Hi there,
I have an nrf5340 DK and I wonder if it is possible to upgrade my own application firmware via fwupd tool on Ubuntu. Does this feature come along with a dongle?
Hi there,
Thanks. To make it much clear, what I want to know is that once I connect a Nordic device to the PC via BLE and install all the depensencies, I could upgrade the device through fwupd command without plugging in a Nordic dongle.
Here are what they say:
The image update is transferred over HID configuration channel (Configuration channel — nRF Connect SDK 2.6.99 documentation (nordicsemi.com)). It uses HID feature reports as underlying transport, so that you can perform background DFU over USB, BLE or even through an nRF Desktop dongle. During update image transfer, the HID device can still be used. Since, the DFU is expected to be done in the background, the default DFU speed is not too high (protocol focuses on mitigating negative impacy on HID device performance).
You can use fwupd daemon with fwupdmgr CLI tool to perform an update (nRF Desktop: fwupd support — nRF Connect SDK 2.6.99 documentation (nordicsemi.com)). We even uploaded some DFU images that are already globally available and can be used to test the DFU with fwupd (fwupd is available e.g. on Ubuntu or ChromeOS): https://fwupd.org/lvfs/search?value=Nordic
We also support HID configurator Python script that can be used to test DFU over configuration channel locally - https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/scripts/hid_configurator/README.html
Does this answer your question?
Thanks. I've ordered an nrf52840 dev kit to figure out the fwupd process with a hands-on practice.
Thank you for your answer but the link does not specify how to upgrade with fwupd, and what firmware should I burn so that he can recognize it as an hidraw device? Looking forward to your reply
I have bought the NRF52840 development kit, but I still can't test the upgrade using fwupd, can you run it normally? Looking forward to your reply
