nRF Connect VSCode plugin flashing on nRF5340 not working with runner jlink or nrfutil
I don't want to use nrfjprog as the runner. I want to use jlink runner when flashing. However it doesn't work, neither do nrfutil.
nRF Connect for VSCode doesn't work when runner is NOT nrfjprog with nRF5340. Neither using nrfutil or jlink as runner works.
I'm on nRF Connect SDK v2.6.0
I have this issue in a custom board, but can be easily reproduced on nRF5340 dk. Easiest way to choose which runner to use is to directly modify zephyr/boards/arm/nrf5340dk_nrf5340/board.cmake.
You will see following:
include(${ZEPHYR_BASE}/boards/common/nrfjprog.board.cmake)
include(${ZEPHYR_BASE}/boards/common/nrfutil.board.cmake)
include(${ZEPHYR_BASE}/boards/common/jlink.board.cmake)
Simply comment out the two not wanted to try the different runners. The top one will be used, so changing order should also work.
I'm using the zephyr/samples/bluetooth/peripheral_dis sample to reproduce
Using JLink runner
- I added some extra logging to see exactly, jlink runner works when it's a single image build (hex file called merged.hex) but building with Bluetooth doesn't work as it tries to flash the merged_domain.hex, which fails.
- If I go in and manually edit the zephyr/scripts/west_commands/runners/jlink.py
- As you can see in the log, it successfully flashes the app core image, but fails with the net core it seems
Flashing build_dk to 960158604
west flash -d /home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk --skip-rebuild -i 960158604
-- west flash: using runner jlink
-- runners.jlink: JLink version: 7.88k
Do reset False
['ExitOnError 1', 'r', 'loadfile "/home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/merged_domains.hex"', 'g', 'writeDP 1 0', 'readDP 1', 'q']
-- runners.jlink: Flashing file: /home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/merged_domains.hex
SEGGER J-Link Commander V7.88k (Compiled Jul  5 2023 15:00:37)
DLL version V7.88k, compiled Jul  5 2023 15:00:17
J-Link Command File read successfully.
Processing script file...
J-Link>ExitOnError 1
J-Link Commander will now exit on Error
J-Link>r
J-Link connection not established yet but required for command.
Connecting to J-Link via USB...O.K.
Firmware: J-Link OB-K22-NordicSemi compiled Oct 30 2023 12:12:53
Hardware version: V1.00
J-Link uptime (since boot): 0d 00h 33m 27s
S/N: 960158604
License(s): RDI, FlashBP, FlashDL, JFlash, GDB
USB speed mode: Full speed (12 MBit/s)
VTref=3.300V
Target connection not established yet but required for command.
Device "NRF5340_XXAA_APP" selected.
Connecting to target via SWD
ConfigTargetSettings() start
ConfigTargetSettings() end - Took 13us
InitTarget() start
InitTarget() end - Took 1.59ms
Found SW-DP with ID 0x6BA02477
DPIDR: 0x6BA02477
CoreSight SoC-400 or earlier
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[1]: AHB-AP (IDR: Not set)
AP[2]: MEM-AP (IDR: Not set)
AP[3]: MEM-AP (IDR: Not set)
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FE000
CPUID register: 0x410FD214. Implementer code: 0x41 (ARM)
Feature set: Mainline
Cache: No cache
Found Cortex-M33 r0p4, Little endian.
FPUnit: 8 code (BP) slots and 0 literal slots
Security extension: implemented
Secure debug: enabled
CoreSight components:
ROMTbl[0] @ E00FE000
[0][0]: E00FF000 CID B105100D PID 000BB4C9 ROM Table
ROMTbl[1] @ E00FF000
[1][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
[1][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
[1][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
[1][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
[1][5]: E0041000 CID B105900D PID 002BBD21 DEVARCH 47724A13 DEVTYPE 13 ETM
[1][6]: E0042000 CID B105900D PID 000BBD21 DEVARCH 47701A14 DEVTYPE 14 CSS600-CTI
[0][1]: E0040000 CID B105900D PID 000BBD21 DEVARCH 00000000 DEVTYPE 11 TPIU
Memory zones:
  Zone: "Default" Description: Default access mode
Cortex-M33 identified.
Reset delay: 0 ms
Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
Reset: ARMv8M core with Security Extension enabled detected.
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
J-Link>loadfile "/home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/merged_domains.hex"
'loadfile': Performing implicit reset & halt of MCU.
