hello there i want to generate external interrupt from adxl345.can you help me? can we do same like we are using with button??
ok i will try it
can i use above button event handler function i have written above??
this is not working
#include <stdbool.h> #include <string.h> #include "app_button.h" #include "boards.h" #include "app_gpiote.h" #include "app_timer.h"
#define APP_TIMER_PRESCALER 0 // Value of the RTC1 PRESCALER register.
#define APP_TIMER_MAX_TIMERS 1 // Maximum number of simultaneously created timers.
#define APP_TIMER_OP_QUEUE_SIZE 2 // Size of timer operation queues.
#define BUTTON_DEBOUNCE_DELAY 50 // Delay from a GPIOTE event until a button is reported as pushed.
#define APP_GPIOTE_MAX_USERS 1 // Maximum number of users of the GPIOTE handler.
* Handler to be called when button is pushed.
* param[in] pin_no The pin number where the event is genereated
* param[in] button_action Is the button pushed or released
static void button_handler(uint8_t pin_no, uint8_t button_action)
if(button_action == APP_BUTTON_PUSH)
switch(pin_no)
case BUTTON_1:
nrf_gpio_pin_toggle(LED_1);
case BUTTON_2:
nrf_gpio_pin_toggle(LED_2);
case BUTTON_3:
nrf_gpio_pin_toggle(LED_3);
case BUTTON_4:
nrf_gpio_pin_toggle(LED_4);
* Initialize the clock.
void init_clock()
NRF_CLOCK->LFCLKSRC = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
NRF_CLOCK->TASKS_LFCLKSTART = 1;
while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0); // Wait for clock to start
* Initialize all four LEDs on the nRF51 DK.
void init_leds()
nrf_gpio_cfg_output(LED_1);
nrf_gpio_cfg_output(LED_2);
nrf_gpio_cfg_output(LED_3);
nrf_gpio_cfg_output(LED_4);
nrf_gpio_pin_set(LED_1);
nrf_gpio_pin_set(LED_2);
nrf_gpio_pin_set(LED_3);
nrf_gpio_pin_set(LED_4);
* Function for application main entry.
init_leds();
init_clock();
uint32_t err_code;
// Button configuration structure.
static app_button_cfg_t p_button[] = { {BUTTON_1, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_PULLUP, button_handler},
{BUTTON_2, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_PULLUP, button_handler},
{BUTTON_3, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_PULLUP, button_handler},
{BUTTON_4, APP_BUTTON_ACTIVE_LOW, NRF_GPIO_PIN_PULLUP, button_handler}};
// Macro for initializing the application timer module.
// It will handle dimensioning and allocation of the memory buffer required by the timer, making sure that the buffer is correctly aligned. It will also connect the timer module to the scheduler (if specified).
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
// Macro for initializing the GPIOTE module.
// It will handle dimensioning and allocation of the memory buffer required by the module, making sure that the buffer is correctly aligned.
APP_GPIOTE_INIT(APP_GPIOTE_MAX_USERS);
// Initializing the buttons.
err_code = app_button_init(p_button, sizeof(p_button) / sizeof(p_button[0]), BUTTON_DEBOUNCE_DELAY);
// Enabling the buttons.
err_code = app_button_enable();
while(true)
// Do nothing.
i don't know but this code is not working. when i load this code. all LEDS are on. there is no change in LED. if i press button
