Hello!
I am trying to collect data from an nRF52832 device which works as a peripheral to another device nRF52832 which operates as both Central and Peripheral.
Description:
I connect with my phone to the Central-Peripheral Device with nRF Connect App. I write a command in a Write Characteristic, which initiates the scanning process.
The device starts scanning and successfully connects and discoveres the Service of the other device-peripheral. The Service has only two characteristics, 0x0001 Write, 0x0002 Notify.
The device-central writes/subscribes in the 0x0001 Write characteristic to activate the sensor from which data will be sent. The command is a specific uint8_t array[14].
Then it also enables the cccd command for the Notify 0x0002 characteristic from which it will receive the data, which are of size uint8_t arr [18] .
Issue:
When I connect from nRF Connect App directly to the device-peripheral and follow the same steps (subscribe with the same data on 0x0001 and enable nitifications on 0x0002) I successfully receive data on the latter characteristic.
When the device-central executes the steps, nothing is received, no BLE_GATTC_EVT_HVX event is even triggered.
Here is the logs from the debugger:
where you can see that in the yellow highlighted lines I get the success of bothGATTC procedures (first write the 14 bytes array and then enable the CCCD) but after that nothing happens, no data are received and for some reason phy update events are triggered.
1. I noticed that in nRF Connect App, as soon as I write the 14 bytes array in 0x0001 characteristic, the phys are updated to 2MBPS. I did this also in my code but nothing changed. (It was normally set as AUTO).
2. I also changed the NRF_BLE_GQ_GATTS_HVX_MAX_DATA_LEN from 16 to 18 in sdk_config.h, but didn't help.
Below some parts of my code:
// <e> NRF_BLE_GQ_ENABLED - nrf_ble_gq - BLE GATT Queue Module //========================================================== #ifndef NRF_BLE_GQ_ENABLED #define NRF_BLE_GQ_ENABLED 1 #endif // <o> NRF_BLE_GQ_DATAPOOL_ELEMENT_SIZE - Default size of a single element in the pool of memory objects. #ifndef NRF_BLE_GQ_DATAPOOL_ELEMENT_SIZE #define NRF_BLE_GQ_DATAPOOL_ELEMENT_SIZE 20 #endif // <o> NRF_BLE_GQ_DATAPOOL_ELEMENT_COUNT - Default number of elements in the pool of memory objects. #ifndef NRF_BLE_GQ_DATAPOOL_ELEMENT_COUNT #define NRF_BLE_GQ_DATAPOOL_ELEMENT_COUNT 8 #endif // <o> NRF_BLE_GQ_GATTC_WRITE_MAX_DATA_LEN - Maximal size of the data inside GATTC write request (in bytes). #ifndef NRF_BLE_GQ_GATTC_WRITE_MAX_DATA_LEN #define NRF_BLE_GQ_GATTC_WRITE_MAX_DATA_LEN 16 #endif // <o> NRF_BLE_GQ_GATTS_HVX_MAX_DATA_LEN - Maximal size of the data inside GATTC notification or indication request (in bytes). #ifndef NRF_BLE_GQ_GATTS_HVX_MAX_DATA_LEN #define NRF_BLE_GQ_GATTS_HVX_MAX_DATA_LEN 18 #endif
sdk_config.h
uint32_t ble_scol_c_adj_notif_enable(ble_scol_c_t * p_ble_scol_c, bool enable)
VERIFY_PARAM_NOT_NULL(p_ble_scol_c);
if (p_ble_scol_c->conn_handle == BLE_CONN_HANDLE_INVALID)
NRF_LOG_INFO("Configuring CCCD. CCCD Handle = %d, Connection Handle = %d",
p_ble_scol_c->peer_scol_db.live_meas_cccd_handle,
p_ble_scol_c->conn_handle);
nrf_ble_gq_req_t cccd_req;
uint16_t cccd_val = enable ? BLE_GATT_HVX_NOTIFICATION : 0;
uint8_t cccd[BLE_CCCD_VALUE_LEN];
cccd[0] = LSB_16(cccd_val);
cccd[1] = MSB_16(cccd_val);
memset(&cccd_req, 0, sizeof(cccd_req));
cccd_req.type = NRF_BLE_GQ_REQ_GATTC_WRITE;
cccd_req.error_handler.cb = gatt_error_handler;
cccd_req.error_handler.p_ctx = p_ble_scol_c;
cccd_req.params.gattc_write.handle = p_ble_scol_c->peer_scol_db.live_meas_cccd_handle;
cccd_req.params.gattc_write.len = BLE_CCCD_VALUE_LEN;
//cccd_req.params.gattc_write.offset = 0;
cccd_req.params.gattc_write.p_value = cccd;
cccd_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_REQ;
return nrf_ble_gq_item_add(p_ble_scol_c->p_gatt_queue, &cccd_req, p_ble_scol_c->conn_handle);
}function with which central enables notifications on the peripheral
uint32_t ble_scol_c_subscribe(ble_scol_c_t * p_ble_scol_c, uint8_t subscribe[14])
uint8_t subscribe_size[14]={0};
//char subscribe_size[14] = {0};
NRF_LOG_INFO("p_ble_scol_c->conn_handle %d", p_ble_scol_c->conn_handle);
NRF_LOG_INFO("Writing Subscription [%d,%d,%d,%d,%d..", subscribe[0], subscribe[1],subscribe[2],subscribe[3],subscribe[4]);
NRF_LOG_INFO(" .... %d,%d,%d,%d,%d....", subscribe[5],subscribe[6],subscribe[7],subscribe[8],subscribe[9]);
NRF_LOG_INFO(" .... %d,%d,%d,%d]", subscribe[10],subscribe[11],subscribe[12],subscribe[13]);
nrf_ble_gq_req_t write_req;
//memset(&write_req, 0, sizeof(nrf_ble_gq_req_t));
write_req.type = NRF_BLE_GQ_REQ_GATTC_WRITE;
write_req.error_handler.cb = gatt_error_handler;
write_req.error_handler.p_ctx = p_ble_scol_c;
write_req.params.gattc_write.handle = p_ble_scol_c->peer_scol_db.subscribe_handle;
write_req.params.gattc_write.len = sizeof(subscribe_size);
write_req.params.gattc_write.p_value = (uint8_t *)&subscribe;
write_req.params.gattc_write.offset = 0;
write_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_REQ;
return nrf_ble_gq_item_add(p_ble_scol_c->p_gatt_queue, &write_req, p_ble_scol_c->conn_handle);
function to write the uint8_t array in 0x0001 Characteristic
void ble_scol_on_db_disc_evt(ble_scol_c_t * p_ble_scol_c, const ble_db_discovery_evt_t * p_evt)
// Check if the Service was discovered.