Downloading file [/home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/merged_domains.hex]...
Comparing flash   [100%] Done.
Erasing flash     [100%] Done.
Programming flash [100%] Done.
J-Link: Flash download: Bank 2 @ 0x00000000: 1 range affected (73728 bytes)
J-Link: Flash download: Total: 0.685s (Prepare: 0.067s, Compare: 0.006s, Erase: 0.000s, Program & Verify: 0.565s, Restore: 0.046s)
J-Link: Flash download: Program & Verify speed: 127 KB/s
Writing target memory failed.
Script processing completed.
FATAL ERROR: command exited with status 1: /opt/SEGGER/JLink_V788k/JLinkExe -USB 960158604 -nogui 1 -if swd -speed 4000 -device nrf5340_xxaa_app -CommanderScript /tmp/tmpr50rillvjlink/runner.jlink -nogui 1
 *  The terminal process terminated with exit code: 1.
Using nrfutil runner (nrfutil downloaded from here today https://www.nordicsemi.com/Products/Development-tools/nRF-Util/Download)
- Doesn't work at all
-- west flash: using runner nrfutil
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Flashing file: /home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/merged_domains.hex
-- runners.nrfutil: /home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/merged_domains.hex targets both nRF53 coprocessors; splitting it into: /home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/GENERATED_CP_NETWORK_merged_domains.hex and /home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/GENERATED_CP_APPLICATION_merged_domains.hex
error: unrecognized subcommand 'execute-batch'
  tip: some similar subcommands exist: 'x-execute', 'x-execute-batch'
Usage: nrfutil device [OPTIONS] [COMMAND]
For more information, try '--help'.
FATAL ERROR: command exited with status 2: nrfutil --json device execute-batch --batch-path /home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk/zephyr/generated_nrfutil_batch.json --serial-number 960158604
VSCode debug generate:
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "linux",
    "osVersion": "#29~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Apr  4 14:39:20 UTC 2",
    "osKernel": "6.5.0-28-generic",
    "vscode": "1.89.1",
    "electron": "28.2.8",
    "node": "v18.18.2"
  "system": {
    "date": "2024-05-12T13:17:31.923Z",
    "vscodeRoot": "/snap/code/159/usr/share/code/resources/app",
    "nrfConnectForDesktopInstalled": "unknown",
    "vscodeUptime": "25:08:19",
    "osUptime": "28:46:55",
    "cpu": "Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz"
  "workspace": {
    "name": "project",
    "workspaceFile": null,
    "folders": [
      "/home/jakkra/Documents/project"
  "sdks": [
      "version": "v2.6.0",
      "path": "/home/jakkra/ncs/v2.6.0"
      "version": "v0.7.0-0",
      "path": "/home/jakkra/Documents/project"
  "activeBuild": "/home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk",
  "apps": [
      "workspace": "/home/jakkra/Documents/project",
      "uri": "/home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis",
      "buildConfigurations": [
          "id": "/home/jakkra/Documents/project/zephyr/samples/bluetooth/peripheral_dis/build_dk",
          "name": "build_dk",
          "boardId": "nrf5340dk_nrf5340_cpuapp",
          "type": "Zephyr",
          "isChild": false,
          "isStale": false,
          "taskBindings": {
            "build": [],
            "pristineBuild": [],
            "flash": [],
            "eraseAndFlash": []
  "topdir": "/home/jakkra/Documents/project",
  "workspaceState": "workspace-ready",
  "toolchains": [
      "version": "2.6.0",
      "path": "/home/jakkra/ncs/toolchains/2be090971e"
      "version": "2.4.2",
      "path": "/home/jakkra/ncs/toolchains/1f9b40e71a"
      "version": "2.4.0",
  "connectedDevices": [
      "serialNumber": "000960158604"
  "deviceProvider": "nrfutil",
  "tools": {
    "/home/jakkra/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.5",
    "/opt/SEGGER/JLink/JLinkExe": "7.88k",
    "/usr/local/bin/nrfjprog": "10.22.0",
    "/usr/bin/nrfutil": "7.7.1",
    "/home/jakkra/ncs/toolchains/2be090971e/usr/local/bin/cmake": "3.21.0",
    "/home/jakkra/ncs/toolchains/2be090971e/usr/local/bin/west": "1.2.0",
    "/home/jakkra/ncs/toolchains/2be090971e/usr/local/bin/python3": "3.9.18",
