little fs directory disappears after having used it for ~20-30 hours
we are working on a nrf52840 based device, which has an external mx25r16 flash (via SPI), having 3 partitions for: secondary-image, mcu-scatch-partition and application-data-partition with litte-fs.
Our device is based on zephyr 2.4 (...knowing that this is quite old).
Recently we added a flash-file based event-logging feature to our application, where various events are logged to an increasing number of event-log-files (located in one log-subdirectory).
These event-log files are published to some cloud service one-by-one about two times per day and are deleted after successful publishing.
The implementation seems to work perfectly, when having a debug build with various LOG_INF()s.
As soon as running in release build we can observe, that on about 40% of our devices are not sending any event-log-files anymore after having run for about 20-30 hours, even while everything worked fine within the time between reboot and the first occurrence of the problem.
When digging into the problem, we found out, that all of the affected devices do not have the logging-subdirectory anymore, which was created on demand during the app-initialization after reboot.
We reviewed our application very carefully and are sure, that there is no line of application-code which might cause the delete of the logging-subdirectory.
Is there known any filesystem / little fs issue, which might cause this kind of problem?
Any help or suggestion is highly appreciated!
Volker
  • Hi Volker,
    Maybe you can try updating the littlefs revision in your west manifest. I'm not sure if this will require other integration changes to Zephyr.
    Vidar Berg said:
    You may try to include a newer revision of littlefs by changing the revision number in the Zephyr manifest followed by a 'west update': https://github.com/nrfconnect/sdk-zephyr/blob/41095df79d11e081ea96d150fbe3dbd93f73af6c/west.yml#L272
    I have not received any suggestions for troubleshooting this yet, but I recommend that you also post this question on Discord (https://discord.com/invite/Ck7jw53nU2 ) to see if someone else has experienced this.
    Vidar
  • LFS_THREADSAFE is redundant because of the implementation in littlefs_fs.c.
    LFS_THREADSAFE enables LOCK/UNLOCK macros & associated API entries in <workspace>/modules/fs/littlefs/lfs.c. However, all of the calls into functions in that module that have locking gated behind LFS_THREADSAFE are wrapped in locking functions in <workspace>/zephyr/subsys/fs/littlsfs_fs.c.
  • Hi Vidar,
    we are still struggeling with this problem.
    I have modified our application code to protect ALL file-access operations with an lock (previously I had only locked the write/delete operations), but the problem still occurs from time to time. Still having problems to reproduce this.
    In the meantime I have made an observation which might help to find a trace to the problem...
    I used a different build-configuration which does not use the external flash (connected via SPI), but uses the nrf52840 internal flash with an application storage partition there.
    The application repeatedly writes to the same file, with an incrementing number of events. This is done by totally replacing the file with new extended content. The write operation is done by single open-/write-/truncate-/close-calls.
    At some point this file is read and transmitted to some cloud service. During this publishing sequence there is repeatedly iterated through all the files of the event-logging directory with reading the oldest file, publishing to the cloud and deleting the file afterwards.
    When using the build-configuration with the internal flash partition, there is published a file-content, which does not contain all events, which must have been written to the file at this point. It seems that there is read a kind of older version of the file. Or there might be some zephyr internal write buffering queue, which does not finally write all data to file, as soon as the file-close operation is called ... and maybe the read-operation is not queued ... leading to a read of some outdated file content. This part of the problem seems to be reproduceable.  When repeating the publishing some time later, the file with the missing events gets published again with all the expected content.
    Do you know any kind of similar zephyr / little-fs issues?
    Volker
  • The previously described observation with the nrf-internal flash might have been caused by the very low number of blocks available in the internal partition.
    When using the zephyr 2.4 it seems that there is not returned any error-code if no more free blocks are available.
    In the meantime I am able to run our application on a zephyr 3.2 version. This version gives a clear indication that there are no more free blocks in the internal flash partition.
    Next step is to test the application on zephyr 3.2 on a bigger number of test-devices ... to see if the directories are disappearing again.
  • Thank you for the update. These are interesting findings. Please let me know if how it goes when testing your application with Zephyr 3.2. If that works, it may be worth reviewing the changelogs again.
