Hi everyone,
I'm the author of the following question and a lot of context information about the state of our custom application can be gathered from there: registration sometimes fails.
Here's the current configuration:
# # Application sample # CONFIG_UI_INPUT=y # CONFIG_UI_SENSE_LED is not set # # Modules # CONFIG_SENSOR_MODULE=y CONFIG_SENSOR_MODULE_WATER_PRIOT=y CONFIG_SENSOR_MODULE_PRIOT_RAKE_TEMP=y CONFIG_SENSOR_MODULE_PRIOT_RAKE_HUM=y CONFIG_SENSOR_MODULE_PRIOT_I2_CIRCUIT_BOARD_TEMP=y CONFIG_SENSOR_MODULE_PRIOT_I2_CIRCUIT_BOARD_HUM=y CONFIG_SENSOR_MODULE_READ_FREQUENCY=5 # CONFIG_PRIOT_BETA_HARDWARE is not set # end of Modules CONFIG_LWM2M_APP_WATER_SENSOR_PRIOT=y CONFIG_LWM2M_APP_PUSH_BUTTON=y # # LwM2M objects # CONFIG_APP_PUSH_BUTTON=y # CONFIG_APP_LIGHT_CONTROL is not set # CONFIG_APP_BUZZER is not set # CONFIG_APP_LIGHT_SENSOR is not set # CONFIG_APP_ENV_SENSOR is not set # CONFIG_APP_ACCELEROMETER is not set # CONFIG_APP_GNSS is not set # CONFIG_GNSS is not set # end of LwM2M objects CONFIG_APP_LWM2M_PSK="3d83cfc5f8a254b62a1f64f051934e24" CONFIG_APP_ENDPOINT_PREFIX="urn:imei:" # # Device info # CONFIG_APP_MANUFACTURER="PRiOT AG" CONFIG_APP_DEVICE_TYPE="OMA-LWM2M Client" # end of Device info CONFIG_APP_CUSTOM_VERSION="ntc_ver_0.15_5min_sensor_read" # CONFIG_APP_LWM2M_CONFORMANCE_TESTING is not set # CONFIG_APP_LOG_LEVEL_OFF is not set # CONFIG_APP_LOG_LEVEL_ERR is not set # CONFIG_APP_LOG_LEVEL_WRN is not set # CONFIG_APP_LOG_LEVEL_INF is not set CONFIG_APP_LOG_LEVEL_DBG=y # CONFIG_APP_LOG_LEVEL_DEFAULT is not set CONFIG_APP_LOG_LEVEL=4 # end of Application sample # # Zephyr Kernel # # CONFIG_INPUT is not set # CONFIG_WIFI is not set # CONFIG_NET_L2_ETHERNET is not set CONFIG_ADC_INIT_PRIORITY=50 # CONFIG_MIPI_DSI is not set # CONFIG_MODEM is not set CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_COAP_INIT_ACK_TIMEOUT_MS=4000 # CONFIG_NET_IPV6 is not set # CONFIG_NET_CONFIG_NEED_IPV6 is not set CONFIG_SPI=y CONFIG_BOARD="thingy91_nrf9160" CONFIG_REGULATOR=y CONFIG_BUILD_WITH_TFM=y CONFIG_TFM_FLASH_MERGED_BINARY=y CONFIG_FLASH_LOAD_SIZE=0x0 CONFIG_FLASH_LOAD_OFFSET=0x0 CONFIG_HW_STACK_PROTECTION=y CONFIG_NUM_IRQS=65 CONFIG_SOC_SERIES="nrf91" CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768 CONFIG_SOC="nRF9160_SICA" CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30 CONFIG_FLASH_SIZE=1024 CONFIG_FLASH_BASE_ADDRESS=0x0 CONFIG_ICACHE_LINE_SIZE=32 CONFIG_DCACHE_LINE_SIZE=32 CONFIG_HEAP_MEM_POOL_SIZE=16384 CONFIG_ROM_START_OFFSET=0 CONFIG_PINCTRL=y CONFIG_CLOCK_CONTROL=y CONFIG_WATCHDOG=y # CONFIG_RESET is not set CONFIG_GPIO=y CONFIG_SOC_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y CONFIG_NRF_RTC_TIMER=y CONFIG_LOG_DOMAIN_NAME="" CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768 CONFIG_BUILD_OUTPUT_HEX=y # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set CONFIG_SERIAL_INIT_PRIORITY=55 # CONFIG_FPU is not set # CONFIG_MBEDTLS is not set # CONFIG_MEMC is not set # CONFIG_CODE_DATA_RELOCATION is not set # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set # CONFIG_TINYCRYPT is not set # CONFIG_NET_L2_IEEE802154 is not set CONFIG_SERIAL=y CONFIG_NET_UDP_CHECKSUM=y CONFIG_MAIN_STACK_SIZE=4096 # CONFIG_SRAM_VECTOR_TABLE is not set CONFIG_USE_DT_CODE_PARTITION=y CONFIG_PLATFORM_SPECIFIC_INIT=y CONFIG_IDLE_STACK_SIZE=320 CONFIG_PM_DEVICE=y CONFIG_BUILD_OUTPUT_BIN=y CONFIG_MP_MAX_NUM_CPUS=1 # # Devicetree Info # CONFIG_DT_HAS_ADI_ADP5360_ENABLED=y CONFIG_DT_HAS_ADI_ADP5360_REGULATOR_ENABLED=y CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF91_FLASH_CONTROLLER_ENABLED=y CONFIG_DT_HAS_PWM_LEDS_ENABLED=y CONFIG_DT_HAS_SENSIRION_SHT4X_ENABLED=y CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y CONFIG_DT_HAS_TI_ADS1015_ENABLED=y CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y # end of Devicetree Info # # Modules # # # Available modules. # # # nrf (C:/ncs/v2.6.0/nrf) # CONFIG_OBERON_BACKEND=y CONFIG_PSA_CRYPTO_DRIVER_OBERON=y # CONFIG_MBOX is not set CONFIG_NUM_METAIRQ_PRIORITIES=0 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_LOG_BUFFER_SIZE=1024 CONFIG_INIT_STACKS=y CONFIG_NET_PKT_RX_COUNT=4 CONFIG_NET_PKT_TX_COUNT=4 # CONFIG_MBEDTLS_CIPHER_MODE_CBC is not set # CONFIG_MBEDTLS_CIPHER_MODE_CTR is not set CONFIG_MBEDTLS_CIPHER_MODE_CFB=y CONFIG_MBEDTLS_CIPHER_MODE_OFB=y # CONFIG_MBEDTLS_CHACHA20_C is not set # CONFIG_MBEDTLS_POLY1305_C is not set # CONFIG_MBEDTLS_DHM_C is not set CONFIG_MBEDTLS_SHA512_C=y # CONFIG_MBEDTLS_GCM_C is not set # CONFIG_MBEDTLS_CIPHER_MODE_XTS is not set # CONFIG_NET_PKT_TXTIME is not set # CONFIG_NET_PKT_TIMESTAMP is not set # CONFIG_MBEDTLS_SHA1_C is not set CONFIG_MBEDTLS_MD_C=y # CONFIG_MBEDTLS_TLS_LIBRARY is not set # CONFIG_MBEDTLS_X509_LIBRARY is not set # CONFIG_MBEDTLS_ENABLE_HEAP is not set # CONFIG_MBEDTLS_ECP_C is not set # CONFIG_MBEDTLS_CTR_DRBG_C is not set # CONFIG_MBEDTLS_CMAC_C is not set # CONFIG_MBEDTLS_CCM_C is not set CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y CONFIG_TFM_MCUBOOT_IMAGE_NUMBER=1 CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED=y CONFIG_TFM_PARTITION_CRYPTO=y CONFIG_TFM_PARTITION_PLATFORM=y # # Nordic nRF Connect # CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK" CONFIG_WARN_EXPERIMENTAL=y CONFIG_BOARD_THINGY91_NRF9160_NS=y CONFIG_PRIVILEGED_STACK_SIZE=1024 CONFIG_INIT_ARCH_HW_AT_BOOT=y CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_GETOPT=y # CONFIG_NCS_SAMPLES_DEFAULTS is not set # # Image build variants # # CONFIG_NCS_MCUBOOT_IN_BUILD is not set # end of Image build variants CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_UPDATEABLE_IMAGE_NUMBER=1 # # Subsystems # # # Bootloader # # CONFIG_BUILD_S1_VARIANT is not set # CONFIG_SECURE_BOOT is not set CONFIG_PM_PARTITION_SIZE_PROVISION=0x280 # CONFIG_B0_MIN_PARTITION_SIZE is not set CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000 # CONFIG_IS_SECURE_BOOTLOADER is not set # # Secure Boot firmware validation # CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483 CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1 CONFIG_SB_VALIDATION_INFO_VERSION=2 CONFIG_SB_VALIDATION_METADATA_OFFSET=0 CONFIG_SB_VALIDATE_FW_SIGNATURE=y # end of Secure Boot firmware validation # CONFIG_SECURE_BOOT_STORAGE is not set # end of Bootloader # # Bluetooth Low Energy # # # BLE over nRF RPC # # end of BLE over nRF RPC # end of Bluetooth Low Energy # # DFU # # CONFIG_DFU_MULTI_IMAGE is not set CONFIG_DFU_TARGET=y CONFIG_DFU_TARGET_MCUBOOT=y CONFIG_DFU_TARGET_STREAM=y # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set # CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS is not set CONFIG_DFU_TARGET_MODEM_DELTA=y CONFIG_DFU_TARGET_MODEM_TIMEOUT=60 # CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set # CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set # CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set # CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set # CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y CONFIG_DFU_TARGET_LOG_LEVEL=3 # CONFIG_FMFU_FDEV is not set # end of DFU # CONFIG_ESB is not set # CONFIG_EMDS is not set # # Peripheral CPU DFU (PCD) # # CONFIG_PCD is not set # CONFIG_PCD_APP is not set CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046 # CONFIG_PCD_NET is not set # end of Peripheral CPU DFU (PCD) # # Networking # # # Application protocols # # # nRF Cloud # # # Client ID (nRF Cloud Device ID) # CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y # CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME is not set CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="nrf-" # end of Client ID (nRF Cloud Device ID) # CONFIG_NRF_CLOUD_MQTT is not set # CONFIG_NRF_CLOUD_FOTA is not set CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y CONFIG_FOTA_DL_TIMEOUT_MIN=15 # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set # CONFIG_NRF_CLOUD_FOTA_POLL is not set # CONFIG_NRF_CLOUD_AGNSS is not set # CONFIG_NRF_CLOUD_PGPS is not set # CONFIG_NRF_CLOUD_REST is not set # CONFIG_NRF_CLOUD_ALERT is not set # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3 CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1 # CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256 # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3 # CONFIG_NRF_CLOUD_COAP is not set # # Send shadow info sections on initial connect (MQTT/CoAP) # # end of Send shadow info sections on initial connect (MQTT/CoAP) # CONFIG_NRF_CLOUD_GATEWAY is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y CONFIG_NRF_CLOUD_LOG_LEVEL=3 # end of nRF Cloud # CONFIG_REST_CLIENT is not set CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2048 CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE=1024 # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_2048 is not set CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_512 is not set # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_256 is not set CONFIG_DOWNLOAD_CLIENT_COAP_BLOCK_SIZE=5 CONFIG_DOWNLOAD_CLIENT_COAP_BLOCK_SIZE_512=y # CONFIG_DOWNLOAD_CLIENT_COAP_BLOCK_SIZE_256 is not set # CONFIG_DOWNLOAD_CLIENT_COAP_BLOCK_SIZE_128 is not set # # Thread and stack buffers # CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 CONFIG_DOWNLOAD_CLIENT_MAX_HOSTNAME_SIZE=255 CONFIG_DOWNLOAD_CLIENT_MAX_FILENAME_SIZE=255 CONFIG_DOWNLOAD_CLIENT_TCP_SOCK_TIMEO_MS=30000 CONFIG_DOWNLOAD_CLIENT_COAP_MAX_RETRANSMIT_REQUEST_COUNT=4 CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS=y # CONFIG_DOWNLOAD_CLIENT_CID is not set # CONFIG_DOWNLOAD_CLIENT_SHELL is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_OFF is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_ERR is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_WRN is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_INF is not set # CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG is not set CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DEFAULT=y CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL=3 CONFIG_FOTA_DOWNLOAD=y CONFIG_FOTA_SOCKET_RETRIES=2 CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y CONFIG_FOTA_CLIENT_AUTOSCHEDULE_UPDATE=y CONFIG_FOTA_DOWNLOAD_MCUBOOT_FLASH_BUF_SZ=512 # CONFIG_FOTA_DOWNLOAD_NATIVE_TLS is not set CONFIG_FOTA_DOWNLOAD_FILE_NAME_LENGTH=128 CONFIG_FOTA_DOWNLOAD_HOST_NAME_LENGTH=128 CONFIG_FOTA_DOWNLOAD_RESOURCE_LOCATOR_LENGTH=512 CONFIG_FOTA_DOWNLOAD_SEC_TAG_LIST_SIZE_MAX=5 # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_OFF is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_ERR is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_WRN is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_INF is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DBG is not set CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DEFAULT=y CONFIG_FOTA_DOWNLOAD_LOG_LEVEL=3 # CONFIG_AWS_IOT is not set # CONFIG_AWS_JOBS is not set # CONFIG_AWS_FOTA is not set # CONFIG_AZURE_IOT_HUB is not set # # Self-Registration (Zi ZHu Ce) # # CONFIG_ZZHC is not set # end of Self-Registration (Zi ZHu Ce) # CONFIG_ICAL_PARSER is not set # CONFIG_FTP_CLIENT is not set # CONFIG_COAP_UTILS is not set CONFIG_LWM2M_CLIENT_UTILS=y CONFIG_LWM2M_CLIENT_UTILS_DEVICE_OBJ_SUPPORT=y CONFIG_LWM2M_CLIENT_UTILS_SECURITY_OBJ_SUPPORT=y CONFIG_LWM2M_CLIENT_UTILS_SERVER="coaps://prod.lwm2m.measuremind.ch" CONFIG_LWM2M_CLIENT_UTILS_SERVER_TLS_TAG=35724861 CONFIG_LWM2M_CLIENT_UTILS_BOOTSTRAP_TLS_TAG=35724862 CONFIG_LWM2M_CLIENT_UTILS_CONN_MON_OBJ_SUPPORT=y CONFIG_LWM2M_CONN_MON_BEARER_MAX=2 CONFIG_LWM2M_CONN_HOLD_TIME_RSRP=60 # CONFIG_LWM2M_CLIENT_UTILS_LOCATION_OBJ_SUPPORT is not set CONFIG_LWM2M_CLIENT_UTILS_FIRMWARE_UPDATE_OBJ_SUPPORT=y CONFIG_LWM2M_CLIENT_UTILS_DOWNLOADER_SEC_TAG=16842753 CONFIG_LWM2M_CLIENT_UTILS_FIRMWARE_UPDATE_THREAD_STACK_SIZE=2048 # CONFIG_LWM2M_CLIENT_UTILS_ADV_FIRMWARE_UPDATE_OBJ_SUPPORT is not set # CONFIG_LWM2M_CLIENT_UTILS_GROUND_FIX_OBJ_SUPPORT is not set # CONFIG_LWM2M_CLIENT_UTILS_GNSS_ASSIST_OBJ_SUPPORT is not set CONFIG_LWM2M_CLIENT_UTILS_CELL_CONN_OBJ_SUPPORT=y CONFIG_LWM2M_CELL_CONN_OBJ_VERSION_1_1=y CONFIG_LWM2M_CELL_CONN_APN_PROFILE_COUNT=3 CONFIG_LWM2M_CLIENT_UTILS_RAI=y # CONFIG_LWM2M_CLIENT_UTILS_LTE_CONNEVAL is not set # CONFIG_LWM2M_CLIENT_UTILS_DTLS_CID is not set # CONFIG_LWM2M_CLIENT_UTILS_DTLS_CON_MANAGEMENT is not set # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_OFF is not set # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_ERR is not set # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_WRN is not set # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_INF is not set # CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_DBG is not set CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL_DEFAULT=y CONFIG_LWM2M_CLIENT_UTILS_LOG_LEVEL=3 # CONFIG_WIFI_CREDENTIALS is not set # CONFIG_WIFI_CREDENTIALS_STATIC is not set # CONFIG_MQTT_HELPER is not set # CONFIG_NRF_PROVISIONING is not set # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set # end of Application protocols # end of Networking # # NFC # # CONFIG_NFC_NDEF is not set # CONFIG_NFC_NDEF_PARSER is not set # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set # CONFIG_NFC_T2T_PARSER is not set # CONFIG_NFC_T4T_NDEF_FILE is not set # CONFIG_NFC_T4T_ISODEP is not set # CONFIG_NFC_T4T_APDU is not set # CONFIG_NFC_T4T_CC_FILE is not set # CONFIG_NFC_T4T_HL_PROCEDURE is not set # CONFIG_NFC_PLATFORM is not set # CONFIG_NFC_TNEP_TAG is not set # CONFIG_NFC_TNEP_POLLER is not set # CONFIG_NFC_TNEP_CH is not set # end of NFC CONFIG_APP_EVENT_MANAGER=y CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y # CONFIG_APP_EVENT_MANAGER_SHOW_EVENT_HANDLERS is not set # CONFIG_APP_EVENT_MANAGER_TRACE_EVENT_DATA is not set CONFIG_APP_EVENT_MANAGER_SHELL=y # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_OFF is not set # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_ERR is not set # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_WRN is not set # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF is not set # CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DBG is not set CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DEFAULT=y CONFIG_APP_EVENT_MANAGER_LOG_LEVEL=3 # CONFIG_APP_EVENT_MANAGER_USE_DEPRECATED_LOG_FUN is not set CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=y CONFIG_APP_EVENT_MANAGER_MAX_EVENT_CNT=32 # CONFIG_APP_EVENT_MANAGER_PROVIDE_EVENT_SIZE is not set # CONFIG_APP_EVENT_MANAGER_POSTINIT_HOOK is not set # CONFIG_APP_EVENT_MANAGER_SUBMIT_HOOKS is not set # CONFIG_APP_EVENT_MANAGER_PREPROCESS_HOOKS is not set # CONFIG_APP_EVENT_MANAGER_POSTPROCESS_HOOKS is not set # CONFIG_APP_EVENT_MANAGER_PROFILER_TRACER is not set # CONFIG_NRF_PROFILER is not set CONFIG_FW_INFO=y # CONFIG_FW_INFO_API is not set CONFIG_FW_INFO_OFFSET=0x200 CONFIG_FW_INFO_FIRMWARE_VERSION=1 CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea CONFIG_FW_INFO_HARDWARE_ID=91 CONFIG_FW_INFO_VERSION=2 CONFIG_FW_INFO_CRYPTO_ID=0 CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0 CONFIG_FW_INFO_MAGIC_LEN=12 CONFIG_FW_INFO_VALID_VAL=0x9102FFFF CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set # CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set # # Debug # # CONFIG_CPU_LOAD is not set # CONFIG_ETB_TRACE is not set # CONFIG_PPI_TRACE is not set # end of Debug # # Multiprotocol service layer (MPSL) # # CONFIG_MPSL_FEM_ONLY is not set # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y CONFIG_MPSL_FEM_LOG_LEVEL=3 CONFIG_MPSL_THREAD_COOP_PRIO=8 CONFIG_MPSL_WORK_STACK_SIZE=1024 CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0 # CONFIG_MPSL_ASSERT_HANDLER is not set # CONFIG_MPSL_LOG_LEVEL_OFF is not set # CONFIG_MPSL_LOG_LEVEL_ERR is not set # CONFIG_MPSL_LOG_LEVEL_WRN is not set # CONFIG_MPSL_LOG_LEVEL_INF is not set # CONFIG_MPSL_LOG_LEVEL_DBG is not set CONFIG_MPSL_LOG_LEVEL_DEFAULT=y CONFIG_MPSL_LOG_LEVEL=3 # end of Multiprotocol service layer (MPSL) # # Partition Manager # CONFIG_PARTITION_MANAGER_ENABLED=y CONFIG_FLASH_MAP_CUSTOM=y CONFIG_SRAM_SIZE=128 CONFIG_SRAM_BASE_ADDRESS=0x20020000 # # Zephyr subsystem configurations # CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000 CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x8000 # end of Zephyr subsystem configurations # # NCS subsystem configurations # CONFIG_PM_SINGLE_IMAGE=y CONFIG_PM_EXTERNAL_FLASH_BASE=0 CONFIG_PM_EXTERNAL_FLASH_PATH="" CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0 # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set CONFIG_PM_SRAM_BASE=0x20000000 CONFIG_PM_SRAM_SIZE=0x40000 # end of Partition Manager # # nRF RPC (Remote Procedure Call) library # # end of nRF RPC (Remote Procedure Call) library # # Full Modem Firmware Update Management(FMFU) # # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y CONFIG_MGMT_FMFU_LOG_LEVEL=3 # end of Full Modem Firmware Update Management(FMFU) # CONFIG_CAF is not set # # Nordic IEEE 802.15.4 # # end of Nordic IEEE 802.15.4 # CONFIG_DM_MODULE is not set # # nRF Security # CONFIG_NORDIC_SECURITY_BACKEND=y CONFIG_NRF_SECURITY=y CONFIG_MBEDTLS_CFG_FILE="nrf-config.h" CONFIG_MBEDTLS_USER_CONFIG_FILE="nrf-config-user-empty.h" CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-want-config.h" CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-config.h" CONFIG_GENERATE_MBEDTLS_CFG_FILE=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y # # PSA RNG support # CONFIG_PSA_WANT_GENERATE_RANDOM=y # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set CONFIG_PSA_WANT_ALG_HMAC_DRBG=y # end of PSA RNG support # # PSA key type support # # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set # CONFIG_PSA_WANT_KEY_TYPE_AES is not set # CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set # CONFIG_PSA_WANT_KEY_TYPE_DES is not set # CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set # CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set # CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set # end of PSA key type support # # PSA AEAD support # # CONFIG_PSA_WANT_ALG_CCM is not set # CONFIG_PSA_WANT_ALG_GCM is not set # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set # end of PSA AEAD support # # PSA MAC support # # CONFIG_PSA_WANT_ALG_CBC_MAC is not set # CONFIG_PSA_WANT_ALG_CMAC is not set # CONFIG_PSA_WANT_ALG_HMAC is not set # end of PSA MAC support # # PSA Hash support # # CONFIG_PSA_WANT_ALG_SHA_1 is not set # CONFIG_PSA_WANT_ALG_SHA_224 is not set # CONFIG_PSA_WANT_ALG_SHA_256 is not set # CONFIG_PSA_WANT_ALG_SHA_384 is not set # CONFIG_PSA_WANT_ALG_SHA_512 is not set # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set # CONFIG_PSA_WANT_ALG_SHA3_224 is not set # CONFIG_PSA_WANT_ALG_SHA3_256 is not set # CONFIG_PSA_WANT_ALG_SHA3_384 is not set # CONFIG_PSA_WANT_ALG_SHA3_512 is not set # CONFIG_PSA_WANT_ALG_SM3 is not set # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set # CONFIG_PSA_WANT_ALG_MD2 is not set # CONFIG_PSA_WANT_ALG_MD4 is not