               NRF_SDH_BLE_CENTRAL_LINK_COUNT,
               NRF_BLE_GQ_QUEUE_SIZE);
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief NUS UUID. */
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Nordic UART Service Client errors.
static void nus_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    ret = nrf_ble_scan_start(&m_scan);
    APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
    switch(p_scan_evt->scan_evt_id)
         case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
              err_code = p_scan_evt->params.connecting_err.err_code;
         } break;
         case NRF_BLE_SCAN_EVT_CONNECTED:
              ble_gap_evt_connected_t const * p_connected =
                               p_scan_evt->params.connected.p_connected;
             // Scan is automatically stopped by the connection.
             NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                      p_connected->peer_addr.addr[0],
                      p_connected->peer_addr.addr[1],
                      p_connected->peer_addr.addr[2],
                      p_connected->peer_addr.addr[3],
                      p_connected->peer_addr.addr[4],
                      p_connected->peer_addr.addr[5]
         } break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
             NRF_LOG_INFO("Scan timed out.");
             scan_start();
         } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
        // Send data back to the peripheral.
        do
            ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= (m_ble_nus_max_data_len)))
                do
                    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            printf("Discovery complete at the central side\n]r");
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
           printf("In central: Connected to the peripheral\n\r");
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
           printf("In central: Disconnected from the periperhal\n\r");
            NRF_LOG_INFO("Disconnected.");
            scan_start();
 * @brief Function for handling shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
            printf("In Central: Disconnected from the device\n\r");
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in] event  Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler   = ble_nus_c_evt_handler;
    init.error_handler = nus_error_handler;
    init.p_gatt_queue  = &m_ble_gatt_queue;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
    ble_db_discovery_init_t db_init;
    memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
    db_init.evt_handler  = db_disc_handler;
    db_init.p_gatt_queue = &m_ble_gatt_queue;
    ret_code_t err_code = ble_db_discovery_init(&db_init);
 * @details Handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    buttons_leds_init();
    db_discovery_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    nus_c_init();
    scan_init();
    // Start execution.
    printf("BLE UART central example started.\r\n");
    NRF_LOG_INFO("BLE UART central example started.");
    scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
// #include <stdio.h>
// #include <string.h>
// #include <zephyr/kernel.h>
// #include <zephyr/net/socket.h>
// #include <zephyr/logging/log.h>
// #include <dk_buttons_and_leds.h>
// #include <modem/nrf_modem_lib.h>
// #include <modem/lte_lc.h>
// #include <zephyr/net/mqtt.h>
// #include "mqtt_connection.h"
// #include <zephyr/device.h>
// #include <zephyr/devicetree.h>
// #include <zephyr/drivers/gpio.h>
// #include <zephyr/sys/printk.h>
// #include <zephyr/drivers/uart.h>
// // UART2
// #define SLEEP_TIME_MS   1000
// #define RECEIVE_BUFF_SIZE 70
// #define RECEIVE_TIMEOUT 1000  // usec  around 10 usec for each bit that is transmitted
// const struct device *uart= DEVICE_DT_GET(DT_NODELABEL(uart2));
// static uint8_t rx_buf[RECEIVE_BUFF_SIZE] = {0};
// static uint8_t temp[RECEIVE_BUFF_SIZE] = {0};
// static struct mqtt_client client;
// static struct pollfd fds;
// static K_SEM_DEFINE(lte_connected, 0, 1);
// LOG_MODULE_REGISTER(LTE, LOG_LEVEL_DBG);
// // flag to indicate the transmission of data
// bool flag1 = 0;
// static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
// 	switch (evt->type) {
// 	case UART_RX_RDY:
// 		flag1 = 1;
// 		printk("D_len: %d\n\r",evt->data.rx.len); 										// for debugging
// 		memcpy(temp, &evt->data.rx.buf[evt->data.rx.offset], 70);
// 	break;
// 	case UART_RX_DISABLED:
// 		uart_rx_enable(dev ,rx_buf,sizeof rx_buf,RECEIVE_TIMEOUT);
// 		break;
// 	default:
// 		break;
// static void lte_handler(const struct lte_lc_evt *const evt)
//      case LTE_LC_EVT_NW_REG_STATUS:
//         if ((evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_HOME) &&
//             (evt->nw_reg_status != LTE_LC_NW_REG_REGISTERED_ROAMING)) {
//             break;
// 		LOG_INF("Network registration status: %s",
// 				evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ?
