nrf9160 always recovers when updating applications
I used two samples, application_update and SLM, to test and try updating the app from application_update to SLM. I first downloaded the firmware of application_update v1 version to 9160, and the LED 1 on 9160dk lit up to indicate that the v1 version was being used. Then, I renamed the bin file of SLM to app_2RF9160dk_2.50_v2. bin and uploaded it to the server. Next, I pressed the button 1, 9160dk to download the v2 firmware normally (but in reality, it was SLM). After downloading, I pressed the button 1 again to update the app to SLM, 9160dk also successfully ran SLM,but after restarting, the bootloader restored the firmware to application_update, even though I had already called boot_writd_img_confirmed in the main function of SLM. I also try to call boot_is_img_confirmed in the main function of slm to check whether the firmware is confirmed. The return value is 0, indicating that it is normal.
When I tested with application_update, everything was fine. 9160 can switch between v1 and v2 versions without automatically restoring to the previous version, but replacing v2's bin with SLM is not possible. I don't know which step I overlooked or made wrong?
Thank you.
  • Sorry, I will pay attention to these details in the future.
    EMPTY_0:
      address: 0xc000
      end_address: 0x10000
      placement:
        before:
        - mcuboot_pad
      region: flash_primary
    app:
      address: 0x18000
      end_address: 0x88000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x10000
      end_address: 0x10200
      placement:
        align:
          start: 0x8000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - mcuboot_pad
      - app
      - tfm
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x88000
      end_address: 0x100000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x8000
        align_next: 0x8000
      share_size:
      - mcuboot_primary
    mcuboot_sram:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id003
      - tfm_sram
      region: sram_primary
      span: *id003
    nrf_modem_lib_ctrl:
      address: 0x20008000
      end_address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
    nrf_modem_lib_rx:
      address: 0x2000a568
      end_address: 0x2000c568
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20008000
      orig_span: &id004
      - nrf_modem_lib_ctrl
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id004
    nrf_modem_lib_tx:
      address: 0x200084e8
      end_address: 0x2000a568
      inside:
      - sram_nonsecure
      placement:
        after:
    otp:
      address: 0xff8108
      end_address: 0xff83fc
      region: otp
    sram_nonsecure:
      address: 0x20008000
      end_address: 0x20040000
      orig_span: &id005
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id005
    sram_primary:
      address: 0x2000c568
    sram_secure:
      address: 0x20000000
      orig_span: &id006
      - tfm_sram
      span: *id006
    tfm:
      address: 0x10200
      end_address: 0x18000
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x18000
      orig_span: &id007
      - app
      span: *id007
    tfm_secure:
      address: 0x10000
      orig_span: &id008
      - mcuboot_pad
      - tfm
      span: *id008
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    This is what I copied directly from the app_update sample without any changes. Can you help me check if there are any issues? Thank you.
  • I just tested opening a fresh serial_lte_modem and application_update examples (SDK 2.6.1), and generated the build configurations for nRF9160-dk.
    I copied the the partitions.yml from application_update as pm_static.yml for the slm and did a pristine build. No errors. Below is my pm_static.yml. Seems to be identical to yours, though at lines 36-38 the order is different (Windows and Linux output the items in different orders, but i don't think it matters, compiles with both).
    EMPTY_0:
      address: 0xc000
      placement:
        before:
        - mcuboot_pad
    app:
      address: 0x18000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x10000
      placement:
        align:
          start: 0x8000
        before:
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - tfm
      - app
      - mcuboot_pad
      sharers: 0x1
      span: *id001
      address: 0x10200
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x88000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x8000
        align_next: 0x8000
      share_size:
      - mcuboot_primary
    mcuboot_sram:
      address: 0x20000000
      orig_span: &id003
      - tfm_sram
      span: *id003
    nrf_modem_lib_ctrl:
      address: 0x20008000
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
    nrf_modem_lib_rx:
      address: 0x2000a568
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20008000
      orig_span: &id004
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id004
    nrf_modem_lib_tx:
      address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
    otp:
      address: 0xff8108
      region: otp
    sram_nonsecure:
      address: 0x20008000
      orig_span: &id005
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id005
    sram_primary:
      address: 0x2000c568
    sram_secure:
      address: 0x20000000
      orig_span: &id006
      - tfm_sram
      span: *id006
    tfm:
      address: 0x10200
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x18000
      orig_span: &id007
      - app
      span: *id007
    tfm_secure:
      address: 0x10000
      orig_span: &id008
      - mcuboot_pad
      - tfm
      span: *id008
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    So your error runs deeper than pm_static, there's something strange with your build process. I noticed some weird stuff while fiddling with the lwm2m_client example, Windows-built binaries had something messed up with the flash maps, the example, mcuboot complained that imagemagic was bad and application failed at "boot_write_img_confirmed()" with IO error (-5). The same source file, SDK version and build configuration worked fine on Linux.
    At some point it started working again on windows though I don't know why, the generated .config and partition.yml files were identical.
    I'm unable to replicate it anymore so it's hard to say at this point.
  • Thank you for your testing. When I have time, I will download NCS again to ensure that there are no issues with the SLM itself, and then see if I can find any more clues
  • By the way, are the samples from the same SDK version as you're currently using? For example, you initially generated them with v2.5.0 and have now switched to v2.6.1? Sometimes the libraries have changed and require updates in the source code.
  • I was just starting to learn about 9160 and have been using version 2.6.1 since the beginning