set # CONFIG_PSA_WANT_ALG_MD5 is not set # end of PSA Hash support # # PSA Cipher support # # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set # CONFIG_PSA_WANT_ALG_CFB is not set # CONFIG_PSA_WANT_ALG_CTR is not set # CONFIG_PSA_WANT_ALG_OFB is not set # CONFIG_PSA_WANT_ALG_XTS is not set # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set # end of PSA Cipher support # # PSA Key agreement support # # CONFIG_PSA_WANT_ALG_ECDH is not set # CONFIG_PSA_WANT_ALG_FFDH is not set # end of PSA Key agreement support # # PSA Key derivation support # # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set # end of PSA Key derivation support # # PSA Asymmetric support # # CONFIG_PSA_WANT_ALG_ECDSA is not set # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set # # Elliptic Curve type support # # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set # end of Elliptic Curve type support # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set # CONFIG_PSA_WANT_ALG_RSA_PSS is not set # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set # end of PSA Asymmetric support # CONFIG_PSA_WANT_ALG_JPAKE is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set # CONFIG_PSA_WANT_ALG_SRP_6 is not set # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set # CONFIG_PSA_WANT_ALG_ED25519PH is not set # CONFIG_PSA_WANT_ALG_ED448PH is not set CONFIG_MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG=y CONFIG_PSA_CORE_OBERON=y # # PSA Driver Support # CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y CONFIG_PSA_DEFAULT_OFF=y CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y # CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set # # Choose DRBG algorithm # CONFIG_PSA_USE_HMAC_DRBG_DRIVER=y # end of Choose DRBG algorithm # # CryptoCell PSA Driver Configuration # CONFIG_PSA_USE_CC3XX_HMAC_DRBG_DRIVER=y # end of CryptoCell PSA Driver Configuration # # CRACEN PSA Driver Configuration # # end of CRACEN PSA Driver Configuration # # AES key size configuration # CONFIG_PSA_WANT_AES_KEY_SIZE_128=y CONFIG_PSA_WANT_AES_KEY_SIZE_192=y CONFIG_PSA_WANT_AES_KEY_SIZE_256=y # end of AES key size configuration # # RSA key size configuration # # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set CONFIG_PSA_MAX_RSA_KEY_BITS=0 # end of RSA key size configuration CONFIG_PSA_ACCEL_GENERATE_RANDOM=y CONFIG_PSA_NEED_CC3XX_HMAC_DRBG_DRIVER=y # CONFIG_CRACEN_LOG_LEVEL_OFF is not set # CONFIG_CRACEN_LOG_LEVEL_ERR is not set # CONFIG_CRACEN_LOG_LEVEL_WRN is not set # CONFIG_CRACEN_LOG_LEVEL_INF is not set # CONFIG_CRACEN_LOG_LEVEL_DBG is not set CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y CONFIG_CRACEN_LOG_LEVEL=3 # # PSA API support # CONFIG_MBEDTLS_USE_PSA_CRYPTO=y CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32 # end of PSA API support CONFIG_MBEDTLS_PLATFORM_MEMORY=y CONFIG_MBEDTLS_PLATFORM_C=y CONFIG_MBEDTLS_MEMORY_C=y CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y CONFIG_MBEDTLS_AES_DECRYPT_ALT=y CONFIG_MBEDTLS_CHACHA20_ALT=y CONFIG_MBEDTLS_POLY1305_ALT=y CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y CONFIG_MBEDTLS_ECJPAKE_ALT=y CONFIG_MBEDTLS_SHA1_ALT=y CONFIG_MBEDTLS_SHA224_ALT=y CONFIG_MBEDTLS_SHA256_ALT=y CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1 CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y # CONFIG_NRF_SECURITY_ADVANCED is not set CONFIG_OBERON_ONLY_PSA_ENABLED=y CONFIG_OBERON_ONLY_ENABLED=y # # Legacy mbed TLS crypto APIs # CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6 CONFIG_MBEDTLS_MPI_MAX_SIZE=256 # CONFIG_CC3XX_BACKEND is not set CONFIG_MBEDTLS_CTR_DRBG_USE_128_BIT_KEY=y CONFIG_MBEDTLS_HMAC_DRBG_C=y CONFIG_MBEDTLS_AES_C=y # # Cipher Selection # # # AEAD - Authenticated Encryption with Associated Data # # end of AEAD - Authenticated Encryption with Associated Data CONFIG_MBEDTLS_HKDF_C=y # # SHA - Secure Hash Algorithm # CONFIG_MBEDTLS_SHA224_C=y CONFIG_MBEDTLS_SHA256_C=y CONFIG_MBEDTLS_SHA384_C=y # end of SHA - Secure Hash Algorithm CONFIG_MBEDTLS_CIPHER_C=y # CONFIG_MBEDTLS_PK_C is not set # CONFIG_MBEDTLS_PK_WRITE_C is not set # CONFIG_MBEDTLS_PK_PARSE_C is not set # end of Legacy mbed TLS crypto APIs # end of nRF Security # # Audio Module # # CONFIG_AUDIO_MODULE_TEST is not set CONFIG_AUDIO_MODULE_NAME_SIZE=20 # CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set # CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set # CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set # CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set # CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y CONFIG_AUDIO_MODULE_LOG_LEVEL=3 # end of Audio Module # end of Subsystems # CONFIG_WPA_SUPP is not set CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1 CONFIG_NET_SOCKETPAIR_BUFFER_SIZE=64 CONFIG_POSIX_MAX_FDS=4 CONFIG_NET_SOCKETS_POLL_MAX=3 # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set # CONFIG_WFA_QT_LOG_LEVEL_INF is not set # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y CONFIG_WFA_QT_LOG_LEVEL=3 # CONFIG_WFA_QT_CONTROL_APP is not set CONFIG_WFA_QT_THREAD_STACK_SIZE=4096 CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000 CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0" CONFIG_WPAS_READY_TIMEOUT_MS=10000 # # Libraries # # # Binary libraries # # # Log levels # # CONFIG_BLE_HCI_VSC_LOG_LEVEL_OFF is not set # CONFIG_BLE_HCI_VSC_LOG_LEVEL_ERR is not set # CONFIG_BLE_HCI_VSC_LOG_LEVEL_WRN is not set # CONFIG_BLE_HCI_VSC_LOG_LEVEL_INF is not set # CONFIG_BLE_HCI_VSC_LOG_LEVEL_DBG is not set CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT=y CONFIG_BLE_HCI_VSC_LOG_LEVEL=3 # end of Log levels # end of Binary libraries CONFIG_NRF_MODEM_LIB=y # # Memory configuration # CONFIG_NRF_MODEM_LIB_HEAP_SIZE=1024 CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8 CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8320 CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192 CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0 CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128 # CONFIG_NRF_MODEM_LIB_MEM_DIAG is not set # end of Memory configuration # CONFIG_NRF_MODEM_LIB_TRACE is not set CONFIG_NRF_MODEM_LIB_ON_FAULT_DO_NOTHING=y # CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM is not set # CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC is not set CONFIG_NRF_MODEM_LIB_CFUN_HOOKS=y # CONFIG_NRF_MODEM_LIB_FAULT_STRERROR is not set # # Shell # # CONFIG_NRF_MODEM_LIB_SHELL_TRACE is not set # end of Shell CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO=1 # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_OFF is not set # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_ERR is not set # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_WRN is not set # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_INF is not set # CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG is not set CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DEFAULT=y CONFIG_NRF_MODEM_LIB_LOG_LEVEL=3 # CONFIG_NRF_MODEM_LIB_LOG_FW_VERSION_UUID is not set CONFIG_ADP536X=y CONFIG_AT_MONITOR=y CONFIG_AT_MONITOR_HEAP_SIZE=512 # CONFIG_AT_MONITOR_LOG_LEVEL_OFF is not set # CONFIG_AT_MONITOR_LOG_LEVEL_ERR is not set # CONFIG_AT_MONITOR_LOG_LEVEL_WRN is not set # CONFIG_AT_MONITOR_LOG_LEVEL_INF is not set # CONFIG_AT_MONITOR_LOG_LEVEL_DBG is not set CONFIG_AT_MONITOR_LOG_LEVEL_DEFAULT=y CONFIG_AT_MONITOR_LOG_LEVEL=3 CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_SHELL=y # CONFIG_LTE_LOCK_BANDS is not set # CONFIG_LTE_LOCK_PLMN is not set # CONFIG_LTE_UNLOCK_PLMN is not set CONFIG_LTE_PSM_REQ=y CONFIG_LTE_PSM_REQ_FORMAT_STRING=y # CONFIG_LTE_PSM_REQ_FORMAT_SECONDS is not set CONFIG_LTE_PSM_REQ_RPTAU="00111000" CONFIG_LTE_PSM_REQ_RAT="00000010" CONFIG_LTE_PSM_REQ_RPTAU_SECONDS=1800 CONFIG_LTE_PSM_REQ_RAT_SECONDS=60 # CONFIG_LTE_PROPRIETARY_PSM_REQ is not set CONFIG_LTE_EDRX_REQ=y CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="0000" CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="0000" CONFIG_LTE_PTW_VALUE_LTE_M="0000" CONFIG_LTE_PTW_VALUE_NBIOT="0000" # CONFIG_LTE_NETWORK_MODE_DEFAULT is not set # CONFIG_LTE_NETWORK_MODE_LTE_M is not set # CONFIG_LTE_NETWORK_MODE_LTE_M_GPS is not set # CONFIG_LTE_NETWORK_MODE_NBIOT is not set # CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=y # CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS is not set CONFIG_LTE_MODE_PREFERENCE_AUTO=y # CONFIG_LTE_MODE_PREFERENCE_LTE_M is not set # CONFIG_LTE_MODE_PREFERENCE_NBIOT is not set # CONFIG_LTE_MODE_PREFERENCE_LTE_M_PLMN_PRIO is not set # CONFIG_LTE_MODE_PREFERENCE_NBIOT_PLMN_PRIO is not set CONFIG_LTE_MODE_PREFERENCE_VALUE=0 # CONFIG_LTE_RAI_REQ is not set CONFIG_LTE_RAI_REQ_VALUE="0" # CONFIG_LTE_NETWORK_USE_FALLBACK is not set CONFIG_LTE_NETWORK_TIMEOUT=150 CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=y CONFIG_LTE_LC_TAU_PRE_WARNING_TIME_MS=5000 CONFIG_LTE_LC_TAU_PRE_WARNING_THRESHOLD_MS=1200000 CONFIG_LTE_NEIGHBOR_CELLS_MAX=10 CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS=y CONFIG_LTE_LC_MODEM_SLEEP_PRE_WARNING_TIME_MS=5000 CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS_THRESHOLD_MS=1200000 # CONFIG_LTE_LC_TRACE is not set # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF is not set # CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG is not set CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DEFAULT=y CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=3 CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000 