I'm trying to setup a I2S module by referring the I2S module given in the nrf5340-audio application. This is my audio_i2s.c
file.
/* * Copyright (c) 2021, PACKETCRAFT, INC. * * SPDX-License-Identifier: LicenseRef-PCFT */ #include "audio_i2s.h" #include <zephyr/kernel.h> #include <zephyr/device.h> #include <zephyr/drivers/pinctrl.h> #include <nrfx_i2s.h> #include <nrfx_clock.h> #include <audio_module/audio_module.h> #define I2S_NL DT_NODELABEL(i2s0) #define HFCLKAUDIO_12_288_MHZ 0x9BAE enum audio_i2s_state { AUDIO_I2S_STATE_UNINIT, AUDIO_I2S_STATE_IDLE, AUDIO_I2S_STATE_STARTED, }; static enum audio_i2s_state state = AUDIO_I2S_STATE_UNINIT; PINCTRL_DT_DEFINE(I2S_NL); #if CONFIG_AUDIO_SAMPLE_RATE_16000_HZ #define CONFIG_AUDIO_RATIO NRF_I2S_RATIO_384X #elif CONFIG_AUDIO_SAMPLE_RATE_24000_HZ #define CONFIG_AUDIO_RATIO NRF_I2S_RATIO_256X #elif CONFIG_AUDIO_SAMPLE_RATE_48000_HZ #define CONFIG_AUDIO_RATIO NRF_I2S_RATIO_128X #else #error "Current AUDIO_SAMPLE_RATE_HZ setting not supported" #endif static nrfx_i2s_t i2s_inst = NRFX_I2S_INSTANCE(0); static nrfx_i2s_config_t cfg = { /* Pins are configured by pinctrl. */ .skip_gpio_cfg = true, .skip_psel_cfg = true, .irq_priority = DT_IRQ(I2S_NL, priority), .mode = NRF_I2S_MODE_MASTER, .format = NRF_I2S_FORMAT_I2S, .alignment = NRF_I2S_ALIGN_LEFT, .ratio = CONFIG_AUDIO_RATIO, .mck_setup = 0x66666000, #if (CONFIG_AUDIO_BIT_DEPTH_16) .sample_width = NRF_I2S_SWIDTH_16BIT, #elif (CONFIG_AUDIO_BIT_DEPTH_32) .sample_width = NRF_I2S_SWIDTH_32BIT, #else #error Invalid bit depth selected #endif /* (CONFIG_AUDIO_BIT_DEPTH_16) */ .channels = NRF_I2S_CHANNELS_STEREO, .clksrc = NRF_I2S_CLKSRC_ACLK, .enable_bypass = false, }; static i2s_blk_comp_callback_t i2s_blk_comp_callback; static void i2s_comp_handler(nrfx_i2s_buffers_t const *released_bufs, uint32_t status) { uint32_t frame_start_ts = audio_sync_timer_capture_get(); if ((status == NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED) && released_bufs && i2s_blk_comp_callback && (released_bufs->p_rx_buffer || released_bufs->p_tx_buffer)) { i2s_blk_comp_callback(frame_start_ts, released_bufs->p_rx_buffer, released_bufs->p_tx_buffer); } } void audio_i2s_set_next_buf(const uint8_t *tx_buf, uint32_t *rx_buf) { __ASSERT_NO_MSG(state == AUDIO_I2S_STATE_STARTED); if (IS_ENABLED(CONFIG_STREAM_BIDIRECTIONAL) || (CONFIG_AUDIO_DEV == GATEWAY)) { __ASSERT_NO_MSG(rx_buf != NULL); } if (IS_ENABLED(CONFIG_STREAM_BIDIRECTIONAL) || (CONFIG_AUDIO_DEV == HEADSET)) { __ASSERT_NO_MSG(tx_buf != NULL); } const nrfx_i2s_buffers_t i2s_buf = { .p_rx_buffer = rx_buf, .p_tx_buffer = (uint32_t *)tx_buf }; nrfx_err_t ret; ret = nrfx_i2s_next_buffers_set(&i2s_inst, &i2s_buf); __ASSERT_NO_MSG(ret == NRFX_SUCCESS); } void audio_i2s_start(const uint8_t *tx_buf, uint32_t *rx_buf) { __ASSERT_NO_MSG(state == AUDIO_I2S_STATE_IDLE); if (IS_ENABLED(CONFIG_STREAM_BIDIRECTIONAL) || (CONFIG_AUDIO_DEV == GATEWAY)) { __ASSERT_NO_MSG(rx_buf != NULL); } if (IS_ENABLED(CONFIG_STREAM_BIDIRECTIONAL) || (CONFIG_AUDIO_DEV == HEADSET)) { __ASSERT_NO_MSG(tx_buf != NULL); } const nrfx_i2s_buffers_t i2s_buf = { .p_rx_buffer = rx_buf, .p_tx_buffer = (uint32_t *)tx_buf }; nrfx_err_t ret; /* Buffer size in 32-bit words */ ret = nrfx_i2s_start(&i2s_inst, &i2s_buf, I2S_SAMPLES_NUM, 0); __ASSERT_NO_MSG(ret == NRFX_SUCCESS); state = AUDIO_I2S_STATE_STARTED; } void audio_i2s_stop(void) { __ASSERT_NO_MSG(state == AUDIO_I2S_STATE_STARTED); nrfx_i2s_stop(&i2s_inst); state = AUDIO_I2S_STATE_IDLE; } void audio_i2s_blk_comp_cb_register(i2s_blk_comp_callback_t blk_comp_callback) { i2s_blk_comp_callback = blk_comp_callback; } void audio_i2s_init(void) { __ASSERT_NO_MSG(state == AUDIO_I2S_STATE_UNINIT); nrfx_err_t ret; nrfx_clock_hfclkaudio_config_set(HFCLKAUDIO_12_288_MHZ); NRF_CLOCK->TASKS_HFCLKAUDIOSTART = 1; /* Wait for ACLK to start */ while (!NRF_CLOCK_EVENT_HFCLKAUDIOSTARTED) { k_sleep(K_MSEC(1)); } ret = pinctrl_apply_state(PINCTRL_DT_DEV_CONFIG_GET(I2S_NL), PINCTRL_STATE_DEFAULT); __ASSERT_NO_MSG(ret == 0); IRQ_CONNECT(DT_IRQN(I2S_NL), DT_IRQ(I2S_NL, priority), nrfx_isr, nrfx_i2s_0_irq_handler, 0); irq_enable(DT_IRQN(I2S_NL)); ret = nrfx_i2s_init(&i2s_inst, &cfg, i2s_comp_handler); __ASSERT_NO_MSG(ret == NRFX_SUCCESS); state = AUDIO_I2S_STATE_IDLE; }
Now when I'm building this, I'm getting this weird error
gen_isr_tables.py: error: multiple registrations at table_index 40 for irq 40 (0x28)
Existing handler 0x22407, new handler 0x22407
Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
I went through the Global Search to find if there are multiple instances of IRQ_CONNECT, but I found only 1 instance that is present in the audio_i2s_init() function in the code file which I have mentioned above. What could possibly cause this error and how do I fix it?
Also is there any other simpler way of setting up I2S service with both the CS47L63 Codec and the LC3 Codec?
