nRF52832 DK Programmer / USB?
I got a brand new nRF52832 DK today and wanted to program it but the USB is not recognized at all therefore the nRF Programmer shows no programming option.
I connected the board, switched it on while pressing the reset button. Programming LED is blinking and if I press Buttons 1 - 4 the relating LED shows up.
"nrfjprog --ids" is not showing anything at all.
Other devices such as "nRF52840 Dongle" and "Thingy:53" are working fine on the same PC.
Could you tell me what to do in order to fix this behaviour?
Many thanks in advance.
Regards, Andreas
  • The J-Link will be there next week hopefully. I used various USB-Cabels such as my Jabra-Cable which works fine as data cable with my Jabra. So this should not be the problem. Those cables work also with older mobile phones on the same PC. I am confused because there is no USB-Detection at all.
    One Step further: I have managed to get the bootloader. For some reasons I have not seen this before. This actually is available right after switching on and holding the Reset-Button. It vanishes after some time...
    So it might make sense to flash the bootloader again...
  • Thanks for the additional information. The LED will blink more rapidly when there is a communication issue. Please try to drag&drop the J-link binary to the BOOTLOADER drive as Turbo suggested. The binary can be downloaded at https://www.nordicsemi.com/Products/Development-hardware/nRF52-DK/Download?lang=en#infotabs.
  • I guess this was the issue - for some reason the bootloader was messed up.
    Looks now like this
    nRF Programmer is now also able to detect the device.
    So I guess the issue is solved.
    To sum the solution up:
    1. Need to install Segger JLink Drivers > V7.94e and select "Install legacy USB Driver for J-Link" and uninstall the old one
    2. Reboot
    3. Switch DK-Board on and hold Reset-Switch
    4. Immediately check for the Bootloader-Drive
    5. Drag and Drop https://nsscprodmedia.blob.core.windows.net/prod/software-and-other-downloads/dev-kits/nrf5x-dk-files/j-link-ob-sam3u128-v2-nordicsemi-170724.bin to the bootloader drive
    6. Switch DK board off and on
    7. Check that COM-Port can be seen in device manager
    8. Check availability in nRF Programmer
  • Thanks for the update. I'm glad to hear that it worked. Normally, it should never be neccessary to enter bootloader mode on the DK.
