I upgraded Toolchain and SDK in VS Code to Version 2.6.1.
Now the build is failing.
As far as I can see the wrong CMake will be used - from Visual Studio but it should be Zephyr.
Errors:
[proc] Executing command: "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\IDE\CommonExtensions\Microsoft\CMake\CMake\bin\cmake.exe" --version
[proc] Executing command: "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\Common7\IDE\CommonExtensions\Microsoft\CMake\CMake\bin\cmake.exe" -E capabilities
[variant] Loaded new set of variants
[kit] Successfully loaded 4 kits from C:\Users\andre\AppData\Local\CMakeTools\cmake-tools-kits.json
[proc] The command: ninja --version failed with error: Error: spawn ninja ENOENT
[proc] The command: ninja-build --version failed with error: Error: spawn ninja-build ENOENT
[proc] The command: make --version failed with error: Error: spawn make ENOENT
[main] Unable to determine what CMake generator to use. Please install or configure a preferred generator, or update settings.json, your Kit configuration or PATH variable. Error: No usable generator found.
[main] Configuring project: fund_less2_exer2
Could you instruct me how to configure the system in order to use the right CMake?
Many thanks in advance
