tfm_ns_fault_handler_callback is called when booting
I have a problem where tfm_ns_fault_handler_callback is called when booting the system.
This results in arm_fault and k_sys_fatal_error_handler is called. The reason is 41.
I have upgraded to SDK v2.6.1
Custom board based on nrf9160-SIP
The project is based on a azure iot hub example.
This is the error log:
Please feel free to contact me, if more information is needed.
BR Replay
  • Do you get any logs before the crash happens?
    Yes:
    Can you build the azure IoT hub sample for the DK and run it?
    Yes, I can build and run the sample for DK. With and without debug enabled.
    Can you build the azure IoT hub sample for your custom board and run it?
    Yes, I can build and run the sample for my custom board. With and without debug enabled.
  • Interesting.
    Can you in broad terms list the main feature differences between the Az ure IoT Hub sample and your app?
    Also, try to check TF-M logs and see what they say
  • Okay maybe this not the best way of finding the error.
    But it all started when using 2.2.0 and enabling debug.
    I did go back and tried it again.
    I use mcuboot in the project. This is the differences in .config files when building without vs with debugging enabled.
    Without:
    CONFIG_BOOT_FIH_PROFILE_OFF=y
    # CONFIG_BOOT_FIH_PROFILE_LOW is not set
    With:
    # CONFIG_BOOT_FIH_PROFILE_OFF is not set
    CONFIG_BOOT_FIH_PROFILE_LOW=y
    Here the bootloader just stops.
    The execution stops in
    context_boot_go
    After this check: - BOOT_SWAP_TYPE(state) is
    BOOT_SWAP_TYPE_NONE
    if (BOOT_SWAP_TYPE(state) != BOOT_SWAP_TYPE_NONE)
    Notable differences:
    - Using mcuboot as bootloader.
    - Added FOTA.
    - Using external SPI-NOR flash for image storage.
    BR Replay
    The Azure IoT Hub sample is also using MCUboot by default for the nRF9160DK.
    Replay said:
    - Added FOTA.
    Same for this.
    So that makes me wonder, what did you do to add those?
    Maybe something happended when you were trying to add something that is already enabled.
    This is often something that can fail.
    Try to disable external flash temporarily, to test if it works without.
  • Also, try to check TF-M logs and see what they say
    I'm having a hard time getting the TF-M to log any information.
    My problem is using UART2 for logging, but none of the configs enables it for UART2.
    I have tried with
    CONFIG_TFM_SECURE_UART0,
    CONFIG_TFM_SECURE_UART1,
    CONFIG_TFM_SECURE_UART22
1 2 3 4 5