CONFIG_FPROTECT_BLOCK_SIZE=0x8000 # CONFIG_FPROTECT is not set # CONFIG_AT_CMD_CUSTOM is not set # CONFIG_AT_HOST_LIBRARY is not set CONFIG_DK_LIBRARY=y CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10 CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y # CONFIG_DK_LIBRARY_BUTTON_NO_ISR is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_OFF is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_ERR is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_WRN is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_INF is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_DBG is not set CONFIG_DK_LIBRARY_LOG_LEVEL_DEFAULT=y CONFIG_DK_LIBRARY_LOG_LEVEL=3 # CONFIG_DK_LIBRARY_SHELL is not set CONFIG_AT_CMD_PARSER=y # CONFIG_MODEM_BATTERY is not set CONFIG_MODEM_INFO=y CONFIG_MODEM_INFO_MAX_AT_PARAMS_RSP=10 CONFIG_MODEM_INFO_BUFFER_SIZE=128 CONFIG_MODEM_INFO_ADD_NETWORK=y # CONFIG_MODEM_INFO_ADD_DATE_TIME is not set CONFIG_MODEM_INFO_ADD_SIM=y CONFIG_MODEM_INFO_ADD_SIM_ICCID=y CONFIG_MODEM_INFO_ADD_SIM_IMSI=y CONFIG_MODEM_INFO_ADD_DEVICE=y # CONFIG_PDN is not set CONFIG_RESET_ON_FATAL_ERROR=y # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y CONFIG_FATAL_ERROR_LOG_LEVEL=3 # CONFIG_SMS is not set # CONFIG_GCF_SMS is not set CONFIG_MODEM_KEY_MGMT=y # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_OFF is not set # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_ERR is not set # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_WRN is not set # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_INF is not set # CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_DBG is not set CONFIG_MODEM_KEY_MGMT_LOG_LEVEL_DEFAULT=y CONFIG_MODEM_KEY_MGMT_LOG_LEVEL=3 CONFIG_DATE_TIME=y CONFIG_DATE_TIME_AUTO_UPDATE=y CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=86400 CONFIG_DATE_TIME_TOO_OLD_SECONDS=3600 CONFIG_DATE_TIME_MODEM=y CONFIG_DATE_TIME_NTP=y CONFIG_DATE_TIME_THREAD_STACK_SIZE=1280 CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5 # CONFIG_DATE_TIME_LOG_LEVEL_OFF is not set # CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set # CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set # CONFIG_DATE_TIME_LOG_LEVEL_INF is not set # CONFIG_DATE_TIME_LOG_LEVEL_DBG is not set CONFIG_DATE_TIME_LOG_LEVEL_DEFAULT=y CONFIG_DATE_TIME_LOG_LEVEL=3 # CONFIG_HW_ID_LIBRARY is not set # CONFIG_WAVE_GEN_LIB is not set CONFIG_HW_UNIQUE_KEY_SUPPORTED=y CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0 # CONFIG_MODEM_JWT is not set # CONFIG_MODEM_ATTEST_TOKEN is not set # CONFIG_LOCATION is not set # CONFIG_AT_SHELL is not set CONFIG_MODEM_ANTENNA=y CONFIG_MODEM_ANTENNA_GNSS_ONBOARD=y # CONFIG_MODEM_ANTENNA_GNSS_EXTERNAL is not set CONFIG_MODEM_ANTENNA_AT_MAGPIO="AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586" CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0=1,1,1565,1586" CONFIG_MODEM_ANTENNA_AT_MIPIRFFEDEV="" CONFIG_MODEM_ANTENNA_AT_MIPIRFFECTRL_INIT="" CONFIG_MODEM_ANTENNA_AT_MIPIRFFECTRL_ON="" CONFIG_MODEM_ANTENNA_AT_MIPIRFFECTRL_OFF="" CONFIG_MODEM_ANTENNA_AT_MIPIRFFECTRL_PWROFF="" # CONFIG_MODEM_ANTENNA_LOG_LEVEL_OFF is not set # CONFIG_MODEM_ANTENNA_LOG_LEVEL_ERR is not set # CONFIG_MODEM_ANTENNA_LOG_LEVEL_WRN is not set # CONFIG_MODEM_ANTENNA_LOG_LEVEL_INF is not set # CONFIG_MODEM_ANTENNA_LOG_LEVEL_DBG is not set CONFIG_MODEM_ANTENNA_LOG_LEVEL_DEFAULT=y CONFIG_MODEM_ANTENNA_LOG_LEVEL=3 # CONFIG_QOS is not set # CONFIG_SFLOAT is not set # CONFIG_CONTIN_ARRAY is not set # CONFIG_PCM_MIX is not set # CONFIG_TONE is not set # CONFIG_PSCM is not set # CONFIG_DATA_FIFO is not set # CONFIG_FEM_AL_LIB is not set # CONFIG_SAMPLE_RATE_CONVERTER is not set # end of Libraries # # Device Drivers # # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set # CONFIG_ETH_RTT is not set CONFIG_SENSOR=y # CONFIG_BH1749 is not set # CONFIG_SENSOR_SIM is not set # CONFIG_SENSOR_STUB is not set # CONFIG_PMW3360 is not set # CONFIG_PAW3212 is not set # CONFIG_BME68X_IAQ is not set # CONFIG_NRF_SW_LPUART is not set CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1 CONFIG_NET_TX_STACK_SIZE=1200 CONFIG_NET_RX_STACK_SIZE=1500 CONFIG_NET_TC_TX_COUNT=0 CONFIG_NET_INTERFACE_NAME_LEN=8 # end of Device Drivers # # External libraries # # end of External libraries # # Test # CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y # CONFIG_UNITY is not set # # Mocks # # CONFIG_MOCK_NRF_MODEM_AT is not set # end of Mocks # end of Test # end of Nordic nRF Connect CONFIG_ZEPHYR_NRF_MODULE=y # end of nrf (C:/ncs/v2.6.0/nrf) # # mcuboot (C:/ncs/v2.6.0/bootloader/mcuboot) # # # MCUboot # CONFIG_SIGN_IMAGES=y # CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set # CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set # CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y # CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4 CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4 # CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set # CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS is not set # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set # end of MCUboot CONFIG_ZEPHYR_MCUBOOT_MODULE=y # end of mcuboot (C:/ncs/v2.6.0/bootloader/mcuboot) # # mbedtls (C:/ncs/v2.6.0/modules/crypto/mbedtls) # CONFIG_ZEPHYR_MBEDTLS_MODULE=y # # PSA RNG support # # end of PSA RNG support # # PSA key type support # # end of PSA key type support # # PSA AEAD support # # end of PSA AEAD support # # PSA MAC support # # end of PSA MAC support # # PSA Hash support # # end of PSA Hash support # # PSA Cipher support # # end of PSA Cipher support # # PSA Key agreement support # # end of PSA Key agreement support # # PSA Key derivation support # # end of PSA Key derivation support # # PSA Asymmetric support # # # Elliptic Curve type support # # end of Elliptic Curve type support # end of PSA Asymmetric support # end of mbedtls (C:/ncs/v2.6.0/modules/crypto/mbedtls) # # trusted-firmware-m (C:/ncs/v2.6.0/modules/tee/tf-m/trusted-firmware-m) # CONFIG_TFM_BOARD="C:/ncs/v2.6.0/nrf/modules/trusted-firmware-m/tfm_boards/nrf9160" CONFIG_TFM_ISOLATION_LEVEL=1 # CONFIG_TFM_BL2 is not set # CONFIG_TFM_DUMMY_PROVISIONING is not set # CONFIG_TFM_REGRESSION_NS is not set # CONFIG_TFM_LOG_LEVEL_SILENCE is not set CONFIG_TFM_QCBOR_PATH="C:/ncs/v2.6.0/modules/tee/tf-m/trusted-firmware-m/../qcbor" CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y CONFIG_TFM_KEY_FILE_S="C:/ncs/v2.6.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072.pem" CONFIG_TFM_KEY_FILE_NS="C:/ncs/v2.6.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072_1.pem" # CONFIG_TFM_PROFILE_TYPE_NOT_SET is not set # CONFIG_TFM_PROFILE_TYPE_SMALL is not set # CONFIG_TFM_PROFILE_TYPE_MEDIUM is not set # CONFIG_TFM_PROFILE_TYPE_LARGE is not set # CONFIG_TFM_CMAKE_BUILD_TYPE_RELEASE is not set # CONFIG_TFM_CMAKE_BUILD_TYPE_RELWITHDEBINFO is not set CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y # CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG is not set # CONFIG_TFM_ITS_NUM_ASSETS_OVERRIDE is not set # CONFIG_TFM_ITS_MAX_ASSET_SIZE_OVERRIDE is not set CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT=y CONFIG_TFM_IMAGE_VERSION_S="0.0.0+0" CONFIG_TFM_IMAGE_VERSION_NS="0.0.0+0" # CONFIG_TFM_USE_NS_APP is not set # CONFIG_TFM_CONNECTION_BASED_SERVICE_API is not set # CONFIG_TFM_IPC is not set CONFIG_TFM_SFN=y # CONFIG_TFM_REGRESSION_S is not set # CONFIG_TFM_PSA_TEST_CRYPTO is not set # CONFIG_TFM_PSA_TEST_PROTECTED_STORAGE is not set # CONFIG_TFM_PSA_TEST_INTERNAL_TRUSTED_STORAGE is not set # CONFIG_TFM_PSA_TEST_STORAGE is not set # CONFIG_TFM_PSA_TEST_INITIAL_ATTESTATION is not set CONFIG_TFM_PSA_TEST_NONE=y # CONFIG_TFM_SPM_LOG_LEVEL_DEBUG is not set CONFIG_TFM_SPM_LOG_LEVEL_INFO=y # CONFIG_TFM_SPM_LOG_LEVEL_ERROR is not set # CONFIG_TFM_SPM_LOG_LEVEL_SILENCE is not set CONFIG_TFM_EXCEPTION_INFO_DUMP=y # # Platform partition component configs # CONFIG_TFM_PLATFORM_SERVICE_INPUT_BUFFER_SIZE=64 CONFIG_TFM_PLATFORM_SERVICE_OUTPUT_BUFFER_SIZE=64 CONFIG_TFM_PLATFORM_SP_STACK_SIZE=0x500 CONFIG_TFM_PLATFORM_NV_COUNTER_MODULE_DISABLED=y # end of Platform partition component configs # # Crypto component configs # # CONFIG_TFM_CRYPTO_SINGLE_PART_FUNCS_DISABLED is not set CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=1 CONFIG_TFM_CRYPTO_CONC_OPER_NUM=1 CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=1024 CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x800 # end of Crypto component configs # # TF-M SPM component configs # # end of TF-M SPM component configs # # TF-M memory regions # CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x8000 CONFIG_PM_PARTITION_SIZE_BL2=0 CONFIG_PM_PARTITION_SIZE_TFM=0x7E00 CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0 CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE=0 CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS=0 # end of TF-M memory regions # # Peripheral Secure mapping # # CONFIG_NRF_FPU_SECURE is not set # CONFIG_NRF_REGULATORS_SECURE is not set # CONFIG_NRF_CLOCK_SECURE is not set # CONFIG_NRF_POWER_SECURE is not set # CONFIG_NRF_SPIM0_SECURE is not set # CONFIG_NRF_TWIM0_SECURE is not set # CONFIG_NRF_UARTE0_SECURE is not set # CONFIG_NRF_SPIM1_SECURE is not set # CONFIG_NRF_TWIM1_SECURE is not set CONFIG_NRF_UARTE1_SECURE=y # CONFIG_NRF_SPIM2_SECURE is not set # CONFIG_NRF_TWIM2_SECURE is not set # CONFIG_NRF_UARTE2_SECURE is not set # CONFIG_NRF_SPIM3_SECURE is not set # CONFIG_NRF_TWIM3_SECURE is not set # CONFIG_NRF_UARTE3_SECURE is not set # CONFIG_NRF_SAADC_SECURE is not set # CONFIG_NRF_TIMER0_SECURE is not set # CONFIG_NRF_TIMER1_SECURE is not set # CONFIG_NRF_TIMER2_SECURE is not set # CONFIG_NRF_RTC0_SECURE is not set # CONFIG_NRF_RTC1_SECURE is not set # CONFIG_NRF_DPPI_SECURE is not set # CONFIG_NRF_WDT0_SECURE is not set # CONFIG_NRF_EGU0_SECURE is not set # CONFIG_NRF_EGU1_SECURE is not set # CONFIG_NRF_EGU2_SECURE is not set # CONFIG_NRF_EGU3_SECURE is not set # CONFIG_NRF_EGU4_SECURE is not set # CONFIG_NRF_EGU5_SECURE is not set # CONFIG_NRF_PWM0_SECURE is not set # CONFIG_NRF_PWM1_SECURE is not set # CONFIG_NRF_PWM2_SECURE is not set # CONFIG_NRF_PWM3_SECURE is not set # CONFIG_NRF_PDM_SECURE is not set # CONFIG_NRF_I2S_SECURE is not set # CONFIG_NRF_IPC_SECURE is not set # CONFIG_NRF_NVMC_SECURE is not set # CONFIG_NRF_GPIO0_SECURE is not set # CONFIG_NRF_VMC_SECURE is not set # CONFIG_NRF_GPIOTE0_SECURE is not set CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000000 CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000 # end of Peripheral Secure mapping CONFIG_TFM_PROFILE_TYPE_MINIMAL=y CONFIG_TFM_SECURE_UART=y # CONFIG_TFM_SECURE_UART_SHARE_INSTANCE is not set # CONFIG_TFM_SECURE_UART0 is not set CONFIG_TFM_SECURE_UART1=y # CONFIG_TFM_SECURE_UART22 is not set CONFIG_TFM_HW_INIT_RESET_ON_BOOT=y CONFIG_TFM_HW_INIT_NRF_PERIPHERALS=y # CONFIG_TFM_HALT_ON_CORE_PANIC is not set CONFIG_TFM_ALLOW_NON_SECURE_RESET=y CONFIG_TFM_ALLOW_NON_SECURE_FAULT_HANDLING=y CONFIG_TFM_S_CODE_VECTOR_TABLE_SIZE=0x144 # CONFIG_TFM_PSA_FRAMEWORK_HAS_MM_IOVEC is not set # end of trusted-firmware-m (C:/ncs/v2.6.0/modules/tee/tf-m/trusted-firmware-m) CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y # # cjson (C:/ncs/v2.6.0/modules/lib/cjson) # # CONFIG_CJSON_LIB is not set CONFIG_ZEPHYR_CJSON_MODULE=y # end of cjson (C:/ncs/v2.6.0/modules/lib/cjson) # # azure-sdk-for-c (C:/ncs/v2.6.0/modules/lib/azure-sdk-for-c) # # CONFIG_AZURE_SDK is not set CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y # end of azure-sdk-for-c (C:/ncs/v2.6.0/modules/lib/azure-sdk-for-c) # # cirrus-logic (C:/ncs/v2.6.0/modules/hal/cirrus-logic) # # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y # end of cirrus-logic (C:/ncs/v2.6.0/modules/hal/cirrus-logic) # # openthread (C:/ncs/v2.6.0/modules/lib/openthread) # # CONFIG_OPENTHREAD is not set CONFIG_ZEPHYR_OPENTHREAD_MODULE=y # end of openthread (C:/ncs/v2.6.0/modules/lib/openthread) # # memfault-firmware-sdk (C:/ncs/v2.6.0/modules/lib/memfault-firmware-sdk) # # CONFIG_MEMFAULT is not set CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y # end of memfault-firmware-sdk (C:/ncs/v2.6.0/modules/lib/memfault-firmware-sdk) # # canopennode (C:/ncs/v2.6.0/modules/lib/canopennode) # CONFIG_ZEPHYR_CANOPENNODE_MODULE=y # end of canopennode (C:/ncs/v2.6.0/modules/lib/canopennode) # # chre (C:/ncs/v2.6.0/modules/lib/chre) # CONFIG_ZEPHYR_CHRE_MODULE=y # CONFIG_CHRE is not set # end of chre (C:/ncs/v2.6.0/modules/lib/chre) # # lz4 (C:/ncs/v2.6.0/modules/lib/lz4) # CONFIG_ZEPHYR_LZ4_MODULE=y # CONFIG_LZ4 is not set # end of lz4 (C:/ncs/v2.6.0/modules/lib/lz4) # # nanopb (C:/ncs/v2.6.0/modules/lib/nanopb) # CONFIG_ZEPHYR_NANOPB_MODULE=y # CONFIG_NANOPB is not set # end of nanopb (C:/ncs/v2.6.0/modules/lib/nanopb) CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y # # zscilib (C:/ncs/v2.6.0/modules/lib/zscilib) # # CONFIG_ZSL is not set CONFIG_ZEPHYR_ZSCILIB_MODULE=y # end of zscilib (C:/ncs/v2.6.0/modules/lib/zscilib) # # cmsis (C:/ncs/v2.6.0/modules/hal/cmsis) # CONFIG_ZEPHYR_CMSIS_MODULE=y CONFIG_HAS_CMSIS_CORE=y CONFIG_HAS_CMSIS_CORE_M=y # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set # end of cmsis (C:/ncs/v2.6.0/modules/hal/cmsis) # # cmsis-dsp (C:/ncs/v2.6.0/modules/lib/cmsis-dsp) # CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y # CONFIG_CMSIS_DSP is not set # end of cmsis-dsp (C:/ncs/v2.6.0/modules/lib/cmsis-dsp) # # cmsis-nn (C:/ncs/v2.6.0/modules/lib/cmsis-nn) # CONFIG_ZEPHYR_CMSIS_NN_MODULE=y # CONFIG_CMSIS_NN is not set # end of cmsis-nn (C:/ncs/v2.6.0/modules/lib/cmsis-nn) # # fatfs (C:/ncs/v2.6.0/modules/fs/fatfs) # CONFIG_ZEPHYR_FATFS_MODULE=y # end of fatfs (C:/ncs/v2.6.0/modules/fs/fatfs) # # hal_nordic (C:/ncs/v2.6.0/modules/hal/nordic) # CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set CONFIG_HAS_NRFX=y # # nrfx drivers # # # nrfx drivers logging # # CONFIG_NRFX_CLOCK_LOG is not set # CONFIG_NRFX_DPPI_LOG is not set # CONFIG_NRFX_GPIOTE_LOG is not set # CONFIG_NRFX_IPC_LOG is not set # CONFIG_NRFX_NVMC_LOG is not set # CONFIG_NRFX_TWIM_LOG is not set # CONFIG_NRFX_WDT_LOG is not set # end of nrfx drivers logging CONFIG_NRFX_CLOCK=y CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y CONFIG_NRFX_DPPI=y # CONFIG_NRFX_EGU0 is not set # CONFIG_NRFX_EGU1 is not set # CONFIG_NRFX_EGU2 is not set # CONFIG_NRFX_EGU3 is not set # CONFIG_NRFX_EGU4 is not set # CONFIG_NRFX_EGU5 is not set CONFIG_NRFX_GPIOTE=y CONFIG_NRFX_GPIOTE1=y # CONFIG_NRFX_I2S0 is not set CONFIG_NRFX_IPC=y CONFIG_NRFX_NVMC=y # CONFIG_NRFX_PDM is not set # CONFIG_NRFX_POWER is not set # CONFIG_NRFX_PWM0 is not set # CONFIG_NRFX_PWM1 is not set # CONFIG_NRFX_PWM2 is not set # CONFIG_NRFX_PWM3 is not set # CONFIG_NRFX_RTC0 is not set # CONFIG_NRFX_RTC1 is not set # CONFIG_NRFX_SAADC is not set # CONFIG_NRFX_SPIM0 is not set # CONFIG_NRFX_SPIM1 is not set # CONFIG_NRFX_SPIM2 is not set # CONFIG_NRFX_SPIM3 is not set # CONFIG_NRFX_SYSTICK is not set # CONFIG_NRFX_TIMER0 is not set # CONFIG_NRFX_TIMER1 is not set # CONFIG_NRFX_TIMER2 is not set CONFIG_NRFX_TWIM=y # CONFIG_NRFX_TWIM0 is not set # CONFIG_NRFX_TWIM1 is not set CONFIG_NRFX_TWIM2=y # CONFIG_NRFX_TWIM3 is not set # CONFIG_NRFX_UARTE0 is not set # CONFIG_NRFX_UARTE1 is not set # CONFIG_NRFX_UARTE2 is not set # CONFIG_NRFX_UARTE3 is not set CONFIG_NRFX_WDT=y CONFIG_NRFX_WDT0=y # # Peripheral Resource Sharing module # # CONFIG_NRFX_PRS_BOX_0 is not set # CONFIG_NRFX_PRS_BOX_1 is not set # CONFIG_NRFX_PRS_BOX_2 is not set # CONFIG_NRFX_PRS_BOX_3 is not set # CONFIG_NRFX_PRS_BOX_4 is not set # end of Peripheral Resource Sharing module # end of nrfx drivers # end of hal_nordic (C:/ncs/v2.6.0/modules/hal/nordic) CONFIG_ZEPHYR_ST_MODULE=y CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y CONFIG_ZEPHYR_LIBMETAL_MODULE=y # # liblc3 (C:/ncs/v2.6.0/modules/lib/liblc3) # CONFIG_ZEPHYR_LIBLC3_MODULE=y # end of liblc3 (C:/ncs/v2.6.0/modules/lib/liblc3) # # littlefs (C:/ncs/v2.6.0/modules/fs/littlefs) # CONFIG_ZEPHYR_LITTLEFS_MODULE=y # end of littlefs (C:/ncs/v2.6.0/modules/fs/littlefs) # # loramac-node (C:/ncs/v2.6.0/modules/lib/loramac-node) # CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set # end of loramac-node (C:/ncs/v2.6.0/modules/lib/loramac-node) # # lvgl (C:/ncs/v2.6.0/modules/lib/gui/lvgl) # CONFIG_ZEPHYR_LVGL_MODULE=y # end of lvgl (C:/ncs/v2.6.0/modules/lib/gui/lvgl) CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y CONFIG_ZEPHYR_OPEN_AMP_MODULE=y # # picolibc (C:/ncs/v2.6.0/modules/lib/picolibc) # # CONFIG_PICOLIBC_MODULE is not set CONFIG_ZEPHYR_PICOLIBC_MODULE=y # end of picolibc (C:/ncs/v2.6.0/modules/lib/picolibc) # # segger (C:/ncs/v2.6.0/modules/debug/segger) # CONFIG_ZEPHYR_SEGGER_MODULE=y CONFIG_HAS_SEGGER_RTT=y # CONFIG_USE_SEGGER_RTT is not set # end of segger (C:/ncs/v2.6.0/modules/debug/segger) CONFIG_ZEPHYR_TINYCRYPT_MODULE=y # # uoscore-uedhoc (C:/ncs/v2.6.0/modules/lib/uoscore-uedhoc) # CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y # end of uoscore-uedhoc (C:/ncs/v2.6.0/modules/lib/uoscore-uedhoc) # # zcbor (C:/ncs/v2.6.0/modules/lib/zcbor) # CONFIG_ZEPHYR_ZCBOR_MODULE=y CONFIG_ZCBOR=y CONFIG_ZCBOR_CANONICAL=y # CONFIG_ZCBOR_STOP_ON_ERROR is not set # CONFIG_ZCBOR_VERBOSE is not set CONFIG_ZCBOR_ASSERT=y CONFIG_ZCBOR_MAX_STR_LEN=256 # end of zcbor (C:/ncs/v2.6.0/modules/lib/zcbor) # # nrfxlib (C:/ncs/v2.6.0/nrfxlib) # # # Nordic nrfxlib # # # nrf_modem (Modem library) # CONFIG_NRF_MODEM=y CONFIG_NRF_MODEM_LINK_BINARY=y # CONFIG_NRF_MODEM_LOG is not set # end of nrf_modem (Modem library) CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8 # CONFIG_NFC_T2T_NRFXLIB is not set # CONFIG_NFC_T4T_NRFXLIB is not set # # Crypto libraries for nRF5x SOCs. # CONFIG_HAS_HW_NRF_CC3XX=y CONFIG_NRF_OBERON=y # end of Crypto libraries for nRF5x SOCs. # CONFIG_NRF_RPC is not set CONFIG_NRF_802154_SOURCE_NRFXLIB=y # CONFIG_NRF_DM is not set # CONFIG_LC3_PLC_DISABLED is not set CONFIG_LC3_ENC_CHAN_MAX=1 CONFIG_LC3_DEC_CHAN_MAX=1 # # Encoder sample rates # CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y # end of Encoder sample rates # # Decoder sample rates # CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y # end of Decoder sample rates # CONFIG_NRF_FUEL_GAUGE is not set # end of Nordic nrfxlib CONFIG_ZEPHYR_NRFXLIB_MODULE=y # end of nrfxlib (C:/ncs/v2.6.0/nrfxlib) # # connectedhomeip (C:/ncs/v2.6.0/modules/lib/matter) # # CONFIG_CHIP is not set CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y # end of connectedhomeip (C:/ncs/v2.6.0/modules/lib/matter) # CONFIG_LIBMETAL is not set # CONFIG_LVGL is not set # CONFIG_HAS_MEC_HAL is not set # CONFIG_HAS_MPFS_HAL is not set # CONFIG_OPENAMP is not set # CONFIG_MIPI_SYST_LIB is not set # CONFIG_HAS_TELINK_DRIVERS is not set CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS="--quiet" CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="" CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.0.0" CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="" # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set # # On board MCUboot operation mode # # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set # end of On board MCUboot operation mode CONFIG_MCUBOOT_BOOTUTIL_LIB=y CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3 # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=8192 # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_OFF is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_ERR is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_WRN is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG is not set CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DEFAULT=y CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL=3 CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=6 # # Unavailable modules, please install those via the project manifest. # # # hal_gigadevice module not available. # # # Trusted-firmware-a module not available. # # # THRIFT module not available. # # CONFIG_ACPI is not set # end of Modules CONFIG_BOARD_REVISION="$BOARD_REVISION" # CONFIG_NET_DRIVERS is not set # CONFIG_BOARD_THINGY91_NRF9160 is not set CONFIG_THINGY91_STATIC_PARTITIONS_FACTORY=y # CONFIG_THINGY91_NO_PREDEFINED_LAYOUT is not set # # Board Options # CONFIG_BOARD_INIT_PRIORITY=80 # CONFIG_BOARD_LOG_LEVEL_OFF is not set # CONFIG_BOARD_LOG_LEVEL_ERR is not set # CONFIG_BOARD_LOG_LEVEL_WRN is not set # CONFIG_BOARD_LOG_LEVEL_INF is not set # CONFIG_BOARD_LOG_LEVEL_DBG is not set CONFIG_BOARD_LOG_LEVEL_DEFAULT=y CONFIG_BOARD_LOG_LEVEL=3 # end of Board Options # CONFIG_SOC_SERIES_APOLLO4X is not set # CONFIG_SOC_SERIES_BEETLE is not set # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set # CONFIG_SOC_SERIES_MPS2 is not set # CONFIG_SOC_SERIES_MPS3 is not set # CONFIG_SOC_SERIES_MUSCA_B1 is not set # CONFIG_SOC_SERIES_MUSCA_S1 is not set # CONFIG_SOC_SERIES_AST10X0 is not set # CONFIG_SOC_SERIES_SAMC20 is not set # CONFIG_SOC_SERIES_SAMC21 is not set # CONFIG_SOC_SERIES_SAMD20 is not set # CONFIG_SOC_SERIES_SAMD21 is not set # CONFIG_SOC_SERIES_SAMD51 is not set # CONFIG_SOC_SERIES_SAME51 is not set # CONFIG_SOC_SERIES_SAME53 is not set # CONFIG_SOC_SERIES_SAME54 is not set # CONFIG_SOC_SERIES_SAML21 is not set # CONFIG_SOC_SERIES_SAMR21 is not set # CONFIG_SOC_SERIES_SAMR34 is not set # CONFIG_SOC_SERIES_SAMR35 is not set # CONFIG_SOC_SERIES_SAM3X is not set # CONFIG_SOC_SERIES_SAM4E is not set # CONFIG_SOC_SERIES_SAM4L is not set # CONFIG_SOC_SERIES_SAM4S is not set # CONFIG_SOC_SERIES_SAME70 is not set # CONFIG_SOC_SERIES_SAMV71 is not set # CONFIG_SOC_SERIES_VALKYRIE is not set # CONFIG_SOC_SERIES_VIPER is not set # CONFIG_SOC_SERIES_PSOC62 is not set # CONFIG_SOC_SERIES_PSOC63 is not set # CONFIG_SOC_SERIES_GD32A50X is not set # CONFIG_SOC_SERIES_GD32E10X is not set # CONFIG_SOC_SERIES_GD32E50X is not set # CONFIG_SOC_SERIES_GD32F3X0 is not set # CONFIG_SOC_SERIES_GD32F403 is not set # CONFIG_SOC_SERIES_GD32F4XX is not set # CONFIG_SOC_SERIES_GD32L23X is not set # CONFIG_SOC_SERIES_PSOC_60 is not set # CONFIG_SOC_SERIES_PSOC_61 is not set # CONFIG_SOC_SERIES_PSOC_62 is not set # CONFIG_SOC_SERIES_PSOC_63 is not set # CONFIG_SOC_SERIES_PSOC_64 is not set # CONFIG_SOC_SERIES_XMC_4XXX is not set # CONFIG_SOC_SERIES_CYCLONE5 is not set # CONFIG_SOC_SERIES_MEC1501X is not set # CONFIG_SOC_SERIES_MEC172X is not set # CONFIG_SOC_SERIES_NRF51X is not set # CONFIG_SOC_SERIES_NRF52X is not set # CONFIG_SOC_SERIES_NRF53X is not set # CONFIG_SOC_SERIES_NRF54HX is not set # CONFIG_SOC_SERIES_NRF54LX is not set CONFIG_SOC_SERIES_NRF91X=y CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT=0x8000 CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000 CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT=0x2000 # CONFIG_SOC_SERIES_NPCX4 is not set # CONFIG_SOC_SERIES_NPCX7 is not set # CONFIG_SOC_SERIES_NPCX9 is not set # CONFIG_SOC_SERIES_M46X is not set # CONFIG_SOC_SERIES_M48X is not set # CONFIG_SOC_SERIES_IMX_6X_M4 is not set # CONFIG_SOC_SERIES_IMX7_M4 is not set # CONFIG_SOC_SERIES_IMX8ML_M7 is not set # CONFIG_SOC_SERIES_IMX8MM_M4 is not set # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set # CONFIG_SOC_SERIES_IMX_RT5XX is not set # CONFIG_SOC_SERIES_IMX_RT6XX is not set # CONFIG_SOC_SERIES_IMX_RT is not set # CONFIG_SOC_SERIES_KINETIS_K2X is not set # CONFIG_SOC_SERIES_KINETIS_K6X is not set # CONFIG_SOC_SERIES_KINETIS_K8X is not set # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set # CONFIG_SOC_SERIES_KINETIS_KL2X is not set # CONFIG_SOC_SERIES_KINETIS_KV5X is not set # CONFIG_SOC_SERIES_KINETIS_KWX is not set # CONFIG_SOC_SERIES_LPC11U6X is not set # CONFIG_SOC_SERIES_LPC51U68 is not set # CONFIG_SOC_SERIES_LPC54XXX is not set # CONFIG_SOC_SERIES_LPC55XXX is not set # CONFIG_SOC_SERIES_S32K3XX is not set # CONFIG_SOC_SERIES_S32ZE_R52 is not set # CONFIG_SOC_EOS_S3 is not set # CONFIG_SOC_SERIES_RA4M1 is not set # CONFIG_SOC_SERIES_RCAR_GEN3 is not set # CONFIG_SOC_RENESAS_RZT2M is not set # CONFIG_SOC_SERIES_DA1469X is not set # CONFIG_SOC_SERIES_RP2XXX is not set # CONFIG_SOC_SERIES_EFM32GG11B is not set # CONFIG_SOC_SERIES_EFM32GG12B is not set # CONFIG_SOC_SERIES_EFM32HG is not set # CONFIG_SOC_SERIES_EFM32JG12B is not set # CONFIG_SOC_SERIES_EFM32PG12B is not set # CONFIG_SOC_SERIES_EFM32PG1B is not set # CONFIG_SOC_SERIES_EFM32WG is not set # CONFIG_SOC_SERIES_EFR32BG13P is not set # CONFIG_SOC_SERIES_EFR32BG22 is not set # CONFIG_SOC_SERIES_EFR32BG27 is not set # CONFIG_SOC_SERIES_EFR32FG13P is not set # CONFIG_SOC_SERIES_EFR32FG1P is not set # CONFIG_SOC_SERIES_EFR32MG12P is not set # CONFIG_SOC_SERIES_EFR32MG21 is not set # CONFIG_SOC_SERIES_EFR32MG24 is not set # CONFIG_SOC_SERIES_STM32C0X is not set # CONFIG_SOC_SERIES_STM32F0X is not set # CONFIG_SOC_SERIES_STM32F1X is not set # CONFIG_SOC_SERIES_STM32F2X is not set # CONFIG_SOC_SERIES_STM32F3X is not set # CONFIG_SOC_SERIES_STM32F4X is not set # CONFIG_SOC_SERIES_STM32F7X is not set # CONFIG_SOC_SERIES_STM32G0X is not set # CONFIG_SOC_SERIES_STM32G4X is not set # CONFIG_SOC_SERIES_STM32H5X is not set # CONFIG_SOC_SERIES_STM32H7X is not set # CONFIG_SOC_SERIES_STM32L0X is not set # CONFIG_SOC_SERIES_STM32L1X is not set # CONFIG_SOC_SERIES_STM32L4X is not set # CONFIG_SOC_SERIES_STM32L5X is not set # CONFIG_SOC_SERIES_STM32MP1X is not set # CONFIG_SOC_SERIES_STM32U5X is not set # CONFIG_SOC_SERIES_STM32WBX is not set # CONFIG_SOC_SERIES_STM32WBAX is not set # CONFIG_SOC_SERIES_STM32WLX is not set # CONFIG_SOC_SERIES_AM62X_M4 is not set # CONFIG_SOC_TI_LM3S6965 is not set # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set # CONFIG_SOC_SERIES_CC32XX is not set # CONFIG_SOC_SERIES_MSP432P4XX is not set # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set # # Hardware Configuration # CONFIG_CPU_HAS_ARM_MPU=y CONFIG_CPU_HAS_NRF_IDAU=y CONFIG_SOC_FAMILY="nordic_nrf" CONFIG_GPIO_INIT_PRIORITY=40 CONFIG_SOC_FAMILY_NRF=y CONFIG_HAS_HW_NRF_CC310=y CONFIG_HAS_HW_NRF_CLOCK=y CONFIG_HAS_HW_NRF_DPPIC=y CONFIG_HAS_HW_NRF_EGU0=y CONFIG_HAS_HW_NRF_EGU1=y CONFIG_HAS_HW_NRF_EGU2=y CONFIG_HAS_HW_NRF_EGU3=y CONFIG_HAS_HW_NRF_EGU4=y CONFIG_HAS_HW_NRF_EGU5=y CONFIG_HAS_HW_NRF_GPIO0=y CONFIG_HAS_HW_NRF_GPIOTE1=y CONFIG_HAS_HW_NRF_IPC=y CONFIG_HAS_HW_NRF_KMU=y CONFIG_HAS_HW_NRF_NVMC_PE=y CONFIG_HAS_HW_NRF_POWER=y CONFIG_HAS_HW_NRF_REGULATORS=y CONFIG_HAS_HW_NRF_SAADC=y CONFIG_HAS_HW_NRF_TWIM2=y CONFIG_HAS_HW_NRF_UARTE0=y CONFIG_HAS_HW_NRF_VMC=y CONFIG_HAS_HW_NRF_WDT0=y CONFIG_NRF_ENABLE_ICACHE=y CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0 CONFIG_SOC_NRF9160=y CONFIG_SOC_NRF9160_SICA=y # CONFIG_SOC_NRF9161_LACA is not set # CONFIG_SOC_NRF9131_LACA is not set # CONFIG_SOC_NRF9151_LACA is not set CONFIG_NRF_SOC_SECURE_SUPPORTED=y CONFIG_TFM_NRF_NS_STORAGE=y CONFIG_NRF_APPROTECT_USE_UICR=y # CONFIG_NRF_APPROTECT_LOCK is not set # CONFIG_NRF_APPROTECT_USER_HANDLING is not set # CONFIG_NRF_TRACE_PORT is not set # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set # CONFIG_SOC_LOG_LEVEL_OFF is not set # CONFIG_SOC_LOG_LEVEL_ERR is not set # CONFIG_SOC_LOG_LEVEL_WRN is not set # CONFIG_SOC_LOG_LEVEL_INF is not set # CONFIG_SOC_LOG_LEVEL_DBG is not set CONFIG_SOC_LOG_LEVEL_DEFAULT=y CONFIG_SOC_LOG_LEVEL=3 # end of Hardware Configuration CONFIG_SOC_COMPATIBLE_NRF=y # # ARM Options # CONFIG_ARCH="arm" CONFIG_CPU_CORTEX=y # CONFIG_CODE_DATA_RELOCATION_SRAM is not set CONFIG_CPU_CORTEX_M=y # CONFIG_ARM_ZIMAGE_HEADER is not set CONFIG_ISA_THUMB2=y CONFIG_ASSEMBLER_ISA_THUMB2=y CONFIG_COMPILER_ISA_THUMB2=y CONFIG_STACK_ALIGN_DOUBLE_WORD=y # CONFIG_RUNTIME_NMI is not set CONFIG_FAULT_DUMP=2 CONFIG_BUILTIN_STACK_GUARD=y CONFIG_ARM_STACK_PROTECTION=y CONFIG_ARM_NONSECURE_FIRMWARE=y CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS=y CONFIG_ARM_STORE_EXC_RETURN=y CONFIG_FP16=y CONFIG_FP16_IEEE=y # CONFIG_FP16_ALT is not set CONFIG_CPU_CORTEX_M33=y CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y CONFIG_CPU_CORTEX_M_HAS_DWT=y CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y CONFIG_CPU_CORTEX_M_HAS_VTOR=y CONFIG_CPU_CORTEX_M_HAS_SPLIM=y CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y CONFIG_CPU_CORTEX_M_HAS_CMSE=y CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_SE=y CONFIG_ARMV7_M_ARMV8_M_FP=y CONFIG_ARMV8_M_DSP=y # # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options # CONFIG_GEN_ISR_TABLES=y # CONFIG_ZERO_LATENCY_IRQS is not