// 				"Connected - home network" : "Connected - roaming");
// 		k_sem_give(&lte_connected);
//         break;
// 	case LTE_LC_EVT_RRC_UPDATE:
// 		LOG_INF("RRC mode: %s", evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED ?
// 				"Connected" : "Idle");
// 		break;
//      default:
//              break;
// static int modem_configure(void)
// 	int err;
// 	LOG_INF("Initializing modem library");
// 	err = nrf_modem_lib_init();
// 	if (err) {
// 		LOG_ERR("Failed to initialize the modem library, error: %d", err);
// 		return err;
// 	LOG_INF("Connecting to LTE network");
// 	err = lte_lc_init_and_connect_async(lte_handler);
// 	if (err) {
// 		LOG_INF("Modem could not be configured, error: %d", err);
// 		return err;
// 	k_sem_take(&lte_connected, K_FOREVER);
// 	LOG_INF("Connected to LTE network");
// 	dk_set_led_on(DK_LED2);
// 	return 0;
// int main(void)
// 	int ret;
// 	int err;
// 	uint32_t connect_attempt = 0;
// 	if (!device_is_ready(uart)){
// 		printk("UART device not ready\r\n");
// 		return 1 ;
// 	if (dk_leds_init() != 0) {
// 		LOG_ERR("Failed to initialize the LED library");
// 	err = modem_configure();
// 	if (err) {
// 		LOG_ERR("Failed to configure the modem");
// 		return 0;
// 	err = client_init(&client);
// 	if (err) {
// 		LOG_ERR("Failed to initialize MQTT client: %d", err);
// 		return 0;
// do_connect:
// 	if (connect_attempt++ > 0) {
// 		LOG_INF("Reconnecting in %d seconds...",
// 			CONFIG_MQTT_RECONNECT_DELAY_S);
// 		k_sleep(K_SECONDS(CONFIG_MQTT_RECONNECT_DELAY_S));
// 	LOG_INF("Connection to broker using mqtt_connect");
// 	err = mqtt_connect(&client);
// 	if (err) {
// 		LOG_ERR("Error in mqtt_connect: %d", err);
// 		goto do_connect;
// 	ret = uart_callback_set(uart, uart_cb, NULL);
// 	if (ret) {
// 		return 1;
// 	ret = uart_rx_enable(uart ,rx_buf,sizeof rx_buf,RECEIVE_TIMEOUT);
// 	if (ret) {
// 		return 1;
// 	err = fds_init(&client,&fds);
// 	if (err) {
// 		LOG_ERR("Error in fds_init: %d", err);
// 		return 0;
// 	while (1) {
// 		printk("testing in while\n\r");
// 		if (flag1)
// 			data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE, temp, sizeof(temp)-1);
// 			flag1 = 0;
// 			// printk("data_sent?\n\r");
// 			printk("Data: %s\n\r",temp);
// 			for(size_t i = 0; i<RECEIVE_BUFF_SIZE; i++)
// 				temp[i] = 0;
// 		err = poll(&fds, 1, mqtt_keepalive_time_left(&client));
// 		if (err < 0) {
// 			LOG_ERR("Error in poll(): %d", errno);
// 			break;
// 		err = mqtt_live(&client);
// 		if ((err != 0) && (err != -EAGAIN)) {
// 			LOG_ERR("Error in mqtt_live: %d", err);
// 			break;
// 		if ((fds.revents & POLLIN) == POLLIN) {
// 			err = mqtt_input(&client);
// 			if (err != 0) {
// 				LOG_ERR("Error in mqtt_input: %d", err);
// 				break;
// 		if ((fds.revents & POLLERR) == POLLERR) {
// 			LOG_ERR("POLLERR");
// 			break;
// 		if ((fds.revents & POLLNVAL) == POLLNVAL) {
// 			LOG_ERR("POLLNVAL");
// 			break;
// 	LOG_INF("Disconnecting MQTT client");
// 	err = mqtt_disconnect(&client);
// 	if (err) {
// 		LOG_ERR("Could not disconnect MQTT client: %d", err);
// 	goto do_connect;
// 	/* This is never reached */
// 	return 0;
//----with workqueue-----------
#include <stdio.h>
#include <string.h>
// UART2
// change it to uart0 in case of Fanstel module
const struct device *uart= DEVICE_DT_GET(DT_NODELABEL(uart0));
#define SERIAL_Q_SIZE 5
static struct work_data{
    struct k_work work;
    char data[70];
    char data_len;						// should not be char for 1k data ?
