BLE connection processing with nRF5340 Audio
I have a few questions about the sample source of nRF5340 Audio.
1. Where does the connection processing between the Gateway and Headset take place?
2. Where is the BLE bonding information set?
3. Is it possible to rewrite the bonding information?
Thank you in advance.
  • Hi
    Junichi said:
    Which part of the source is responsible for sending the connection request?
    Establishing connections in the central role is handled by the bt_mgmt_scan_for_conn.c module, which can be found in the src\bluetooth\bt_management\scanning\ folder.
    The exact connection establishment is done by calling bt_conn_le_create(..), and if you search for it in the bt_mgmt_scan_for_conn.c file you can find it referenced in three other functions: device_name_check(), csip_found() and bond_connect().
    bond_connect() is called when you receive a directed advertising message, which means you want to connect to a previously bonded device (you should never receive directed advertising messages for non bonded devices). You will also call this function if you have used all the bond slots, since in this case you can not bond any new devices.
    csip_found() is used if you want to connect to a device which is part of a coordinated set, as defined by the Coordinated Set Identification Service (CSIS).
    For all other devices the device_name_check() function will be used to connect.
    Best regards
    Torbjørn
  • Please tell me the following about running nRF5340 Audio with CIS.
    1. Am I correct in thinking that the Headset (Server) sends an advertisement, the Gateway (Client) scans the advertisement and connects?
    2. Where in the source is the key information for connecting with CIS set?
    3. If the device tree of the Headset and Gateway are different, can a connection be made even if only the Headset is built and flashed and only the Gateway is built and flashed using separate scripts?
    4. If I want to create several combinations of Gateway and Headset, how can I change the connection information so that it does not conflict with the others?
  • Hi
    Correct.
    What particular information are you referring to?
    This shouldn't matter. In the default example the scanner will look for a specific advertising name, and if it finds it the connection will be established.
    The easiest way to do this would be to change the advertising name on the peripheral side, and change the target name on the scanner side, to something unique. Then you can control which peripherals and scanners will connect, and which will not.
    Best regards
    Torbjørn
  • hi  ,
    I wanted to understand more on the same information.
    Can i continue in the same thread or should I raise a new ticket?
  • Hi Sanjay,
    Torbjørn unfortunately has left Nordic. Please create a new ticket.
