Upgrade from s140 to s340
Reference to my old work where I sucessfully upgraded an s140 based application to s340 (ANT supported) application here:
 Replacing s140 with s340 softdevice
Now we have decided to change the bootloader name from simple DfuTarg to Dfu_ABCD_C where ABCD is short for the MAC address of the device to identify individual device.
Before uplaoding the s340 based app, there is an intermediate step where I upload s140 based app but with modified bootloader which allows the s340 based app to be uploaded. The s140 bootloader by default does not allow to firmware to be replaced by an s340 based app. It i son this step where I'm facing problems.
I am using the same bootloader project as before and following the same steps. But the first half of upload is complete (bl+sd), the app.hex does not upload. The nRFConnect app gets stuck after bl+sd upload successful and then gives time out error.
I get the following error message:
I have attached the log file of the bootloader and the package generation command is:
nrfutil pkg generate --bootloader bootloader.hex --bootloader-version 1 --application app.hex --application-version 2 --application-version-string "2.0.0" --hw-version 52 --sd-req 0xB9 --sd-id 0xCA --softdevice s140_nrf52_7.0.1_softdevice.hex --key-file private.pem FW_Hotshot_hv_fv_3_files.zip
Log file:
SN: Is there a way to directly replace an s140 based app to s340 one?
  • There was an error in the linker configuration for the bootloader in SDK 16 that allowed the bootloader code to grow into the MBR param and BL settings page without raising any errors at link time..
    You can replace your flash_placement.xml with the one attached below to ensure that the build will fail if your bootloader becomes too big.
    <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" />
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
        <ProgramSection alignment="4" load="Yes" name=".init" />
        <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
        <ProgramSection alignment="4" load="Yes" name=".text" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".crypto_data" inputsections="*(SORT(.crypto_data*))" address_symbol="__start_crypto_data" end_symbol="__stop_crypto_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".dfu_trans" inputsections="*(SORT(.dfu_trans*))" address_symbol="__start_dfu_trans" end_symbol="__stop_dfu_trans" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".svc_data" inputsections="*(.svc_data*)" address_symbol="__start_svc_data" end_symbol="__stop_svc_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_backends" inputsections="*(SORT(.log_backends*))" address_symbol="__start_log_backends" end_symbol="__stop_log_backends" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data"  inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_filter_data"  inputsections="*(SORT(.log_filter_data*))" runin=".log_filter_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data"  inputsections="*(.fs_data*)" runin=".fs_data_run"/>
        <ProgramSection alignment="4" load="Yes" name=".dtors" />
        <ProgramSection alignment="4" load="Yes" name=".ctors" />
        <ProgramSection alignment="4" load="Yes" name=".rodata" />
        <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
        <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
        <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
        <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".mbr_params_page" address_symbol="__start_mbr_params_page" end_symbol="__stop_mbr_params_page" start = "0x000FE000" size="0x1000" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".bootloader_settings_page" address_symbol="__start_bootloader_settings_page" end_symbol="__stop_bootloader_settings_page" start = "0x000FF000" size="0x1000" />
      </MemorySegment>
      <MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" />
        <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_filter_data_run" address_symbol="__start_log_filter_data" end_symbol="__stop_log_filter_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
        <ProgramSection alignment="4" load="No" name=".fast_run" />
        <ProgramSection alignment="4" load="No" name=".data_run" />
        <ProgramSection alignment="4" load="No" name=".tdata_run" />
        <ProgramSection alignment="4" load="No" name=".bss" />
        <ProgramSection alignment="4" load="No" name=".tbss" />
        <ProgramSection alignment="4" load="No" name=".non_init" />
        <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack"  address_symbol="__StackLimit" end_symbol="__StackTop"/>
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
      <MemorySegment name="uicr_bootloader_start_address" start="0x10001014" size="0x4">
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".uicr_bootloader_start_address" address_symbol="__start_uicr_bootloader_start_address" end_symbol="__stop_uicr_bootloader_start_address" start = "0x10001014" size="0x4" />
      </MemorySegment>
      <MemorySegment name="uicr_mbr_params_page" start="0x10001018" size="0x4">
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".uicr_mbr_params_page" address_symbol="__start_uicr_mbr_params_page" end_symbol="__stop_uicr_mbr_params_page" start = "0x10001018" size="0x4" />
      </MemorySegment>
    </Root>
  • The build does not fail with the flash_placement.xml file you provided
  • Yes, but you were not getting the NRF_DFU_RES_CODE_INSUFFICIENT_RESOURCES error on your last attempt either.
  • The old bootloader advertised with name DfuTarg, the new one is with Dfu_ABCD_X, does this affect anything? Also if I with download the bootloader onto barebone device, it quickly starts advertising. Not sure what is missing here.
