NRF52840DK NFC Sample applications not working on Zephyr
I'm trying to setup my NFR52840 DK to act as a NFC tag so that I can read some simple data on my phone via NFC transfer.
I have tried a few NFC sample applications (record_txt & record_launch_app) but I can not get my phone to detect anything. I have tried loading the applications on a couple of NRF52840 DKs and have tried multiple NFC antennas (so I'm pretty sure the hardware is not at fault as at least one of the two boards should work). I have tried a few Android phone apps (Nordic's 'nRF NFC Toolbox' and NXP's 'TagInfo'). I confident that my phones NFC is working okay (as I use it on Android pay and I also have an old hotel security NFC key card that can be read by both apps).
I set the target as the NRF52840 DK when imported the sample code into VS Code editor.  I built the code using a pristine build in Zephyr without any errors or warnings. Lokking at the kconfig GUI, it suggests that the NFC is enabled for the build.
When I flash the device I get the usual messages in the COM terminal window (for the 'record_text' sample it displays:
***Booting nRF SDK 2.5.0 ***
Starting NFC Text Record example
NFC Configuration Done
So the code seems to be executing okay.
When I put my phone over the antenna to read the TAG information nothing happens. LED1 is not illuminated and the phone doe not detect an active TAG.
Please can you give me some ideas of where I might be going wrong or is there a problem with the Zephyr sample applications?
Best regards
Michael
  • Hi Jared,
    Sorry I haven't got back to you earlier as I have been busy on other urgent projects.
    Unfortunately I am still having issues with this. I have downloaded the zip file and extracted the Zephyr.Hex file (117kb) from the Zephyr directory. I have flashed the hex code to Two of my NRf52 DK boards it using the NRF programmer utility.
    Both boards seem to program okay (no reported errors).
    When I use the Nordic NRF NFC tag tool on my phone, neither board is detected as a NFC tag device.
    My phones NFC tag reader seems to be working as it still detect an old NFC hotel room key card (as shown in the picture).
    I tried to open your project in Zephyr to recompile/debug the code but it says that the project does not contain an application source:
    Any ideas as where I could be going wrong? Is there a hardware switch on the NRF52 DK, or if it just a case of plugging in the NFC antenna?
    Kind regards
    Michael
  • Hi Jared,
    Please see my reply below - I'm still looking for a solution. I can't import the project zip contents as an application into Zephyr /VSCode as it says the folder does not contain an application
    You're using a preview development kit. A PDK is an early version of a DK that contains an engineering version of the nRF52840 instead of a release version.
    The PDKs are not supported in NCS,
    Buy a Development Kit,
    regards
    Jared
  • Hi Jared
    Do you think that's what the issue is then? My initial target (planned end product) will use a NRF52833.  I have a DK for this device (BL653 from Laird - BL653 Development Kits - Ezurio | Mouser ). I couldn't get the NFC working on this either - so I then tried to get the NFC example working on the NRF52840 Dev kits I have....
    Can you supply me with a working NFC sample hex code example and project based around the NRF52833 so I can validate it works with this the Larid BL653 hardware ?
    Kind regards
    Michael
    Here is the whole record text sample from NCS v2.5.0 with precompiled hex for nRF52840 and nRF52833. I've tested that they work on the nRF52840 DK and the nRF52833 DK.
    build: nRF52840
    build_1: nRF52833
    regards
    Jared
    record_text.7z
