nRF audio DK reference application not visible to smartphone scan
I am evaluating the nRF5340 for a potential BLE audio application. I was able to program the kit following the instructions and using the build script (or through VScode), however the unit is not discoverable and I am not able to find it via bluetooth scan from my iphone or from my laptop. I am able to see the device using the mobile app "nRF Connect for Mobile" but this one shows issues as well when connecting to it. Is this something that anyone else has exhibited before?
Additionally (but less important for the purpose of my evaluation) it is not clear from the link https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/index.html how to program the unit to be a left/right channel or (if it is possible) to program it as duo when using VS code.
Thank you for your support!
  • Hi Dejan,
    How did you perform the scan? Which application did you use on the laptop and iPhones? Did you try with Android phone?
    I don't use any application, I am scanning for available bluetooth devices using my iphone or my windows laptop. I did not try an android phone.
    Are you using 2 different devices that you programmed as headset and gateway, or do you have only one device which you previously programmed as headset and now as gateway?
    I am using a single device. The purpose is to evaluate the LE audio DK and the possibility to use this platform for the development of a headset.
    Can you show this "connecting ..." status?
    When I use my laptop or iphone, the NRF5340_AUDIO device is not discoverable. However, when I use the nRF connect mobile app, I am able to see the device NRF5340_AUDIO. When connecting to it, the app seems to hang in the "Connecting" state for a minute. The serial log of the device looks like this:
    HL [00:15:59.873,474] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:01.154,357] <inf> bt_mgmt: Directed adv timed out with no connection, reverting to normal adv
    HL [00:16:01.157,287] <inf> bt_mgmt_adv: Local addr: 73:7D:73:4E:07:29 (random)
    HL [00:16:01.158,203] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:02.850,494] <inf> bt_mgmt: Connected: F8:C3:CC:16:E3:ED (public)
    HL [00:16:02.850,524] <inf> main: Connected
    HL [00:16:03.021,087] <inf> bt_mgmt: Disconnected: F8:C3:CC:16:E3:ED (public) (reason 0x3e)
    HL [00:16:03.021,087] <inf> main: Disconnected
    HL [00:16:03.021,118] <wrn> bt_content_ctrl_media: Unable to look up conn pointer: -3
    HL [00:16:03.021,118] <err> bt_content_ctrl: bt_content_ctrl_media_conn_disconnected failed with -3
    HL [00:16:03.022,735] <inf> bt_mgmt_adv: Local addr: 73:7D:73:4E:07:29 (random)
    HL [00:16:03.022,827] <inf> bt_mgmt_adv: Adv directed to: F8:C3:CC:16:E3:ED (public).
    HL [00:16:03.023,437] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:04.304,321] <inf> bt_mgmt: Directed adv timed out with no connection, reverting to normal adv
    HL [00:16:04.307,250] <inf> bt_mgmt_adv: Local addr: 76:05:04:36:2E:D3 (random)
    HL [00:16:04.308,166] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:09.780,120] <inf> bt_mgmt: Connected: F8:C3:CC:16:E3:ED (public)
    HL [00:16:09.780,151] <inf> main: Connected
    HL [00:16:09.951,904] <inf> bt_mgmt: Disconnected: F8:C3:CC:16:E3:ED (public) (reason 0x3e)
    HL [00:16:09.951,934] <inf> main: Disconnected
    HL [00:16:09.951,934] <wrn> bt_content_ctrl_media: Unable to look up conn pointer: -3
    HL [00:16:09.951,965] <err> bt_content_ctrl: bt_content_ctrl_media_conn_disconnected failed with -3
    HL [00:16:09.953,582] <inf> bt_mgmt_adv: Local addr: 76:05:04:36:2E:D3 (random)
    HL [00:16:09.953,643] <inf> bt_mgmt_adv: Adv directed to: F8:C3:CC:16:E3:ED (public).
    HL [00:16:09.954,284] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:11.235,168] <inf> bt_mgmt: Directed adv timed out with no connection, reverting to normal adv
    HL [00:16:11.238,098] <inf> bt_mgmt_adv: Local addr: 76:D0:4D:1F:15:D8 (random)
    HL [00:16:11.239,013] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:13.352,355] <inf> bt_mgmt: Connected: F8:C3:CC:16:E3:ED (public)
    HL [00:16:13.352,386] <inf> main: Connected
    HL [00:16:13.521,667] <inf> bt_mgmt: Disconnected: F8:C3:CC:16:E3:ED (public) (reason 0x3e)
    HL [00:16:13.521,667] <inf> main: Disconnected
    HL [00:16:13.521,697] <wrn> bt_content_ctrl_media: Unable to look up conn pointer: -3
    HL [00:16:13.521,697] <err> bt_content_ctrl: bt_content_ctrl_media_conn_disconnected failed with -3
    HL [00:16:13.523,315] <inf> bt_mgmt_adv: Local addr: 76:D0:4D:1F:15:D8 (random)
    HL [00:16:13.523,406] <inf> bt_mgmt_adv: Adv directed to: F8:C3:CC:16:E3:ED (public).
