nRF9161 - Ciphersuites sample - example.com refuses all Ciphersuites.
Running the Ciphersuites sample code on the nRF9161 I get Connection Refused on all attempted ciphersuites. Including after adding the CONFIG_EXTENDED_CIPHERSUITE_LIST=y to the prj.conf.
*** Booting nRF Connect SDK d96769faceca ***
TLS Ciphersuites sample started
Certificate mismatch
Provisioning certificate
Waiting for network.. OK
Trying all ciphersuites to find which ones are supported...
Trying ciphersuite: TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
Connecting to example.com... connect() failed, err: 111, Connection refused
Trying ciphersuite: TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
Trying ciphersuite: TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
Trying ciphersuite: TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
Trying ciphersuite: TLS_PSK_WITH_AES_256_CBC_SHA
Trying ciphersuite: TLS_PSK_WITH_AES_128_CBC_SHA256
Trying ciphersuite: TLS_PSK_WITH_AES_128_CCM_8
Trying ciphersuite: TLS_EMPTY_RENEGOTIATIONINFO_SCSV
Trying ciphersuite: TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
Trying ciphersuite: TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
Trying ciphersuite: TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
Ciphersuite support summary for host `example.com`:
TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384: No
TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA: No
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256: No
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA: No
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA: No
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256: No
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA: No
TLS_PSK_WITH_AES_256_CBC_SHA: No
TLS_PSK_WITH_AES_128_CBC_SHA256: No
TLS_PSK_WITH_AES_128_CBC_SHA: No
TLS_PSK_WITH_AES_128_CCM_8: No
TLS_EMPTY_RENEGOTIATIONINFO_SCSV: No
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256: No
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384: No
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256: No
Finished.
    It is great to hear that you got it working. Thank you for providing the update.
    Dejan
  • This continues not to work consistently. Today the same code does not send a TLS Hello and just sends a TPC FIN after the TCP SYN ACK handshaking.
    Is there a way to get more verbose logging for TCP/TLS issues? There is no indication of what is going wrong.
    Is your issue consistently reproducible on the nrf9161-dk?
    Have you made any changes to the default cipher suites sample?
    Have you tried to use another nrf9161-dk board?
    Dejan
  • Yes, it's consistent on the nrf9161. I also have a nRF9151 DK that does not work as well, but I do not have more nRF9161-DKs.
    I am also doing this work in a workspace not in tree.
    This morning, I  "create a new application" select "copy a sample" and select "TLS cipher suite", then add the nRF9161dk build config and build. This fails in the same way (however without modem tracing). All connections are refused.
    Toolchain and SDK are both set to v2.6.1
    Below is the
    [Sec Thread] Secure image initializing!
    TF-M isolation level is: 0x00000001
    Booting TF-M v2.0.0
    *** Booting nRF Connect SDK 3758bcbfa5cd ***
    Finished.
    I've also uploaded the modem trace.
    trace-2024-05-28T12-51-10.831Z.mtrace
    Thank you for additional information and modem trace.
    I have replicated your issue. We will further look into it. I will get back to you with new information, probably by the end of this week.
    Dejan
