LED Strip - SPI failures at ~250 LEDs?
Hi all.
I have made myself a board which has a module with the nRF52833 chip embedded onto it. It's effectively a board with a set of switching regulators on it to drive multiple strings of LEDs. I have been testing the board with relatively small strings of SK6812 RGBW LEDs - up to 120 or so - and all has been working fine. Today I have received a longer strip of LEDs and I'm apparently having issues driving it.
The code is relatively simple, I am generating pixels and sending them towards the strip using the ws2812_spi driver:
ret = led_strip_update_rgb(strips[i]->device, strips[i]->buffer, offset); // Update physical
An example of my config (there's one for each of the four SPI buses):
&spi2 {
    compatible="nordic,nrf-spim";
    status = "okay";
    pinctrl-0 = <&spi2_default>;
    pinctrl-1 = <&spi2_sleep>;
    led_strip2: ws2812@2 {
        compatible = "worldsemi,ws2812-spi";
        /* SPI */
        reg = <2>; /* ignored, but necessary for SPI bindings */
        spi-max-frequency = <SPI_FREQ>;
        /* WS2812 */
        chain-length = <300>; /* arbitrary; change at will */
        color-mapping = <LED_COLOR_ID_GREEN
                 LED_COLOR_ID_RED
                 LED_COLOR_ID_BLUE
                 LED_COLOR_ID_WHITE
        spi-one-frame = <ONE_FRAME>;
        spi-zero-frame = <ZERO_FRAME>;
The issue is that when I try and update a longer strip - up to around 240 pixels works fine but somewhere around 250 it fails - something is locking on a mutex or otherwise dying. Note that the LED strip physically is correctly updated to the # of pixels I requested, including my maximum string length of 300... but the board/OS is then locked up.
If I debug the code, wait for it to fail, and breakpoint - no fatal error happens "naturally" - then the main thread call-stack is stuck here:
arch_swap(unsigned int key) (c:\ncs\v2.6.0\zephyr\arch\arm\core\cortex_m\swap.c:48)
spi_context_wait_for_completion(struct spi_context * ctx) (c:\ncs\v2.6.0\zephyr\drivers\spi\spi_context.h:169)
transceive(const struct device * dev, const struct spi_config * spi_cfg, const struct spi_buf_set * tx_bufs, const struct spi_buf_set * rx_bufs, _Bool asynchronous, spi_callback_t cb, void * userdata) (c:\ncs\v2.6.0\zephyr\drivers\spi\spi_nrfx_spim.c:446)
spi_nrfx_transceive(const struct device * dev, const struct spi_config * spi_cfg, const struct spi_buf_set * tx_bufs, const struct spi_buf_set * rx_bufs) (c:\ncs\v2.6.0\zephyr\drivers\spi\spi_nrfx_spim.c:485)
spi_transceive(const struct spi_buf_set * rx_bufs, const struct spi_buf_set * tx_bufs, const struct spi_config * config, const struct device * dev) (c:\V\led_board_testing\build\zephyr\include\generated\syscalls\spi.h:38)
spi_write(const struct spi_buf_set * tx_bufs, const struct spi_config * config, const struct device * dev) (c:\ncs\v2.6.0\zephyr\include\zephyr\drivers\spi.h:837)
spi_write_dt(const struct spi_dt_spec * spec, const struct spi_buf_set * tx_bufs) (c:\ncs\v2.6.0\zephyr\include\zephyr\drivers\spi.h:855)
ws2812_strip_update_rgb(const struct device * dev, struct led_rgb * pixels, size_t num_pixels) (c:\ncs\v2.6.0\zephyr\drivers\led_strip\ws2812_spi.c:152)
led_strip_update_rgb(size_t num_pixels, struct led_rgb * pixels, const struct device * dev) (c:\ncs\v2.6.0\zephyr\include\zephyr\drivers\led_strip.h:105)
For clarity, the exact line it's gone away on is:
if (k_sem_take(&ctx->sync, timeout)) {
And I'm getting an exception only when I breakpoint, on the logging thread (which seems arbitrary, as if I entirely remove logging, I get the exception instead on the gpio_handler thread):
k_sys_fatal_error_handler(unsigned int reason, const z_arch_esf_t * esf) (c:\ncs\v2.6.0\zephyr\kernel\fatal.c:41)
<signal handler called> (Unknown Source:0)
mpsc_pbuf_free(struct mpsc_pbuf_buffer * buffer, const union mpsc_pbuf_generic * item) (c:\ncs\v2.6.0\zephyr\lib\os\mpsc_pbuf.c:577)
msg_free(struct mpsc_pbuf_buffer * buffer, const union log_msg_generic * msg) (c:\ncs\v2.6.0\zephyr\subsys\logging\log_core.c:739)
log_process() (c:\V\led_board_testing\build\zephyr\include\generated\syscalls\log_ctrl.h:57)
log_process_thread_func(void * dummy1, void * dummy2, void * dummy3) (c:\ncs\v2.6.0\zephyr\subsys\logging\log_core.c:908)
Also note that I have trivially modified a few SPI files to add logging, and the ws2812_spi.c driver to override the buffer length based on num_pixels instead the length preconfigured in the config (i.e.buf.len = cfg->num_colors * 8 * num_pixels; ), so line references in the call stacks may not line up.
