nrf5340 Ethernet and BLE Mesh coexist
Setup:
HW:
Fanstel-WT02C40C (nrf5340/7002)
WIZ5500 ethernet
Versions tested:
ncs-v2.6.0
ncs-v2.5.2
ncs-v2.4.2
Issue:
When attempting to integrate Ethernet and BLE I'm running into an issue where DHCP fails to start the iface on the versions listed above, when introducing CONFIG_BT=y into my system.
I have a working implementation for both my BLE Mesh and for Ethernet, which failed when integrating together so I decided to start piecemeal it together slowly, and on the first step of adding CONFIG_BT=y to my project, is when DHCP begins failing to start Ethernet.
.overlay
&spi4 {
    w5500: w5500@0 {
        compatible = "wiznet,w5500";
        reg = <0>;
        spi-max-frequency = <10000000>;
        zephyr,random-mac-address;
        int-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
        reset-gpios = <&gpio1 5 GPIO_ACTIVE_LOW>;
.conf
# === Ethernet
CONFIG_NETWORKING=y
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=n
CONFIG_NET_DHCPV4=y
CONFIG_NET_LOG=y
CONFIG_NET_SHELL=y
CONFIG_NET_STATISTICS=y
CONFIG_DNS_RESOLVER=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_ETHERNET_LOG_LEVEL_DBG=y
CONFIG_NET_L2_ETHERNET_LOG_LEVEL_DBG=y
CONFIG_NET_DHCPV4_LOG_LEVEL_DBG=y
CONFIG_NET_L2_ETHERNET_MGMT=y
CONFIG_ETH_W5500=y
CONFIG_ETH_W5500_TIMEOUT=1000
CONFIG_NET_MGMT=y
Code:
    struct net_if *iface;
    iface = net_if_get_default();
    if (iface == NULL) {
        printk("Error getting default network interface.\n");
        return;
    // Link status callback handler
    net_mgmt_init_event_callback(&cb, net_mgmt_handler, NET_EVENT_ETHERNET_CARRIER_ON | NET_EVENT_ETHERNET_CARRIER_OFF);
    net_mgmt_add_event_callback(&cb);
    // Start DHCP
    net_dhcpv4_start(iface);
I also need to add WiFi to it, but that's another bridge to be crossed after dealing with this.
