i2s peripheral not generating pointer update events when MCUBoot enabled on nrf5340 device
As soon as we enable CONFIG_BOOTLOADER_MCUBOOT and have an operational MCUBoot image, we noticed that our audio pipeline is no longer working for our i2s omni-microphone. Specifically we fail to allocate buffers. When we pull out the bootloader configuration it works again. This is on 2.6.1 of the SDK / toolchain. After days of debugging this is what we found:
The reason for the audio errors is that the I2S peripheral is not generating pointer update events, so the ISR is not refreshing buffers and our audio thread times out after 2 seconds. We have some PDM mics as well which do not have an issue on a similar audio processing stack; it's limited to I2S. And we don't suspect anything with the I2S mic itself, as the nRF I2S peripheral generates the clocks - even if there was no mic connected, things would still run. Looked extensively at the driver changes in 2.6.1 and nothing stood out. Copied over the 2.5.2 I2S drivers into 2.6.1 and that didn't help.
Also copied the nrfx drivers from 2.6.1 into 2.5.2, and used the pre-2.6.1 FW, and that still worked.
Messed around in the debugger on the working and non-working builds and we can reproduce the behavior by poking registers, so I'm not suspecting runtime issues (though could possibly be init). We backed out bootloader, staying with SDK 2.6.1, and things work again.
But we need to get MCUBoot and the audio pipeline working. Please we are so close. So here are some questions:
  • Could this be related to enabling the internal 32 khz clock RC for mcuboot? (ie CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC and CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM)
  • Are there any hardware inits in bootloader, specifically with clocks or voltage, that may affect the running image?
Here are some things we're thinking of trying next but its a bit of a rabbit hole:
  • I don't think the symptoms indicate any pin conflicts, but check if there are any leftover configs in bootloader.
  • Is it possible to enable bootloader in 2.5.2 with older FW, just for comparison?
  • Can you hack bootloader to skip most of its operations and just transfer to the main image?
  • Is NET processor being initialized, and causing some side effect?
  • Leftover flash, or some memory layout issue which is causing second-order effects?
For reference of our configuration files, you can see here:  nRF5340 Custom Board App not booting when enabling CONFIG_BOOTLOADER_MCUBOOT
  • We use P0.19-21 for the i2s lines in our app but don't have a specified overlay for our bootloader (besides button to enter serial recovery). So I guess we would use the bootloader's default pinout? Do these correspond with the lines used for UARTE?
    That might resolve the issue, but it would require verification through testing
    But since you're using a custom board it will depend your board files
    Andreas
  • I tried cherrypicking the fix mentioned above (https://github.com/nrfconnect/sdk-mcuboot/pull/303) in my local v2.6.1 sdk but it did not resolve the issue.
    So we have a nrf5340_cpuapp_common-pinctrl.dtsi file that we use mainly to build for devkit. This contains a uart definition that seems to reflect the uart configuration you linked:
    &pinctrl {
    	uart0_default: uart0_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, 20)>,
    				<NRF_PSEL(UART_RTS, 0, 19)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 0, 22)>,
    				<NRF_PSEL(UART_CTS, 0, 21)>;
    			bias-pull-up;
    In our custom board overlay we reconfigure these pins to be i2s:
    /delete-node/ &{/pin-controller/uart0_default/group1/};
    /delete-node/ &{/pin-controller/uart0_default/group2/};
    /delete-node/ &{/pin-controller/uart0_sleep/group1/};
    &uart0_default {
        group1 {
            psels = <NRF_PSEL(UART_RX, 0, 9)>, <NRF_PSEL(UART_TX, 0, 11)>;
    //  Pin configurations for PDM device
    &pinctrl {
        pdm0_default_alt: pdm0_default_alt {
            group1 {
                psels = <NRF_PSEL(PDM_CLK, 0, 4)>,
                        <NRF_PSEL(PDM_DIN, 0, 5)>;
        i2s0_default: i2s0_default {
            group1 {
                psels = <NRF_PSEL(I2S_LRCK_M, 0, 20)>,
                        <NRF_PSEL(I2S_SDIN, 0, 21)>,
                        <NRF_PSEL(I2S_SCK_M, 0, 19)>;
    This seems to work for our app but I think mcuboot only picks up the common dts configurations and not the custom board overlays? Why is that even though it is built together with the app?
    Any other suggestions on why i2s is not functioning after entering app from serial recovery mode?
  •   I think I want mcuboot to just use the same overlay as my main app so that pins do not conflict. Is that possible? If so, how can I do it?
    Yes, this is correct. You will have to add a child image overlay file for any multi-image build to ensure that all parts uses the same configuration.
    To ensure that MCUboot uses the same overlay as the application in NCS, you need to provide overlays for a child image (e.g. MCUboot) using its own overlay file. The build system automatically applies any device tree overlay located in the child_image folder provided you follow the schema (e.g. <project_root>/child_image/mcuboot/boards/nrf52840dk_nrf52840.overlay).
    For example, if you have specific configurations for your application, you should put the overlay of your board inside the boards folder. This way, the relevant parameters to build MCUboot correctly to work with the chosen application will be passed automatically to the MCUboot build system so they are in concert with each other.
    Also, make sure to set in your parent image conf CONFIG_BOOTLOADER_MCUBOOT=y to signify it will be chain loaded by MCUboot.
    For more information regarding multi-image builds, you can refer to the documentation:
    There are two options that could cause this, the first is that not all images are not using the same overlay, and the second is that you're building for a board that has a slightly different name than the overlays name.
    The current build system chooses devicetree files based on the build targets name, meaning that if you build for for instance "nrf52840dk_nrf52840" it will use the "nrf52840dk_nrf52840.dts" from zephyr/boards as well as any "nrf52840dk_nrf52840.overlay" in your project folder. If your build target is "nrf5248dk_nrf52840_custom", it will look for any overlays that ends with "_custom" in your project folder, meaning that if you have a "nrf52840dk_nrf52840.overlay" will be ignored since it is looking for the overlay ending with "_custom.overlay" (unless you specify this as a Kconfig fragment when building).
    To summarize: Your overlays needs to have the same naming convention as your board/build target.
    Andreas