Any hints for debugging/diagnosing or potential hardware limitations I'm hitting are welcome (I don't believe this to be a power issue as all the LEDs are correctly updated and lit despite SPI not returning, and power draw is ~1 amp with the regulator rated at 5 and my PSU rated at 10).
Versions:
NCS 2.6.0; custom dts based on this:
#include <nordic/nrf52833_qiaa.dtsi>
#include <zephyr/dt-bindings/led/led.h>
Thanks for reading.
  • Apologies, I know I'm spamming a bit, but I'm getting further, perhaps, and I'm not sure when I'll give up for the night, nor when anybody else will look, so...
    The call stack for the fail is currently this (I still have to hit pause to retrieve it, even with the BUS FAULT already sitting in the RTT logging):
    sys_slist_peek_next_no_check(sys_snode_t * node) (c:\ncs\v2.6.0\zephyr\include\zephyr\sys\slist.h:281)
    sys_slist_peek_next(sys_snode_t * node) (c:\ncs\v2.6.0\zephyr\include\zephyr\sys\slist.h:292)
    gpio_fire_callbacks(sys_slist_t * list, const struct device * port, uint32_t pins) (c:\ncs\v2.6.0\zephyr\include\zephyr\drivers\gpio\gpio_utils.h:91)
    nrfx_gpio_handler(nrfx_gpiote_pin_t abs_pin, nrfx_gpiote_trigger_t trigger, void * context) (c:\ncs\v2.6.0\zephyr\drivers\gpio\gpio_nrfx.c:384)
    call_handler(gpiote_control_block_t * p_cb, nrfx_gpiote_pin_t pin, nrfx_gpiote_trigger_t trigger) (c:\ncs\v2.6.0\modules\hal\nordic\nrfx\drivers\src\nrfx_gpiote.c:1414)
    next_sense_cond_call_handler(gpiote_control_block_t * p_cb, nrfx_gpiote_pin_t pin, nrfx_gpiote_trigger_t trigger, nrf_gpio_pin_sense_t sense) (c:\ncs\v2.6.0\modules\hal\nordic\nrfx\drivers\src\nrfx_gpiote.c:1451)
    port_event_handle(NRF_GPIOTE_Type * p_gpiote, gpiote_control_block_t * p_cb) (c:\ncs\v2.6.0\modules\hal\nordic\nrfx\drivers\src\nrfx_gpiote.c:1501)
    irq_handler(NRF_GPIOTE_Type * p_gpiote, gpiote_control_block_t * p_cb) (c:\ncs\v2.6.0\modules\hal\nordic\nrfx\drivers\src\nrfx_gpiote.c:1666)
    nrfx_gpiote_0_irq_handler() (c:\ncs\v2.6.0\modules\hal\nordic\nrfx\drivers\src\nrfx_gpiote.c:1674)
    nrfx_isr(const void * irq_handler) (c:\ncs\v2.6.0\zephyr\modules\hal_nordic\nrfx\nrfx_glue.c:13)
    _isr_wrapper() (c:\ncs\v2.6.0\zephyr\arch\arm\core\cortex_m\isr_wrapper.S:128)
    data_out_block_mode(uint8_t * data, size_t length, void * ctx) (c:\ncs\v2.6.0\zephyr\subsys\logging\backends\log_backend_rtt.c:204)
    All crashes so far (at least tonight) are in this function used within some flavour of gpiote irq handler:
    static inline sys_snode_t *z_snode_next_peek(sys_snode_t *node)
        return node->next;
    For the call stack above, main()'s call stack:
    ws2812_reset_delay(uint16_t delay) (c:\ncs\v2.6.0\zephyr\drivers\led_strip\ws2812_spi.c:89)
    ws2812_strip_update_rgb(const struct device * dev, struct led_rgb * pixels, size_t num_pixels) (c:\ncs\v2.6.0\zephyr\drivers\led_strip\ws2812_spi.c:155)
    main() (c:\V\led_board_testing\src\main.c:1314)
    I tried turning logging off and it still all crashes. I cannot debug to that line in slist.h because putting a breakpoint there fails to even start debug. I can still add breakpoints and single-step through n cycles of SPI/LED strip updates with no crash.
