Problems with nRF sniffer
I have a dongle attached to my Windows PC and it has the nRF Sniffer firmware flashed onto it. I have also installed the nRF Sniffer extension for Wireshark.
When I start a capture, I see many Advertisements, including for the peripheral I wish to monitor/debug. However, when my app connects to device under test, I do not see any interaction in Wireshark, the same is tur when I write data to the DUT.
I need some help getting the packets the two devices are sending shown in Wireshark.
The device and the app are operating as expected, I just do not see the interaction in Wireshark.
Sid
  • Hi
    Would you be able to test again when using a DK as the sniffer, or by using a USB extension cable to move the sniffer dongle away from the PC/hub?
    Alternatively, run the sniffer from one PC, and the devices under test from another.
    It's a bit of a long shot, but it is common for noise generated by the USB ports to influence RF performance when there is activity on the USB bus, this might be a factor here. If the sniffer drops too many packets in the connection it might lose the sync altogether.
    Best regards
    Torbjørn
