Hi Everyone,
I am trying to develop a simple application with the XIAO BLE Sense device, the idea is to send a BLE message with a something hits the device. To achieve this, I wanted to configure the IMU so that /*********************************/
First of all, let me summarize what I am using and what program I have uploaded to the device:
- Hardware:
- Xiao BLE Sense.
- Software:
- Visual Studio Code.
- nRF Connect for VS Code Extension Pack (latest version).
- nRF Connect SDK Toolchain v2.5.2
- nRF Connect SDK v2.5.2
- Zephyr OS.
I have used the Zephyr Example for LSM6DSL but I have modified the following piece of code:
#ifdef CONFIG_LSM6DSL_TRIGGER
struct sensor_trigger trig;
struct sensor_value dur;
struct sensor_value th;
trig.type = SENSOR_TRIG_MOTION;
trig.chan = SENSOR_CHAN_ACCEL_XYZ;
if (sensor_trigger_set(lsm6dsl_dev, &trig, lsm6dsl_trigger_handler) != 0) {
printk("Could not set sensor type and channel\n");
return 0;
if (sensor_attr_set(lsm6dsl_dev,SENSOR_CHAN_ACCEL_XYZ,SENSOR_ATTR_SLOPE_TH, &val) !=0){
printk("Could not set sensor attribute slope TH\n");
return 0;
if (sensor_attr_set(lsm6dsl_dev,SENSOR_CHAN_ACCEL_XYZ,SENSOR_ATTR_SLOPE_DUR, &val) !=0){
printk("Could not set sensor attribute slope DUR\n");
return 0;
#endifI also attach the prj.config
CONFIG_STDOUT_CONSOLE=y CONFIG_I2C=y CONFIG_SPI=y CONFIG_SENSOR=y CONFIG_LSM6DSL=y CONFIG_LSM6DSL_ACCEL_ODR=8 CONFIG_LSM6DSL_ACCEL_FS=16 CONFIG_LSM6DSL_GYRO_FS=1000 CONFIG_LSM6DSL_GYRO_ODR=8 CONFIG_LSM6DSL_ENABLE_TEMP=y CONFIG_LSM6DSL_TRIGGER_GLOBAL_THREAD=y CONFIG_CBPRINTF_FP_SUPPORT=y CONFIG_BT=y CONFIG_LOG=y CONFIG_BT_SMP=y CONFIG_BT_DEBUG_LOG=y CONFIG_BT_MAX_CONN=1 CONFIG_BT_GATT_CLIENT=y CONFIG_BT_L2CAP_TX_MTU=247 CONFIG_BT_L2CAP_TX_BUF_COUNT=5 CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="ixi" CONFIG_BT_DEVICE_APPEARANCE=962 CONFIG_HEAP_MEM_POOL_SIZE=2048 # This example requires more workqueue stack CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 #USB CONFIG_USB_DEVICE_STACK=y CONFIG_USB_DEVICE_PRODUCT="IXI Sample" CONFIG_USB_DEVICE_PID=0x0004 CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y CONFIG_SERIAL=y CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y CONFIG_UART_LINE_CTRL=y
The issue that I am facing is that no events and no data from the IMU is either launched or read. The only way I could read data was when I use the
trig.type = SENSOR_TRIG_DATA_READY.
So I am not sure what I am doing wrong or if more events have been developed in Zephyr. If so, somebody that has used other events could help me to configure it?
Thanks beforehand, sorry for the inconveniences and looking forward to hearing from you.
Kind regards.