    HL [00:16:13.524,017] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:14.804,901] <inf> bt_mgmt: Directed adv timed out with no connection, reverting to normal adv
    HL [00:16:14.807,830] <inf> bt_mgmt_adv: Local addr: 71:C8:74:03:0A:A2 (random)
    HL [00:16:14.808,746] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:16.065,765] <inf> bt_mgmt: Connected: F8:C3:CC:16:E3:ED (public)
    HL [00:16:16.065,795] <inf> main: Connected
    HL [00:16:16.222,595] <inf> bt_mgmt: Disconnected: F8:C3:CC:16:E3:ED (public) (reason 0x3e)
    HL [00:16:16.222,625] <inf> main: Disconnected
    HL [00:16:16.222,625] <wrn> bt_content_ctrl_media: Unable to look up conn pointer: -3
    HL [00:16:16.222,625] <err> bt_content_ctrl: bt_content_ctrl_media_conn_disconnected failed with -3
    HL [00:16:16.224,243] <inf> bt_mgmt_adv: Local addr: 71:C8:74:03:0A:A2 (random)
    HL [00:16:16.224,334] <inf> bt_mgmt_adv: Adv directed to: F8:C3:CC:16:E3:ED (public).
    HL [00:16:16.224,945] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:17.505,828] <inf> bt_mgmt: Directed adv timed out with no connection, reverting to normal adv
    HL [00:16:17.508,789] <inf> bt_mgmt_adv: Local addr: 57:01:2A:0E:98:CF (random)
    HL [00:16:17.509,704] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:20.258,697] <inf> bt_mgmt: Connected: F8:C3:CC:16:E3:ED (public)
    HL [00:16:20.258,728] <inf> main: Connected
    HL [00:16:20.421,783] <inf> bt_mgmt: Disconnected: F8:C3:CC:16:E3:ED (public) (reason 0x3e)
    HL [00:16:20.421,783] <inf> main: Disconnected
    HL [00:16:20.421,813] <wrn> bt_content_ctrl_media: Unable to look up conn pointer: -3
    HL [00:16:20.421,813] <err> bt_content_ctrl: bt_content_ctrl_media_conn_disconnected failed with -3
    HL [00:16:20.423,431] <inf> bt_mgmt_adv: Local addr: 57:01:2A:0E:98:CF (random)
    HL [00:16:20.423,522] <inf> bt_mgmt_adv: Adv directed to: F8:C3:CC:16:E3:ED (public).
    HL [00:16:20.424,133] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:21.705,017] <inf> bt_mgmt: Directed adv timed out with no connection, reverting to normal adv
    HL [00:16:21.707,946] <inf> bt_mgmt_adv: Local addr: 4E:A6:8A:D7:DF:6D (random)
    HL [00:16:21.708,862] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:16:23.193,054] <inf> bt_mgmt: Connected: F8:C3:CC:16:E3:ED (public)
    HL [00:16:23.193,084] <inf> main: Connected
    HL [00:16:23.569,244] <inf> main: Security changed
    HL [00:16:23.629,211] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
    HL [00:16:23.718,963] <err> bt_content_ctrl_media: Discovery of MCS failed (-61)
    It seems like it connects and tries cyclically to establish a connection until it eventually stops with the following message:
    At this point the nRF mobile connect app shows as in the "Connected" state. I am able to see all the services through the app. But I am unable to connect it as an audio device to my laptop or iphone.
    Is this behavior normal and expected or could it be the reason that my audio DK is not discoverable and cannot connect to my iphone/laptop?
  • Hi Dejan, as we can see in the log, the unit disconnects regularly about 160-170ms after connecting.
    Do you have any recommendations?
    There have been a few public holidays here due to National day among other. Dejan should be able to look into your follow up end of this week.
    Kenneth
  • Hi  ,
    I am sorry for a delayed reply. I was out of the office.
    Could you please provide all necessary steps (including code and configuration changes, and build command) which I could follow when trying to replicate the issue?
    Dejan
  • Hi Dejan, being able to test the EVK is vital for our project. I am not sure what exactly you are looking for and I can share the full zipped project with you.
    As I told you already I simply created a copy of the sample project. I tried to execute with two different SDK versions 2.6.1 and 2.4.0. I tried to build and flash from VScode and from command line as described in your online documentation. When I connect to my iphone using the nRFconnect APP we experience this issue where the unit gets disconnected cyclically 160-170ms after connecting (see the data log that I already attached) (that's why my phone does not find the unit I guess).
    8623.nrf5340_audio.zip