  • If I run 250 LEDs, it fails.
    If I comment my code that initialises IRQs for my buttons, everything works, 240 or 250 LEDs.
    If I run 240 LEDs, everything, including my buttons, work.
    With 250 LEDs it works if I hold the button down upon boot, but dies as soon as a button IRQ arrives (edge to inactive).
    I'm so confused.
    In the hope that I've got something really stupid wrong and I'm looking past it - as opposed to memory corruption or other fun - my button initialisation is as follows (copied from the sample almost verbatim but replicated over three buttons):
    static const struct gpio_dt_spec switch_driver = GPIO_DT_SPEC_GET(DT_NODELABEL(buttondrvdoor), gpios);
    static const struct gpio_dt_spec switch_passenger = GPIO_DT_SPEC_GET(DT_NODELABEL(buttonpassdoor), gpios);
    static const struct gpio_dt_spec switch_boot = GPIO_DT_SPEC_GET(DT_NODELABEL(buttonbootlid), gpios);
    static struct gpio_callback button_drvdoor_cb_data;
    static struct gpio_callback button_passdoor_cb_data;
    static struct gpio_callback button_bootlid_cb_data;
    static inline int initialise_buttons(void) {
        if (!gpio_is_ready_dt(&switch_driver)) {
            LOG_ERR("Error: button device %s is not ready\n",
                    switch_driver.port->name);
            return -1;
        if (!gpio_is_ready_dt(&switch_passenger)) {
                    switch_passenger.port->name);
            return -1;
        if (!gpio_is_ready_dt(&switch_boot)) {
                    switch_boot.port->name);
            return -1;
        return 0;
    static void flag_status(const struct gpio_dt_spec* switch_, uint32_t identifier) {
        struct switch_event event = {.action = gpio_pin_get_dt(switch_) ? SWITCH_STATE_OPENED : SWITCH_STATE_CLOSED, .identifier = identifier};
        int qr = k_msgq_put(&switch_event_q, &event, K_NO_WAIT);
    #define BUTTON_IRQ(switch_name, callback_data, fn) \
        LOG_WRN(">>>>>>>>>>>>>>>>>>> Configuring %s to %s to %s", #switch_name, #callback_data, #fn); \
        ret = gpio_pin_configure_dt(&switch_name, GPIO_INPUT);\
        if (ret != 0) {\
            LOG_ERR("Error %d: failed to configure %s pin %d\n",\
                   ret, switch_name.port->name, switch_name.pin);\
            return -1;\
        ret = gpio_pin_interrupt_configure_dt(&switch_name, \
                                               GPIO_INT_EDGE_BOTH); \
        if (ret != 0) { \
                LOG_ERR("Error %d: failed to configure interrupt on %s pin %d\n", \
                        ret, switch_name.port->name, switch_name.pin); \
                return -1; \
        gpio_init_callback(&callback_data, fn, BIT(switch_name.pin)); \
        gpio_add_callback(switch_name.port, &callback_data); \
        LOG_INF("Set up button at %s pin %d\n", switch_name.port->name, switch_name.pin);
    void button_drvdoor_pressed(const struct device *dev, struct gpio_callback *cb,
                        uint32_t pins)
        flag_status(&switch_driver, SWITCH_ID_DRIVERSDOOR);
    void button_passdoor_pressed(const struct device *dev, struct gpio_callback *cb,
                        uint32_t pins)
        flag_status(&switch_passenger, SWITCH_ID_PASSENGERSDOOR);
    void button_bootlid_pressed(const struct device *dev, struct gpio_callback *cb,
                        uint32_t pins)
        flag_status(&switch_boot, SWITCH_ID_BOOTLID);
    static inline int initialise_button_irqs(void) {
        int ret;
    // COMMENT THESE THREE NEXT LINES AND EVERYTHING WORKS IN ALL SCENARIOS:
        BUTTON_IRQ(switch_driver, button_drvdoor_cb_data, button_drvdoor_pressed)
        BUTTON_IRQ(switch_passenger, button_passdoor_cb_data, button_passdoor_pressed)
        BUTTON_IRQ(switch_boot, button_bootlid_cb_data, button_bootlid_pressed)
        return ret;
        int ret;
        LOG_INF("Bluetooth LED peripheral booting... %s\n", CONFIG_BOARD);
        LOG_INF("Build time: " __DATE__ " " __TIME__ "\n");
        ret = initialise_buttons();
        ret = initialise_button_irqs();
    ... rest of LED code etc.
