(2.6.1 update) lte_lc_connect_async crashes [Illegal use of the EPSR]
Migrating to 2.6.1 we have everything working and the project builds. But as soon as lte_lc_connect_async is called the app now crashes. The Faulting instruction address seems like it might be datetime related? I have tried doubling the main thread stack size, the modem thread stack size, and the system queue stack size but nothing seems to have changed it. If I comment out the LTE connection the app runs normally (but doesn't connect to LTE).
[00:00:31.390,899] <wrn> modem: Functional mode changed to 1
[00:00:31.391,693] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
[00:00:31.392,517] <wrn> modem: -><- LTE CONNECTING....
[00:00:31.434,234] <err> os: ***** USAGE FAULT *****
[00:00:31.434,234] <err> os:   Illegal use of the EPSR
[00:00:31.434,265] <err> os: r0/a1:  0x200213a8  r1/a2:  0x200139c0  r2/a3:  0x200139c0
[00:00:31.434,295] <err> os: r3/a4:  0x0002b800 r12/ip:  0x0ccccccc r14/lr:  0x00029edb
[00:00:31.434,326] <err> os:  xpsr:  0x60000000
[00:00:31.434,356] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x20021398  s[ 2]:  0x20021398  s[ 3]:  0x00029a11
[00:00:31.434,356] <err> os: s[ 4]:  0x2002136f  s[ 5]:  0x7959db2c  s[ 6]:  0x008739b0  s[ 7]:  0x0000f750
[00:00:31.434,387] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
[00:00:31.434,417] <err> os: s[12]:  0xffffffff  s[13]:  0xffffffff  s[14]:  0x00000000  s[15]:  0x00000000
[00:00:31.434,417] <err> os: fpscr:  0x00000000
[00:00:31.434,417] <err> os: Faulting instruction address (r15/pc): 0x0002b800
[00:00:31.434,478] <err> os: >>> ZEPHYR FATAL ERROR 35: Unknown error on CPU 0
[00:00:31.434,509] <err> os: Current thread: 0x200139c0 (sysworkq)
[00:00:32.131,866] <err> fatal_error: Resetting system
Zephyr Map
.text.date_time_core_notify_event
                0x000000000002b868       0x1c modules/nrf/lib/date_time/lib..__nrf__lib__date_time.a(date_time_core.c.obj)
 .text.date_time_lte_ind_handler
                0x000000000002b884       0x38 modules/nrf/lib/date_time/lib..__nrf__lib__date_time.a(date_time_core.c.obj)
                0x000000000002b884                date_time_lte_ind_handler
 .text.date_time_core_schedule_update
                0x000000000002b8bc       0x54 modules/nrf/lib/date_time/lib..__nrf__lib__date_time.a(date_time_core.c.obj)
  • It's possible the ble_enable was keeping that work function running or something. The code was basically this before (when the bug was occurring):
    void start_ble_work_fn(struct k_work *work);
    K_WORK_DELAYABLE_DEFINE(start_ble_work, start_ble_work_fn);
    void start_ble_work_fn(struct k_work *work){
        ARG_UNUSED(work);
        err = bt_enable(NULL);
    	if (err) {
    		LOG_ERR("Bluetooth init failed (err %d)\n", err);
    		return err;
    	if (IS_ENABLED(CONFIG_BT_SETTINGS)) {
    		settings_load();
    	ble_interface_evt_handler = event_handler;
        if (err) {
        	LOG_ERR("ble_interface_init, error: %d", err);
        }else{
        	SEND_EVENT(ble, BLE_EVT_START_ADVERTISING);
        	ble_enabled = true;
    void main_loop(){
        if (IS_EVENT(msg, app, APP_EVT_START)){
            k_work_schedule(&start_ble_work, K_SECONDS(3));
    That code worked in SDK 2.5.2 but not after we updated to 2.6.1. It would crash as soon as LTE connected and this was called in lte_lc_helpers.c "curr->handler(evt);" as shown above in a previous response.
    I was able to fix this by instead making the caller wait 3 seconds before sending an event to start ble. This new delayed event then triggered the "start_ble()" function directly rather than from a k_work_delayable function.
    In the end I removed the delay all together and now send an event when all the relevant modules have been all initialized removing the need for the arbitrary 3 second delay.