if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE &&
p_evt->params.discovered_db.srv_uuid.uuid == SENSOR_UUID_SERVICE &&
p_evt->params.discovered_db.srv_uuid.type == p_ble_scol_c->uuid_type)
ble_scol_c_evt_t evt;
evt.evt_type = BLE_SCOL_C_EVT_DISCOVERY_COMPLETE;
evt.conn_handle = p_evt->conn_handle;
for (uint32_t i = 0; i < p_evt->params.discovered_db.char_count; i++)
const ble_gatt_db_char_t * p_char = &(p_evt->params.discovered_db.charateristics[i]);
switch (p_char->characteristic.uuid.uuid)
// Check if characteristics were found on the peer
case NOTIFY_CHARACTERISTIC:
evt.params.peer_db.live_meas_handle = p_char->characteristic.handle_value; /*< Handle for the characteristic when it received a value. */
evt.params.peer_db.live_meas_cccd_handle = p_char->cccd_handle; /*< Handle for the characteristic to enable/disable notify/indicate. */
NRF_LOG_INFO("Notify Characteristic 0x0002 discovered");
case WRITE_CHARACTERISTIC:
evt.params.peer_db.subscribe_handle = p_char->characteristic.handle_value;
NRF_LOG_INFO("Write Characteristic 0x0001 discovered");
NRF_LOG_DEBUG(" Service discovered at peer.");
//If the instance was assigned prior to db_discovery, assign the db_handles
if (p_ble_scol_c->conn_handle != BLE_CONN_HANDLE_INVALID)
if ((p_ble_scol_c->peer_scol_db.live_meas_handle == BLE_GATT_HANDLE_INVALID)&&
(p_ble_scol_c->peer_scol_db.live_meas_cccd_handle == BLE_GATT_HANDLE_INVALID)&&
(p_ble_scol_c->peer_scol_db.subscribe_handle == BLE_GATT_HANDLE_INVALID))
p_ble_scol_c->peer_scol_db = evt.params.peer_db;
p_ble_scol_c->evt_handler(p_ble_scol_c, &evt);
function with which I confirm that the Service and the Characteristics are successfully discovered
static void on_hvx(ble_scol_c_t * p_ble_scol_c, ble_evt_t const * p_ble_evt)
// Check if the event is on the link for this instance.
if (p_ble_scol_c->conn_handle != p_ble_evt->evt.gattc_evt.conn_handle)
NRF_LOG_INFO("Received hvx on link 0x%x not associated to this instance. Ignore.", p_ble_evt->evt.gattc_evt.conn_handle);
return;
// Check if the event is an Adjustment (live_meas) notification.
if (p_ble_evt->evt.gattc_evt.params.hvx.handle == p_ble_scol_c->peer_scol_db.live_meas_handle)
NRF_LOG_INFO("Received data of size: %d", p_ble_evt->evt.gattc_evt.params.hvx.len);
uint8_t data_size[18];
uint32_t index=0;
if (p_ble_evt->evt.gattc_evt.params.hvx.len == sizeof(data_size))
ble_scol_c_evt_t ble_scol_c_evt;
ble_scol_c_evt.evt_type = SCOL_C_NOTIFY_CHAR_WRITTEN;
ble_scol_c_evt.conn_handle = p_ble_scol_c->conn_handle;
memcpy(&ble_scol_c_evt.params.acc_data[0], p_ble_evt->evt.gattc_evt.params.hvx.data+6, sizeof(ble_scol_c_evt.params.acc_data[0]));
memcpy(&ble_scol_c_evt.params.acc_data[1], p_ble_evt->evt.gattc_evt.params.hvx.data+10, sizeof(ble_scol_c_evt.params.acc_data[0]));
memcpy(&ble_scol_c_evt.params.acc_data[2], p_ble_evt->evt.gattc_evt.params.hvx.data+14, sizeof(ble_scol_c_evt.params.acc_data[0]));
NRF_LOG_INFO("Notify Value Received ="NRF_LOG_FLOAT_MARKER, NRF_LOG_FLOAT(ble_scol_c_evt.params.acc_data[0]));
p_ble_scol_c->evt_handler(p_ble_scol_c, &ble_scol_c_evt);
NRF_LOG_INFO("Another write did happen. Ignore.");
on_hvx function
Do I miss something here? Should I change something more in the config file?
Any ideas on this would be very much appreciated.
Thank you in advance,
Dimitra