    Breakpoints in button_*_pressed are never hit but once I saw a call stack with button_bootlid_pressed in it.
    Giving up for the night, thanks for reading.
  • One more time with feeling.
    This now seems to be a problem 100% with the IRQ handling: I can reproduce a HARD FAULT merely by having buttons hooked to an IRQ.
    I have trimmed my main() code to this:
        int ret;
        LOG_INF("Button init %d", ret);
        LOG_INF("Button IRQ %d", ret);
        if (!gpio_is_ready_dt(&led_diag)) {
            LOG_ERR("Diagnostic LED failed.\n");
            return 0;
        while(true) {
            ret = gpio_pin_toggle_dt(&led_diag);
            k_msleep(1000);
        return 0;
    With the other code previously given (IRQ handlers are currently empty).
    My device config for these buttons:
        buttons {
            compatible = "gpio-keys";
            buttondrvdoor: button_drvdoor {
                gpios = < &gpio1 4 GPIO_ACTIVE_HIGH >;
                label = "Driver Door";
                status = "okay";
            buttonpassdoor: button_passdoor {
                gpios = < &gpio1 2 GPIO_ACTIVE_HIGH >;
                label = "Passenger Door";
                status = "okay";
            buttonbootlid: button_bootlid {
                gpios = < &gpio1 0 GPIO_ACTIVE_HIGH >;
                label = "Boot Lid";
                status = "okay";
    The code runs fine and I can hit the buttons on drvdoor and passdoor and all is fine. As soon as I release bootlid I get a HARD FAULT with the fault line being the closing } of the empty handler:
    button_bootlid_pressed(const struct device * dev, struct gpio_callback * cb, uint32_t pins) (c:\V\led_board_testing\src\main.c:560)
    gpio_fire_callbacks(sys_slist_t * list, const struct device * port, uint32_t pins) (c:\ncs\v2.6.0\zephyr\include\zephyr\drivers\gpio\gpio_utils.h:94)
    gpiote_evt_handle(NRF_GPIOTE_Type * p_gpiote, gpiote_control_block_t * p_cb, uint32_t mask) (c:\ncs\v2.6.0\modules\hal\nordic\nrfx\drivers\src\nrfx_gpiote.c:1650)
    irq_handler(NRF_GPIOTE_Type * p_gpiote, gpiote_control_block_t * p_cb) (c:\ncs\v2.6.0\modules\hal\nordic\nrfx\drivers\src\nrfx_gpiote.c:1671)
    idle(void * unused1, void * unused2, void * unused3) (c:\ncs\v2.6.0\zephyr\kernel\idle.c:89)
    Is there something special about pin 0 on port 1? Have I missed setup somewhere? The code is identical for all three buttons, and two work (GPIO1:2 and GPIO1:4) and one fails (GPIO1:0).
  • I now cannot reproduce it with the exact same code as above. The IRQ handlers all work now. If I revert the code back to as it was before, I'm back to fine at 240 LEDs, dead at 250 though. It's still going AWOL in the gpio IRQ handler stack when it crashes. I'll try and pull it apart bit by bit and find if it works if I pull some other code...
  • Good news on a Friday night: I have found a buffer overrun in my own (LED pixel generation) code and early indications are that this fixes my core issue.
    What I cannot understand is why the minimal code with only the button/GPIO/IRQ handler broke, because that same code now works fine, and the broken code never ran there. Is it possible that I trashed something in memory and it survived a debug restart? I wasn't turning the device off and on, just modify code, build, debug... I'm concerned there's still something wrong and it's going to bite me randomly.
