Direction Finding Project: Central and Peripheral Integration
Now I am using the https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bluetooth/direction_finding_central/README.html and https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bluetooth/direction_finding_peripheral/README.html for a direction finding project.
I am using the nRF52833DK and an antenna array designed by Nordic. The SDK I used is nRF Connect SDK v2.2.0.
Here I have an uncommon requirement: each of my devices needs to act as both a central and a peripheral.
For example, a device with a single antenna will act as a central to collect the CTE for AoD estimation and as a peripheral to transmit the CTE for AoA estimation. Conversely, a device with an antenna array will act as a central to collect the CTE for AoA estimation and as a peripheral to transmit the CTE for AoD estimation.
Yes, I admit this is not common in direction finding, but it is actually the core function of my project.
Firstly, I concat the two prj.conf, two nrf52833dk_nrf52833.conf, the overlay-aoa.conf the and overlay-aod.conf.
Now my central and peripheral is using the same prj.conf and nrf52833dk_nrf52833.conf. I added a variable AoA_AoD_Setting to control whether the estimation value is AoA or AoD, so I no longer need overlay-aoa.conf and overlay-aod.conf.
I have tested this setup and can obtain the correct AoA or AoD separately based on the AoA_AoD_Setting in main.c.
Next, I need to combine the main.c of the central and the main.c of the peripheral, and rewrite the main function to switch between AoA and AoD modes, as well as between central and peripheral modes.
Here let's focus on the antenna array side.
1) initialize the bluetooth as a RX.
while(true)
 2) Start scan(), and wait for a connection to calculate the AoA.
 3) Once a connection is established, call enable_cte_request and wait for CTE collection.
 4) Disconnect the connection and call bt_le_scan_stop() when the CTE collection complated In cte_recv_cb.
 5) The AoA is complated, call bt_le_adv_start() and request for a connection.
 6) When the connection is established, call enable_cte_response(conn) and start transmitting the CTE packet.
 7) Wait for the disconnection of the peer device once it completes the CTE collection for AoD estimation.
 8) Call bt_le_adv_stop().
end while
The single antenna side follows a similar process, but it first acts as a TX to transmit the CTE packet for AoA, and then switches to RX to collect the CTE packet for AoD.
Now the while loop above reaches step 6) successfully (or at least it appears to). I can get the correct AoA value from the CTE collected in step 3) and 4). However, when I switch to TX mode, the connection can't be estiblished. The TX(antenna array) just transmit all the time, and the RX(single antenna side) just scan all the time.
So why can't the connection be estiblished?
For switch modes, I just use the following functions:
bt_le_scan_start();
enable_cte_reqest();
bt_le_scan_stop();
bt_le_adv_start();
enable_cte_response(conn);
bt_le_adv_stop();
I guess there are two things I need to understand:
A) In enable_cte_request(), the functions bt_df_conn_cte_rx_enable() and bt_df_conn_cte_req_enable() set certain settings. So, when I call enable_cte_response(), do I need to drop or cancel the settings made by bt_df_conn_cte_rx_enable() and bt_df_conn_cte_req_enable()?
B) I know that Bluetooth can only be initialized once in Zephyr. Is there any operation similar to "drop", allowing me to call bt_enable() multiple times?
Thanks!
  • Hello, Thank you for providing the links, I also noticed that Nordic does not produce their own antenna arrays, so I want to make a cutsom antenna array board and want to know how the firmware is actually implemented for the positioning using multiple boards.
    I am relatively new to bluetooth development and AoA/AoD so just looking to learn more.
    Thanks once again,
    Darsh.
    We support the entire Bluetooth part of the puzzle, with the SoC and the Bluetooth Controller and Host fully implemented.
    We do not provide antenna array and corresponding algorithm. Building on top of our solutions, these are the current options for completing the picture:
    • Make your own antenna array and algorithms
    • Buy an existing antenna array design, such as the ISP 1907-AOA-DK, and build your own algorithms
    • Buy a package with both antenna array and algorithms, such as the offerings from u-Blox
    Terje
