Delay UART initialization in Zephyr
For my application I need the UART TX/RX pins pulled low until I am ready to turn on the UART.  Is there a method in Zephyr to do this?
Currently when Zephyr starts it reads the device tree configuration and initializes the UART driver before main, which then places pull up on the TX/RX pin.  How can I manually control when the UART initialization occurs in my code?
  • trampas said:
    The best solution I can come up with at the moment is making an out of tree driver by copying nordic's uarte driver from zephyr and then renaming to something like 'myuarte'
    This is within what I have thought as well. I were playing around with trying to use an overlay to modify the existing UART device binding, i.e setting it up but not initializing before I call the initialization of the device but I can't quite get it to do this. Maybe the missing ingredient is to do what you say, i.e copy the existing device and creating your own custom variant of the UART that allows for this.
    Even though it's a bit clunky it is also one of the good features with Zephyr i.e allowing for relatively standardized customization of devices and nodes.
    I won't be able to look further into creating a sample for this for a while, but I am fairly confident that your suggestion will work
    Andreas
  • A second idea is to have a config option which removes all the initialization calls.  Then have a means for me to call all the initialization first thing in main.   Then I can not initialize the UART driver.
    The basic idea would be to make the
    z_sys_init_run_level(enum init_level level)
    a weak function.  Then in my project source code I could redefine this function and control everything.
    I've discussed this topic some more with my colleagues and I've concluded that I'm gonna loop back to my first suggestion, i.e to use the overlay or dts to modify the UART instance to have pull-down until you need to configure it differently using gpio_pin_configure_dt().
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/config_and_build/configuring_app/hardware/pin_control.html#pin-control-in-nrf suggests this option atleast, i.e to use different groups for different modes. Create one pinctrl node with pullup and one with bias-disable and then change between these.
    I've not tested this with hardware and verified that it will comply with the spec you're describing, but it's another suggestion that you can investigate if you wish.
    Andreas
  • Unless I misunderstand the suggestion there will be a period of time after the UART is initialized by Zephyr where the pins are high, before the  call to gpio_pin_configure_dt().  Can you please explain how this solution works around this issue?
    They should be sett do pull-down when being initialized when setting this up in the overlay. But this is exactly what we would need to verify by monitoring the relevant GPIOs. Do you have a Power Profiling Kit or any other tool to measure the current available?
    Andreas
