Bluetooth HCI lpuart issue - nRF9160 + nRF52840
I'm using nRF9160 as a HCI host and nRF52840 as HCI controller (nRF52840 config is based on HCI lpuart example). My application receives data over Bluetooth using notifications. To handle the notifications data I use a message queue and a workqueue (to avoid handling it from a notification callback which is executed from a bt_rx_thread). It has to be able to receive ~50kB of data. Sometimes it works without any problem but sometimes I get the following information in logs:
bt_hci_core: opcode 0x0002 pool id 3 pool 0x20020958 != &hci_cmd_pool 0x200209b0
lpuart: Tx timeout
or
lpuart: req pin low when expected high
lpuart: Empty receiver state:4
bt_hci_core: opcode 0x0000 pool id 3 pool 0x20020958 != &hci_cmd_pool 0x200209b0
bt_hci_core: Unexpected HOST_NUM_COMPLETED_PACKETS (status 0x0c)
or
bt_driver: Not enough space in buffer 1275/255
After each of above logs the bluetooth becomes unresponsive. Using sniffer I found out that the connection is alive and it sends Empty PDU packets. Only reseting the device helps in such situation.
The higher baudrate of HCI, the issue occurs more frequently. When I try to use baud rate of 1000000, it fails almost everytime.
Setup:
Custom board with nRF9160 and nRF52840
NCS v2.6.1
nRF9160 BT configuration:
CONFIG_BT=y
CONFIG_BT_H4=y
CONFIG_BT_WAIT_NOP=y
CONFIG_BT_HCI=y
CONFIG_BT_CTLR=n
CONFIG_BT_CENTRAL=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=1
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT=y
CONFIG_BT_HCI_TX_STACK_SIZE=2048
CONFIG_BT_RX_STACK_SIZE=4096
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_HEAP_MEM_POOL_SIZE=8192
nRF52840 BT configuration:
CONFIG_BT=y
CONFIG_BT_CTLR=y
CONFIG_BT_HCI_RAW=y
CONFIG_BT_HCI_RAW_H4=y
CONFIG_BT_HCI_RAW_H4_ENABLE=y
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255
Also, I would like to mention another issue I encountered.
If I detect some error (I don't mean the error with HCI mentioned above but some kind of error in my functions that has to be handled) while downloading ~50kB of data using notifications,
I would like to drop connection. To do it, I execute bt_conn_disconnect in a workqueue that handles notification data. Using sniffer, I can see that the disconnect command goes to the peripheral device and the connection ends. The problem is that I do not receive a disconnected callback.
When I disconnect after receiving all the data, the disconnected callback is executed.
Any help would be greatly appreciated.
  • I have a Thingy91 and facing the same errors
    <wrn> lpuart: req pin low when expected high
    [00:00:00.265,869] <err> lpuart: Empty receiver state:4
    and constant crashes even by using the lte_ble_gateway sample + hci_lpuart. From the crashes there seems to be some sort of timeout in the hci communication with the 52840
  • I am experiencing the same issues when getting a quite intense stream of notifications from peripheral.
  • Hi
    Can you share how to implement hadware flow control?
    I have this in my overlay file:
    chosen {
    zephyr,bt-uart=&uart1;
    &uart1 {
    current-speed = <1000000>;
    status = "okay";
    hw-flow-control;
    pinctrl-0 = <&uart1_default_alt>;
    pinctrl-1 = <&uart1_sleep_alt>;
    // lpuart: nrf-sw-lpuart {
    // compatible = "nordic,nrf-sw-lpuart";
    // status = "okay";
    // req-pin = <24>;
    // rdy-pin = <25>;
    and this in my thingy conf file:
    # CONFIG_NRF_SW_LPUART=y
    # CONFIG_NRF_SW_LPUART_INT_DRIVEN=y
    # CONFIG_UART_1_ASYNC=y
    CONFIG_UART_1_INTERRUPT_DRIVEN=y
    # CONFIG_UART_1_NRF_HW_ASYNC=y
    # CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
    I'm getting an assert though:
    ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:333
            command opcode 0x0c03 timeout with err -11
    Assotiated line in hci_core is this:
    err = k_sem_take(&sync_sem, HCI_CMD_TIMEOUT);
    BT_ASSERT_MSG(err == 0, "command opcode 0x%04x timeout with err %d", opcode, err);