}w_data[SERIAL_Q_SIZE];
	static int serial_in_count;
	case UART_RX_RDY:
		//printk("Checking UART triggering\n\r");
		memcpy(&w_data[serial_in_count].data, &evt->data.rx.buf[evt->data.rx.offset], 70);
		k_work_submit(&w_data[serial_in_count].work);
		if (serial_in_count < SERIAL_Q_SIZE-1) {
			serial_in_count++;
		else{
            serial_in_count=0;
	int err;
	if (err) {
		return err;
	if (err) {
		return err;
	return 0;
void pub_uart_mqtt(struct k_work *item)
    struct work_data *wrk_data = CONTAINER_OF(item, struct work_data, work);
    //printk("Data: %s\n", wrk_data->data);
    printk("Length of data:%d\n",wrk_data->data_len);
    data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE, wrk_data->data, 70);
	int ret;
	int err;
		return 1 ;
	if (err) {
		return 0;
	if (err) {
		return 0;
do_connect:
	if (err) {
		goto do_connect;
	for(int i=0; i < SERIAL_Q_SIZE; i++){
		k_work_init(&w_data[i].work, pub_uart_mqtt);
	if (ret) {
		return 1;
	if (ret) {
		return 1;
	if (err) {
		return 0;
	while (1) {
		if (err < 0) {
			if (err != 0) {
			LOG_ERR("POLLERR");
	if (err) {
	goto do_connect;
	return 0;
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_ble_qwr.h"
#include "ble_nus.h"
#include "nrf_delay.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "NORDIC_UART_TEST"                               /**< Name of device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define TIMER_INTERVAL                  APP_TIMER_TICKS(5000) // 5 seconds
APP_TIMER_DEF(m_data_send_timer);
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
//static void timers_init(void)
//    ret_code_t err_code = app_timer_init();
//    APP_ERROR_CHECK(err_code);
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
            NRF_LOG_INFO("Connected");
           printf("Connected to the central\n\r");
          printf("Peripheral: Disconnected from the central\n\r");
            NRF_LOG_INFO("Disconnected");
        } break;
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    uint32_t err_code;
    switch (event)
            sleep_mode_enter();
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
            index++;
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
        nrf_pwr_mgmt_run();
//-------------------- user code
//static void data_send_timeout_handler(void * p_context)
//    // Function to be called when the timer expires
//    uint8_t data_to_send[] = "Sphinx of black quartz, judge my vow. Pack my box with five dozen liquor jugs. The quick brown fox jumps over the lazy dog. How razorback-jumping frogs can level six piqued gymnasts! Mr. Jock, TV quiz PhD, bags few lynx. Waltz, testing UART services test"; // Example data
//    uint16_t length = sizeof(data_to_send);
//    ret_code_t err_code = ble_nus_data_send(&m_nus, (uint8_t*) data_to_send, &length, m_conn_handle);
//    if ((err_code != NRF_ERROR_INVALID_STATE) &&
//        (err_code != NRF_ERROR_RESOURCES) &&
//        (err_code != NRF_ERROR_NOT_FOUND))
//        printf("ERROR in BLE transmission\n\r");
//    printf("send sucessful\r\n");
    //// Initialize timer for sending data periodically
    //err_code = app_timer_create(&m_data_send_timer, APP_TIMER_MODE_REPEATED, data_send_timeout_handler);
    //APP_ERROR_CHECK(err_code);
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    //nrf_delay_ms(20000);
    /* uncomment this section
    uint16_t counter=0;
    for (;;)
        //idle_state_handle();
       char st_msg[20]={0};
       sprintf(st_msg,"Connected #%d\n",counter);
       uint16_t ms_len = strlen(st_msg);
       nrf_delay_ms(4000);
       ble_nus_data_send(&m_nus,(uint8_t*) st_msg, &ms_len, m_conn_handle);
       counter++;
    uint16_t counter=0;
    for (;;)
       char st_msg[71]="Hello, this is a test to see if the data can be sent reliably or not!";
       //sprintf(st_msg,"Connected #%d\n",counter);
       nrf_delay_ms(10000);
       counter++;
   //ret_code_t err_code = app_timer_start(m_data_send_timer, TIMER_INTERVAL, NULL);
    //Enter main loop.
    //for (;;)
    //    idle_state_handle();