    "/home/jakkra/ncs/toolchains/2be090971e/usr/local/bin/ninja": "1.10.2",
    "/home/jakkra/ncs/toolchains/2be090971e/usr/bin/gperf": "3.1",
    "/home/jakkra/ncs/toolchains/2be090971e/usr/bin/dtc": "1.5.0",
    "/home/jakkra/ncs/toolchains/2be090971e/opt/bin/gn": "2132",
    "/home/jakkra/ncs/toolchains/2be090971e/usr/local/bin/git": "2.37.3",
    "gdbPath": "/home/jakkra/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
  "nrfutil": {
    "nrfutil-device": {
      "version": "2.0.0",
      "binPath": "/home/jakkra/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-linux-x64/platform/nrfutil/bin/nrfutil-device"
    "nrfutil-toolchain-manager": {
      "version": "0.14.1",
      "binPath": "/home/jakkra/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-linux-x64/platform/nrfutil/bin/nrfutil-toolchain-manager"
  "environment": {
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "GIT_EXEC_PATH": "/home/jakkra/ncs/toolchains/2be090971e/usr/local/libexec/git-core",
      "HOME": "/home/jakkra",
      "PATH": "/home/jakkra/ncs/toolchains/2be090971e/usr/bin:/home/jakkra/ncs/toolchains/2be090971e/usr/bin:/home/jakkra/ncs/toolchains/2be090971e/usr/local/bin:/home/jakkra/ncs/toolchains/2be090971e/opt/bin:/home/jakkra/ncs/toolchains/2be090971e/opt/nanopb/generator-bin:/home/jakkra/ncs/toolchains/2be090971e/opt/zephyr-sdk/aarch64-zephyr-elf/bin:/home/jakkra/ncs/toolchains/2be090971e/opt/zephyr-sdk/x86_64-zephyr-elf/bin:/home/jakkra/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin:/home/jakkra/ncs/toolchains/2be090971e/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/home/jakkra/.local/bin:/home/jakkra/.local/bin:/home/jakkra/.local/lib/python3.10/site-packages:/home/jakkra/.local/bin:/home/jakkra/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/home/jakkra/.local/bin:/home/jakkra/.local/bin:/home/jakkra/.local/bin:/home/jakkra/.local/bin:/home/jakkra/.local/lib/python3.10/site-packages:/home/jakkra/.local/bin:/home/jakkra/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/home/jakkra/.local/bin:/home/jakkra/.local/bin",
      "ZEPHYR_BASE": "/home/jakkra/Documents/project/zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "/home/jakkra/ncs/toolchains/2be090971e/opt/zephyr-sdk",
      "PYTHONPATH": "/home/jakkra/ncs/toolchains/2be090971e/usr/local/lib/python3.9:/home/jakkra/ncs/toolchains/2be090971e/usr/local/lib/python3.9/site-packages",
      "USER": "jakkra"
    "inherited": {
      "PATH": "/home/jakkra/.local/bin:/home/jakkra/.local/bin:/home/jakkra/.local/lib/python3.10/site-packages:/home/jakkra/.local/bin:/home/jakkra/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/home/jakkra/.local/bin:/home/jakkra/.local/bin",
      "USER": "jakkra"
    "toolchainPath": "/home/jakkra/ncs/toolchains/2be090971e",
    "toolchainBinPath": "/home/jakkra/ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin",
    "toolchainVersion": "2.6.0"
  "terminal": {
    "defaultProfile": null
  "config": {
      "topdir": "",
      "toolchain": {
        "path": "${nrf-connect.toolchain:2.6.0}"
      "ozonePath": "",
      "applications": [
        "${workspaceFolder}/app",
        "${workspaceFolder}\\app",
        "${workspaceFolder}/zephyr/samples/bluetooth/peripheral_dis",
        "${workspaceFolder}/zephyr/samples/subsys/usb/mass"
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig"
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [
        "${workspaceFolder}/zephyr",
        "${workspaceFolder}\\zephyr"
      "taskBindings": {},
      "buildTerminal": {
        "condensedProgress": true
      "debugging": {
        "flash": false,
        "bindings": {
          "${workspaceFolder}/app/build": "Launch build"
        "justMyCode": false
      "deviceProvider": "",
      "flash": {
        "softreset": false,
        "erase": false,
        "recover": false
      "enableTelemetry": true,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": null
      "nrfutil": {
        "home": null
      "defaultOpenAction": "ask",
      "welcome": {
        "showOnStartup": true
      "terminalMode": "character"
  "extensions": {
    "internal": {
        "version": "2024.3.25",
