We are using nRF5340 DK and the nRF Connect SDK Version 2.6.1.
We are developing a mesh network. Our requirement is the one device can connect to three other devices. Using one connection as a peripheral and up to two connections as a central for mesh connections.
We are using extended advertising.
When the master tries to connect to the slave, it receives a disconnection event with reason 19. However, on the slave side, there are no connection or disconnection events; but the advertising has stopped, and the following hci errors have occurred in the slave side:
<err> bt_hci_core: bt_hci_le_enh_conn_complete: No pending conn for peer FF:F5:55:5A:D6:6A (random)
<err> bt_hci_core: hci_acl: Unable to find conn for handle 6
<wrn> bt_hci_core: bt_hci_host_num_completed_packets: Unable to look up conn with index 0xff
After these errors occur, advertising stopped.
Here I have attached adv start function
struct bt_le_adv_param adv_param ={
.id = BT_ID_DEFAULT,
.sid = setId, /* Supply unique SID when creating advertising set */
.secondary_max_skip = 0U,
.interval_min = ADV_INTERVAL_MIN,
.interval_max = ADV_INTERVAL_MAX,
.peer = NULL,
adv_param.options = (BT_LE_ADV_OPT_EXT_ADV | BT_LE_ADV_OPT_USE_NAME | BT_LE_ADV_OPT_CONNECTABLE |BT_LE_ADV_OPT_ONE_TIME);
/* Create a non-connectable non-scannable advertising set */
err = bt_le_ext_adv_create(&adv_param, NULL, &adv[setId]);
if (err) {
printk("Failed to create advertising set %d (err %d)\n", setId, err);
return err;
/* Set extended advertising data */
err = bt_le_ext_adv_set_data(adv[setId], ad_ext, ARRAY_SIZE(ad_ext), NULL, 0);
if (err) {
printk("Failed to set advertising data for set %d " "(err %d)\n", setId, err);
return err;
/* Start extended advertising set */
err = bt_le_ext_adv_start(adv[setId], BT_LE_EXT_ADV_START_DEFAULT);
if (err) {
printk("Failed to start extended advertising set %d " "(err %d)\n", setId, err);
return err;
1. What could be causing this issue?
2. How can we determine if the advertising is still active?
