Encrypted FW update with MCUboot fails.
I'm having trouble making encrypted FW update with MCUboot work in NCS 2.5.0. There are no issues with update of signed but not encrypted FW. But when encrypted FW is uploaded, it gets rejected. It turned out that after uploading encrypted FW file to secondary slot, MCUboot verifies it by checking if reset address of new FW is within address range of primary slot (where the new FW needs to be copied to). Code from boot_validated_swap_type() function in \ncs\v2.5.0\bootloader\mcuboot\boot\bootutil\src\loader.c :
        rc = flash_area_read(secondary_fa, hdr->ih_hdr_size +
                             sizeof(uint32_t), &reset_addr,
                             sizeof(reset_addr));
            /* Check start and end of primary slot for current image */
            if (reset_addr < primary_fa->fa_off) {
                return BOOT_SWAP_TYPE_NONE;
            } else if (reset_addr > (primary_fa->fa_off + primary_fa->fa_size)) {
Reset address off new FW is taken from payload part of update file. This part of file is encrypted. No decryption is done at this step. So it depends only on luck if encrypted address falls within rages of primary slot. In my case it does not. If I fake reset address before this check is done, everything works fine: new FW is successfully decrypted and copied to primary slot.
if (primary_fa->fa_off == 0x31000) reset_addr = primary_fa->fa_off;
Is this a bug in MCUboot part of NCS or am I missing something? Do you have any suggestions how to overcome this issue without modifying code of SDK?
    The statement I made in the linked thread is still true: "Encrypted DFU is feature we do not officially support in our SDK, even though it is made available through the mcuboot project." But as demonstrated by the sample I provided in  Using MCUBoot with nRF5340 it is possible to enable encrypted dfu if you configure the bootloader for simultaneously DFU of app and netcore.
    I am trying to update my device with an encrypted firmware, using dual stage bootloader configuration. I think that my problem is the same as the one described by OP, but I don't understand if there's actually a way to perform encrypted updates or not. If I try to send the update image via mcumgr, and then reboot the device, MCUBoot never starts the swap process but neither logs any error. If I try to use the only signed version of the update everything works as expected.
    Is there any way around this, since encrypted image support is also stated in official ncs sdk documentation?
