SoftDevice Controller ASSERT: 53, 296
Hi!
Can you please help me identify what is causing this issue and/or provide more info about this:
[00:04:23.038,330] \033[1;31m<err> bt_sdc_hci_driver: SoftDevice Controller ASSERT: 53, 296\033[0m
[00:04:57.431,335] \033[1;31m<err> os: ***** HARD FAULT *****\033[0m
[00:04:57.431,335] \033[1;31m<err> os:   Fault escalation (see below)\033[0m
[00:04:57.431,365] \033[1;31m<err> os: ARCH_EXCEPT with reason 3
\033[0m
[00:04:57.431,365] \033[1;31m<err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x0001981b\033[0m
[00:04:57.431,396] \033[1;31m<err> os: r3/a4:  0x00000000 r12/ip:  0x20000ab0 r14/lr:  0xffffffff\033[0m
[00:04:57.431,396] \033[1;31m<err> os:  xpsr:  0x41000011\033[0m
[00:04:57.431,396] \033[1;31m<err> os: r4/v1:  0x20015c70  r5/v2:  0x0003370d  r6/v3:  0x0000000a\033[0m
[00:04:57.431,427] \033[1;31m<err> os: r7/v4:  0x20015c70  r8/v5:  0x20001944  r9/v6:  0x2000e204\033[0m
[00:04:57.431,427] \033[1;31m<err> os: r10/v7: 0x200008bc  r11/v8: 0x00000000    psp:  0x20015f40\033[0m
[00:04:57.431,457] \033[1;31m<err> os: EXC_RETURN: 0xfffffff1\033[0m
[00:04:57.431,457] \033[1;31m<err> os: Faulting instruction address (r15/pc): 0x00033744\033[0m
[00:04:57.431,488] \033[1;31m<err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0\033[0m
[00:04:57.431,518] \033[1;31m<err> os: Fault during interrupt handling
\033[0m
[00:04:57.431,549] \033[1;31m<err> os: Current thread: 0x2000ae30 (unknown)\033[0m
[00:05:09.972,747] \033[1;31m<err> fatal_error: Resetting system\033[0m
When this happens it is in the process of uploading a new fw thru mcumgr image group, upload command.
I haven't been able to fully verify this but I think this affected by updating to SDK 2.6.0 (from 2.4.0).
That code part is unchanged before and after the SDK update except that "zcbor_new_decode_state" had two new parameter which we have set to NULL and 0 (after comparing how some examples had changed between sdk versions).
BR,
Mårten
  • Hello Mårten,
    Let me get this straight. This is the central application that is supposed to upload new FW to a peripheral, right? So I would need a peripheral device with an MCUBOOT bootloader running with this? Does the standard smp_svr sample work? Or does it need to be something special?
    BR,
    Edvin
  • Hi!
    yes that is true.
    We set the advertise parameters as follows and call bt_le_ext_adv_create:
    static const uint32_t ADV_OPTS = (BT_LE_ADV_OPT_CONNECTABLE | BT_LE_ADV_OPT_EXT_ADV |
                                      BT_LE_ADV_OPT_CODED | BT_LE_ADV_OPT_USE_IDENTITY |
                                      BT_LE_ADV_OPT_ONE_TIME);
    static struct bt_le_adv_param adv_param = BT_LE_ADV_PARAM_INIT(ADV_OPTS,
        BT_GAP_ADV_FAST_INT_MIN_2,
        BT_GAP_ADV_FAST_INT_MAX_2,
        NULL);
    And when a connection is made they are updated using bt_le_ext_adv_update_param to the following:
    static const uint32_t ADV_DURING_CON_OPTS = (BT_LE_ADV_OPT_EXT_ADV | BT_LE_ADV_OPT_CODED |
                                                 BT_LE_ADV_OPT_USE_IDENTITY);
    static struct bt_le_adv_param adv_conn_param = BT_LE_ADV_PARAM_INIT(ADV_DURING_CON_OPTS,
        NULL);
    But other than that I think the smp_svr example should work.
    I will look into providing you with the peripherial side as well.
    BR,
    Mårten
  • Hi again!
    I have now created a fw for the peripheral side as well.
    Also suitable to link inas the fw binary to upload in the central build
    I have also tested that I can reproduce the issue using these firmwares
    At the moment the central is configured with RTT loggin so the crash dump can be viewed.
    I did not have a dk available to test these on but by disabling various external signals as can be seen in the overlay file I was able to run it on our custom hardware building for nrf52840dk_nrd52840.
    BR,
    Mårten
    nrf-reproducer-peripheral.zip
  • Thank you! That is very helpful, and speeds things up a bit! I am sorry for getting back so late. I will try to run it tomorrow, to replicate the issue. Once that is done, it is a lot easier to either pinpoint, or forward the question to the developers, if they can reproduce it themselves.
    You will hear from me tomorrow.
    Edvin
  • Hi!
    Any updates on this issue?
    Have you been able to reproduce it?
    BR,
    Mårten