        "path": "/home/jakkra/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-linux-x64",
        "isActive": true
        "version": "2024.3.15",
        "path": "/home/jakkra/.vscode/extensions/nordic-semiconductor.nrf-terminal-2024.3.15",
        "isActive": true
        "version": "2024.3.78",
        "path": "/home/jakkra/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2024.3.78",
        "isActive": true
        "version": "2024.3.21",
        "path": "/home/jakkra/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2024.3.21",
        "isActive": true
    "external": {
      "marus25.cortex-debug": null,
      "ms-vscode.cpptools": "1.20.5",
      "ms-vscode.js-debug": "1.89.0",
      "ms-vscode.js-debug-companion": "1.1.2",
      "ms-vscode.vscode-js-profile-table": "1.0.9",
      "chiehyu.vscode-astyle": "0.9.0",
      "GitHub.copilot": "1.188.0",
      "GitHub.copilot-chat": "0.15.1",
      "ms-python.debugpy": "2024.6.0",
      "ms-python.python": "2024.6.0",
      "ms-python.vscode-pylance": "2024.5.1",
      "ms-vscode-remote.remote-containers": "0.362.0",
      "ms-vscode.hexeditor": "1.10.0",
      "smcpeak.default-keys-windows": "0.0.10",
      "twxs.cmake": "0.0.17",
      "webfreak.debug": "0.27.0"
EDIT: After writing this ticker I saw that nRF COnnect 2.6.1 was released also, so I tried it, but flashing still fails there.
    The main culprit when using nrfjprog as runner is the erase type that west uses as default, which is --sectoranduicrerase for the nRF52 device family and --sectorerase for other device families. Here you can see the time it takes to program the Matter light bulb sample on the nRF52840 DK using nrfjprog directly with sectoranduicrerase:
    ~/ncs/nrf/samples/matter/light_bulb/build/zephyr$ time nrfjprog --program merged.hex --sectoranduicrerase --verify
    [ #################### ]  22.069s | Erase file - Done erasing
    [ #################### ]  10.054s | Program file - Done programming
    [ #################### ]   9.856s | Verify file - Done verifying
    real	0m43,825s
    user	0m0,943s
    sys	0m1,267s
    If you use west --erase instead of west, it will use the --chiperase flag, which should reduce the time:
    ~/ncs/nrf/samples/matter/light_bulb/build/zephyr$ time nrfjprog --program merged.hex --chiperase --verify
    [ #################### ]   0.207s | Erase file - Done erasing
    [ #################### ]  10.052s | Program file - Done programming
    real	0m21,863s
    user	0m0,522s
    sys	0m1,067s
    ~/ncs/nrf/samples/matter/light_bulb/build$ time west flash --skip-rebuild --erase
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: mass erase requested
    -- runners.nrfjprog: reset after flashing requested
    Using board 683635785
    -- runners.nrfjprog: Flashing file: /home/marte/ncs/nrf/samples/matter/light_bulb/build/zephyr/merged.hex
    [ #################### ]   0.206s | Erase file - Done erasing
    [ #################### ]  10.051s | Program file - Done programming
    [ #################### ]   9.852s | Verify file - Done verifying
    Enabling pin reset.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 683635785 flashed successfully.
    real	0m25,646s
    user	0m1,637s
    sys	0m3,439s
    It is still not as good as jlink, but it is an improvement.
    Using --erase is the same as the 'Erase and Flash to Board' action in the vscode extension:
    Marte
  • Yes this I'm aware of. Experimented with JLink, and doing an erase and then program using JLink takes:
    time /opt/SEGGER/JLink_V788k/JLinkExe -nogui 1 -if swd -speed 4000 -device nrf5340_xxaa_app -CommanderScript jlink_erase -nogui 1 && time /opt/SEGGER/JLink_V788k/JLinkExe -nogui 1 -if swd -speed 4000 -device nrf5340_xxaa_app -CommanderScript jlink_file_flash -nogui 1
     0m1,393s(erase) +  0m8,581s(program+verify) = ~10s
    Vs.
    time nrfjprog --program app/build_debug/zephyr/merged.hex --chiperase --verify
    real    0m21,907s
    So there are defenately room for improvement by getting the jlink runner functional for nRF53.
    I'll file a bug into Zephyr instead for getting jlink runner functional, and hopefully I get some time myself to fix this.
    You can close this ticket, thank you Slight smile