set # CONFIG_SW_VECTOR_RELAY is not set # CONFIG_CORTEX_M_DWT is not set # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set # CONFIG_TRAP_UNALIGNED_ACCESS is not set # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y CONFIG_ARM_TRUSTZONE_M=y # # ARM TrustZone-M Options # # # Non-secure firmware # # CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS is not set # end of ARM TrustZone-M Options CONFIG_GEN_IRQ_VECTOR_TABLE=y CONFIG_ARM_MPU=y CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32 # CONFIG_MPU_STACK_GUARD is not set CONFIG_MPU_ALLOW_FLASH_WRITE=y # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set # CONFIG_CUSTOM_SECTION_ALIGN is not set CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32 # end of ARM Options CONFIG_ARM=y CONFIG_ARCH_IS_SET=y # # General Architecture Options # # CONFIG_SEMIHOST is not set # CONFIG_ARCH_LOG_LEVEL_OFF is not set # CONFIG_ARCH_LOG_LEVEL_ERR is not set # CONFIG_ARCH_LOG_LEVEL_WRN is not set # CONFIG_ARCH_LOG_LEVEL_INF is not set # CONFIG_ARCH_LOG_LEVEL_DBG is not set CONFIG_ARCH_LOG_LEVEL_DEFAULT=y CONFIG_ARCH_LOG_LEVEL=3 CONFIG_LITTLE_ENDIAN=y # CONFIG_TRUSTED_EXECUTION_SECURE is not set CONFIG_TRUSTED_EXECUTION_NONSECURE=y # CONFIG_USERSPACE is not set CONFIG_KOBJECT_TEXT_AREA=256 CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100 CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16 CONFIG_GEN_PRIV_STACKS=y # CONFIG_STACK_GROWS_UP is not set # # Interrupt Configuration # CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set # CONFIG_DYNAMIC_INTERRUPTS is not set # CONFIG_SHARED_INTERRUPTS is not set CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4 CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set CONFIG_GEN_SW_ISR_TABLE=y CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4 CONFIG_GEN_IRQ_START_VECTOR=0 # CONFIG_EXTRA_EXCEPTION_INFO is not set # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set # end of Interrupt Configuration # end of General Architecture Options CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y CONFIG_ARCH_HAS_STACK_PROTECTION=y CONFIG_ARCH_HAS_USERSPACE=y CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y CONFIG_ARCH_SUPPORTS_COREDUMP=y CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y CONFIG_ARCH_SUPPORTS_ROM_START=y CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y CONFIG_ARCH_HAS_THREAD_ABORT=y CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y CONFIG_CPU_HAS_TEE=y CONFIG_CPU_HAS_FPU=y CONFIG_CPU_HAS_MPU=y CONFIG_MPU=y # CONFIG_MPU_LOG_LEVEL_OFF is not set # CONFIG_MPU_LOG_LEVEL_ERR is not set # CONFIG_MPU_LOG_LEVEL_WRN is not set # CONFIG_MPU_LOG_LEVEL_INF is not set # CONFIG_MPU_LOG_LEVEL_DBG is not set CONFIG_MPU_LOG_LEVEL_DEFAULT=y CONFIG_MPU_LOG_LEVEL=3 CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y CONFIG_MPU_GAP_FILLING=y CONFIG_SRAM_REGION_PERMISSIONS=y # # Floating Point Options # # end of Floating Point Options # # Cache Options # # end of Cache Options CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y # CONFIG_ARCH_CPU_IDLE_CUSTOM is not set # # General Kernel Options # # CONFIG_KERNEL_LOG_LEVEL_OFF is not set # CONFIG_KERNEL_LOG_LEVEL_ERR is not set # CONFIG_KERNEL_LOG_LEVEL_WRN is not set # CONFIG_KERNEL_LOG_LEVEL_INF is not set # CONFIG_KERNEL_LOG_LEVEL_DBG is not set CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y CONFIG_KERNEL_LOG_LEVEL=3 CONFIG_MULTITHREADING=y CONFIG_NUM_COOP_PRIORITIES=16 CONFIG_NUM_PREEMPT_PRIORITIES=15 CONFIG_MAIN_THREAD_PRIORITY=0 CONFIG_COOP_ENABLED=y CONFIG_PREEMPT_ENABLED=y CONFIG_PRIORITY_CEILING=-127 # CONFIG_SCHED_DEADLINE is not set # CONFIG_SCHED_CPU_MASK is not set CONFIG_ISR_STACK_SIZE=2048 CONFIG_THREAD_STACK_INFO=y # CONFIG_THREAD_CUSTOM_DATA is not set # CONFIG_DYNAMIC_THREAD is not set CONFIG_LIBC_ERRNO=y CONFIG_ERRNO=y CONFIG_SCHED_DUMB=y # CONFIG_SCHED_SCALABLE is not set # CONFIG_SCHED_MULTIQ is not set # CONFIG_WAITQ_SCALABLE is not set CONFIG_WAITQ_DUMB=y # # Kernel Debugging and Metrics # CONFIG_BOOT_BANNER=y CONFIG_BOOT_DELAY=0 CONFIG_THREAD_MONITOR=y CONFIG_THREAD_NAME=y CONFIG_THREAD_MAX_NAME_LEN=32 # CONFIG_THREAD_RUNTIME_STATS is not set # end of Kernel Debugging and Metrics # CONFIG_OBJ_CORE is not set # # Work Queue Options # CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1 # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set # end of Work Queue Options # # Barrier Operations # CONFIG_BARRIER_OPERATIONS_ARCH=y # end of Barrier Operations # # Atomic Operations # CONFIG_ATOMIC_OPERATIONS_BUILTIN=y # end of Atomic Operations # # Timer API Options # CONFIG_TIMESLICING=y CONFIG_TIMESLICE_SIZE=0 CONFIG_TIMESLICE_PRIORITY=0 # CONFIG_TIMESLICE_PER_THREAD is not set CONFIG_POLL=y # end of Timer API Options # # Other Kernel Object Options # # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set CONFIG_NUM_MBOX_ASYNC_MSGS=10 # CONFIG_EVENTS is not set CONFIG_PIPES=y CONFIG_KERNEL_MEM_POOL=y # end of Other Kernel Object Options CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y CONFIG_SWAP_NONATOMIC=y CONFIG_SYS_CLOCK_EXISTS=y CONFIG_TIMEOUT_64BIT=y CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365 CONFIG_XIP=y # # Initialization Priorities # CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30 CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40 CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50 CONFIG_APPLICATION_INIT_PRIORITY=90 # end of Initialization Priorities # # Security Options # # CONFIG_STACK_CANARIES is not set CONFIG_STACK_POINTER_RANDOM=0 # end of Security Options # # SMP Options # CONFIG_MP_NUM_CPUS=1 # CONFIG_TICKET_SPINLOCKS is not set # end of SMP Options CONFIG_TICKLESS_KERNEL=y CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y CONFIG_THREAD_LOCAL_STORAGE=y # end of General Kernel Options # # Device Options # # CONFIG_DEVICE_DEPS is not set # CONFIG_DEVICE_MUTABLE is not set # end of Device Options # # Virtual Memory Support # # end of Virtual Memory Support # # Device Drivers # CONFIG_ADC=y # CONFIG_ADC_SHELL is not set CONFIG_ADC_CONFIGURABLE_INPUTS=y # CONFIG_ADC_ASYNC is not set # CONFIG_ADC_LOG_LEVEL_OFF is not set # CONFIG_ADC_LOG_LEVEL_ERR is not set # CONFIG_ADC_LOG_LEVEL_WRN is not set # CONFIG_ADC_LOG_LEVEL_INF is not set # CONFIG_ADC_LOG_LEVEL_DBG is not set CONFIG_ADC_LOG_LEVEL_DEFAULT=y CONFIG_ADC_LOG_LEVEL=3 CONFIG_ADC_NRFX_SAADC=y CONFIG_ADC_ADS1X1X=y CONFIG_ADC_ADS1X1X_INIT_PRIORITY=80 CONFIG_ADC_ADS1X1X_ACQUISITION_THREAD_PRIO=0 CONFIG_ADC_ADS1X1X_ACQUISITION_THREAD_STACK_SIZE=1024 # CONFIG_AUDIO is not set # CONFIG_AUXDISPLAY is not set # CONFIG_BBRAM is not set # CONFIG_CACHE is not set # CONFIG_CAN is not set # CONFIG_CHARGER is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y CONFIG_CLOCK_CONTROL_LOG_LEVEL=3 CONFIG_CLOCK_CONTROL_NRF=y # CONFIG_CLOCK_CONTROL_NRF_SHELL is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50 # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set CONFIG_CLOCK_CONTROL_NPCX_SUPP_APB4=y # CONFIG_CLOCK_CONTROL_NPCX_SUPP_FIU1 is not set CONFIG_CONSOLE=y CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128 CONFIG_CONSOLE_HAS_DRIVER=y # CONFIG_CONSOLE_HANDLER is not set CONFIG_CONSOLE_INIT_PRIORITY=60 CONFIG_UART_CONSOLE=y # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set # CONFIG_UART_CONSOLE_MCUMGR is not set # CONFIG_RAM_CONSOLE is not set # CONFIG_IPM_CONSOLE_SENDER is not set # CONFIG_IPM_CONSOLE_RECEIVER is not set # CONFIG_UART_MCUMGR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y CONFIG_UART_CONSOLE_LOG_LEVEL=3 # CONFIG_GSM_MUX is not set # CONFIG_EFI_CONSOLE is not set # CONFIG_COREDUMP_DEVICE is not set # CONFIG_COUNTER is not set # CONFIG_CRYPTO is not set # CONFIG_DAC is not set # CONFIG_DAI is not set # CONFIG_DISK_DRIVERS is not set # CONFIG_DISPLAY is not set # CONFIG_DMA is not set # CONFIG_EDAC is not set # CONFIG_EEPROM is not set CONFIG_ENTROPY_GENERATOR=y # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set # CONFIG_ENTROPY_LOG_LEVEL_INF is not set # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y CONFIG_ENTROPY_LOG_LEVEL=3 CONFIG_ENTROPY_INIT_PRIORITY=50 CONFIG_ENTROPY_PSA_CRYPTO_RNG=y CONFIG_ENTROPY_HAS_DRIVER=y # CONFIG_ESPI is not set CONFIG_FLASH_HAS_DRIVER_ENABLED=y CONFIG_FLASH_HAS_PAGE_LAYOUT=y CONFIG_FLASH=y # CONFIG_FLASH_LOG_LEVEL_OFF is not set # CONFIG_FLASH_LOG_LEVEL_ERR is not set # CONFIG_FLASH_LOG_LEVEL_WRN is not set # CONFIG_FLASH_LOG_LEVEL_INF is not set # CONFIG_FLASH_LOG_LEVEL_DBG is not set CONFIG_FLASH_LOG_LEVEL_DEFAULT=y CONFIG_FLASH_LOG_LEVEL=3 # CONFIG_FLASH_SHELL is not set CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_INIT_PRIORITY=50 CONFIG_SOC_FLASH_NRF=y CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set # CONFIG_FPGA is not set # CONFIG_FUEL_GAUGE is not set # CONFIG_GPIO_LOG_LEVEL_OFF is not set # CONFIG_GPIO_LOG_LEVEL_ERR is not set # CONFIG_GPIO_LOG_LEVEL_WRN is not set # CONFIG_GPIO_LOG_LEVEL_INF is not set # CONFIG_GPIO_LOG_LEVEL_DBG is not set CONFIG_GPIO_LOG_LEVEL_DEFAULT=y CONFIG_GPIO_LOG_LEVEL=3 # CONFIG_GPIO_SHELL is not set # CONFIG_GPIO_GET_DIRECTION is not set # CONFIG_GPIO_GET_CONFIG is not set # CONFIG_GPIO_HOGS is not set # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set CONFIG_GPIO_NRFX=y CONFIG_GPIO_NRFX_INTERRUPT=y # CONFIG_HWINFO is not set # CONFIG_HWSPINLOCK is not set CONFIG_I2C=y # CONFIG_I2C_SHELL is not set # CONFIG_I2C_CALLBACK is not set # CONFIG_I2C_RTIO is not set # CONFIG_I2C_DW_LPSS_DMA is not set # CONFIG_I2C_TARGET is not set CONFIG_I2C_NRFX=y CONFIG_I2C_NRFX_TWIM=y CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500 CONFIG_I2C_INIT_PRIORITY=50 # CONFIG_I2C_LOG_LEVEL_OFF is not set # CONFIG_I2C_LOG_LEVEL_ERR is not set # CONFIG_I2C_LOG_LEVEL_WRN is not set # CONFIG_I2C_LOG_LEVEL_INF is not set # CONFIG_I2C_LOG_LEVEL_DBG is not set CONFIG_I2C_LOG_LEVEL_DEFAULT=y CONFIG_I2C_LOG_LEVEL=3 # CONFIG_I2S is not set # CONFIG_I3C is not set # CONFIG_IEEE802154 is not set # # Interrupt controller drivers # CONFIG_INTC_INIT_PRIORITY=40 # CONFIG_INTC_LOG_LEVEL_OFF is not set # CONFIG_INTC_LOG_LEVEL_ERR is not set # CONFIG_INTC_LOG_LEVEL_WRN is not set # CONFIG_INTC_LOG_LEVEL_INF is not set # CONFIG_INTC_LOG_LEVEL_DBG is not set CONFIG_INTC_LOG_LEVEL_DEFAULT=y CONFIG_INTC_LOG_LEVEL=3 # CONFIG_MULTI_LEVEL_INTERRUPTS is not set CONFIG_1ST_LEVEL_INTERRUPT_BITS=8 CONFIG_2ND_LEVEL_INTERRUPT_BITS=8 CONFIG_3RD_LEVEL_INTERRUPT_BITS=8 # CONFIG_INTC_ESP32 is not set # end of Interrupt controller drivers # CONFIG_IPM is not set # CONFIG_KSCAN is not set # CONFIG_LED is not set # CONFIG_LED_STRIP is not set # CONFIG_LORA is not set # CONFIG_MDIO is not set # CONFIG_MFD is not set # # Miscellaneous Drivers # # CONFIG_GROVE_LCD_RGB is not set # CONFIG_TIMEAWARE_GPIO is not set # end of Miscellaneous Drivers # CONFIG_MM_DRV is not set # CONFIG_PCIE is not set # CONFIG_PCIE_ENDPOINT is not set # CONFIG_PECI is not set # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set # CONFIG_PINCTRL_LOG_LEVEL_INF is not set # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y CONFIG_PINCTRL_LOG_LEVEL=3 CONFIG_PINCTRL_STORE_REG=y # CONFIG_PINCTRL_DYNAMIC is not set CONFIG_PINCTRL_NRF=y # CONFIG_PM_CPU_OPS is not set # CONFIG_POWER_DOMAIN is not set # CONFIG_PS2 is not set # CONFIG_PTP_CLOCK is not set # CONFIG_PWM is not set CONFIG_REGULATOR_THREAD_SAFE_REFCNT=y # CONFIG_REGULATOR_SHELL is not set # CONFIG_REGULATOR_LOG_LEVEL_OFF is not set # CONFIG_REGULATOR_LOG_LEVEL_ERR is not set # CONFIG_REGULATOR_LOG_LEVEL_WRN is not set # CONFIG_REGULATOR_LOG_LEVEL_INF is not set # CONFIG_REGULATOR_LOG_LEVEL_DBG is not set CONFIG_REGULATOR_LOG_LEVEL_DEFAULT=y CONFIG_REGULATOR_LOG_LEVEL=3 CONFIG_REGULATOR_ADP5360=y CONFIG_REGULATOR_ADP5360_INIT_PRIORITY=76 # CONFIG_REGULATOR_NXP_VREF is not set CONFIG_REGULATOR_NXP_VREF_INIT_PRIORITY=45 # CONFIG_RETAINED_MEM is not set # CONFIG_RTC is not set # CONFIG_SDHC is not set # CONFIG_SENSOR_LOG_LEVEL_OFF is not set # CONFIG_SENSOR_LOG_LEVEL_ERR is not set # CONFIG_SENSOR_LOG_LEVEL_WRN is not set # CONFIG_SENSOR_LOG_LEVEL_INF is not set # CONFIG_SENSOR_LOG_LEVEL_DBG is not set CONFIG_SENSOR_LOG_LEVEL_DEFAULT=y CONFIG_SENSOR_LOG_LEVEL=3 CONFIG_SENSOR_INIT_PRIORITY=90 # CONFIG_SENSOR_ASYNC_API is not set # CONFIG_SENSOR_SHELL is not set # CONFIG_SENSOR_SHELL_BATTERY is not set # CONFIG_SENSOR_INFO is not set # # Device Drivers # # CONFIG_ICM42688_DECODER is not set CONFIG_VCMP_IT8XXX2_INIT_PRIORITY=90 CONFIG_SHT4X=y CONFIG_TMP112_FULL_SCALE_RUNTIME=y CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y # # Capabilities # CONFIG_SERIAL_HAS_DRIVER=y CONFIG_SERIAL_SUPPORT_ASYNC=y CONFIG_SERIAL_SUPPORT_INTERRUPT=y # CONFIG_UART_LOG_LEVEL_OFF is not set # CONFIG_UART_LOG_LEVEL_ERR is not set # CONFIG_UART_LOG_LEVEL_WRN is not set # CONFIG_UART_LOG_LEVEL_INF is not set # CONFIG_UART_LOG_LEVEL_DBG is not set CONFIG_UART_LOG_LEVEL_DEFAULT=y CONFIG_UART_LOG_LEVEL=3 # CONFIG_UART_ASYNC_API is not set # CONFIG_UART_LINE_CTRL is not set # CONFIG_UART_DRV_CMD is not set # CONFIG_UART_WIDE_DATA is not set # CONFIG_UART_PIPE is not set # CONFIG_UART_ASYNC_RX_HELPER is not set # # Serial Drivers # CONFIG_UART_NRFX=y CONFIG_UART_NRFX_UARTE=y CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y CONFIG_UART_0_INTERRUPT_DRIVEN=y CONFIG_UART_0_ENHANCED_POLL_OUT=y # CONFIG_UART_0_NRF_PARITY_BIT is not set CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32 CONFIG_UART_0_GPIO_MANAGEMENT=y # CONFIG_SMBUS is not set # CONFIG_SPI_ASYNC is not set # CONFIG_SPI_RTIO is not set # CONFIG_SPI_SLAVE is not set # CONFIG_SPI_EXTENDED_MODES is not set CONFIG_SPI_INIT_PRIORITY=70 CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200 # CONFIG_SPI_LOG_LEVEL_OFF is not set # CONFIG_SPI_LOG_LEVEL_ERR is not set # CONFIG_SPI_LOG_LEVEL_WRN is not set # CONFIG_SPI_LOG_LEVEL_INF is not set # CONFIG_SPI_LOG_LEVEL_DBG is not set CONFIG_SPI_LOG_LEVEL_DEFAULT=y CONFIG_SPI_LOG_LEVEL=3 CONFIG_SPI_NRFX=y CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200 # CONFIG_SYSCON is not set # # Timer drivers # # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0 CONFIG_TICKLESS_CAPABLE=y CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set # CONFIG_NRF_GRTC_TIMER is not set # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y # end of Timer drivers # CONFIG_USB_BC12 is not set # CONFIG_UDC_DRIVER is not set # CONFIG_UHC_DRIVER is not set # CONFIG_UVB is not set # CONFIG_USB_DEVICE_DRIVER is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3 # CONFIG_USBC_TCPC_DRIVER is not set # CONFIG_USBC_LOG_LEVEL_OFF is not set # CONFIG_USBC_LOG_LEVEL_ERR is not set # CONFIG_USBC_LOG_LEVEL_WRN is not set # CONFIG_USBC_LOG_LEVEL_INF is not set # CONFIG_USBC_LOG_LEVEL_DBG is not set CONFIG_USBC_LOG_LEVEL_DEFAULT=y CONFIG_USBC_LOG_LEVEL=3 # CONFIG_USBC_VBUS_DRIVER is not set # CONFIG_VIDEO is not set # CONFIG_VIRTUALIZATION is not set # CONFIG_W1 is not set # CONFIG_WDT_DISABLE_AT_BOOT is not set # CONFIG_WDT_LOG_LEVEL_OFF is not set # CONFIG_WDT_LOG_LEVEL_ERR is not set # CONFIG_WDT_LOG_LEVEL_WRN is not set # CONFIG_WDT_LOG_LEVEL_INF is not set # CONFIG_WDT_LOG_LEVEL_DBG is not set CONFIG_WDT_LOG_LEVEL_DEFAULT=y CONFIG_WDT_LOG_LEVEL=3 CONFIG_WDT_NRFX=y # CONFIG_WDT_SHELL is not set # end of Device Drivers CONFIG_REQUIRES_FULL_LIBC=y # CONFIG_REQUIRES_FLOAT_PRINTF is not set CONFIG_FULL_LIBC_SUPPORTED=y CONFIG_MINIMAL_LIBC_SUPPORTED=y CONFIG_NEWLIB_LIBC_SUPPORTED=y CONFIG_PICOLIBC_SUPPORTED=y # # C Library # CONFIG_PICOLIBC=y # CONFIG_NEWLIB_LIBC is not set # CONFIG_EXTERNAL_LIBC is not set CONFIG_HAS_NEWLIB_LIBC_NANO=y CONFIG_COMMON_LIBC_ABORT=y CONFIG_COMMON_LIBC_MALLOC=y CONFIG_COMMON_LIBC_CALLOC=y CONFIG_COMMON_LIBC_REALLOCARRAY=y # CONFIG_PICOLIBC_USE_MODULE is not set CONFIG_PICOLIBC_USE_TOOLCHAIN=y CONFIG_PICOLIBC_HEAP_SIZE=-2 # CONFIG_PICOLIBC_IO_FLOAT is not set CONFIG_PICOLIBC_IO_LONG_LONG=y CONFIG_STDOUT_CONSOLE=y CONFIG_NEED_LIBC_MEM_PARTITION=y # end of C Library # # C++ Language Support # # CONFIG_CPP is not set # # Deprecated # # CONFIG_CPLUSPLUS is not set # CONFIG_LIB_CPLUSPLUS is not set # end of Deprecated # end of C++ Language Support CONFIG_CRC=y # CONFIG_CRC_SHELL is not set # # Additional libraries # # # Hash Function Support # CONFIG_SYS_HASH_FUNC32=y # CONFIG_SYS_HASH_FUNC32_DJB2 is not set CONFIG_SYS_HASH_FUNC32_MURMUR3=y # CONFIG_SYS_HASH_FUNC32_CHOICE_DJB2 is not set CONFIG_SYS_HASH_FUNC32_CHOICE_MURMUR3=y # CONFIG_SYS_HASH_FUNC32_CHOICE_IDENTITY is not set # end of Hash Function Support # # Hashmap (Hash Table) Support # # CONFIG_SYS_HASH_MAP is not set # end of Hashmap (Hash Table) Support # # OS Support Library # CONFIG_FDTABLE=y CONFIG_JSON_LIBRARY=y CONFIG_RING_BUFFER=y CONFIG_NOTIFY=y CONFIG_BASE64=y # CONFIG_PRINTK_SYNC is not set CONFIG_MPSC_PBUF=y CONFIG_ONOFF=y # CONFIG_SPSC_PBUF is not set # CONFIG_SHARED_MULTI_HEAP is not set # CONFIG_WINSTREAM is not set # CONFIG_MPSC_CLEAR_ALLOCATED is not set CONFIG_REBOOT=y CONFIG_HAS_POWEROFF=y # CONFIG_POWEROFF is not set # CONFIG_UTF8 is not set CONFIG_CBPRINTF_COMPLETE=y # CONFIG_CBPRINTF_NANO is not set CONFIG_CBPRINTF_FULL_INTEGRAL=y # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set # CONFIG_CBPRINTF_FP_SUPPORT is not set # CONFIG_CBPRINTF_FP_A_SUPPORT is not set # CONFIG_CBPRINTF_LIBC_SUBSTS is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3 # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y # # Heap and Memory Allocation # # CONFIG_SYS_HEAP_VALIDATE is not set CONFIG_SYS_HEAP_ALLOC_LOOPS=3 # CONFIG_SYS_HEAP_RUNTIME_STATS is not set # CONFIG_SYS_HEAP_LISTENER is not set # CONFIG_SYS_HEAP_SMALL_ONLY is not set # CONFIG_SYS_HEAP_BIG_ONLY is not set CONFIG_SYS_HEAP_AUTO=y # CONFIG_SYS_MEM_BLOCKS is not set # end of Heap and Memory Allocation # end of OS Support Library # CONFIG_POSIX_API is not set # CONFIG_PTHREAD_IPC is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_BARRIER_LOG_LEVEL=3 CONFIG_POSIX_CLOCK=y # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_COND_LOG_LEVEL=3 # CONFIG_EVENTFD is not set CONFIG_FNMATCH=y # CONFIG_GETOPT_LONG is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_KEY_LOG_LEVEL=3 # CONFIG_POSIX_MQUEUE is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_MUTEX_LOG_LEVEL=3 # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_LOG_LEVEL=3 CONFIG_SEM_VALUE_MAX=32767 # CONFIG_POSIX_SIGNAL is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=3 # CONFIG_TIMER_LOG_LEVEL_OFF is not set # CONFIG_TIMER_LOG_LEVEL_ERR is not set # CONFIG_TIMER_LOG_LEVEL_WRN is not set # CONFIG_TIMER_LOG_LEVEL_INF is not set # CONFIG_TIMER_LOG_LEVEL_DBG is not set CONFIG_TIMER_LOG_LEVEL_DEFAULT=y CONFIG_TIMER_LOG_LEVEL=3 # CONFIG_TIMER is not set CONFIG_MAX_TIMER_COUNT=5 CONFIG_TIMER_CREATE_WAIT=100 CONFIG_TIMER_DELAYTIMER_MAX=20 # CONFIG_POSIX_UNAME is not set # CONFIG_OPENAMP_RSC_TABLE is not set # CONFIG_SMF is not set CONFIG_ACPI_HID_LEN_MAX=12 CONFIG_LIBGCC_RTLIB=y # end of Additional libraries # # Subsystems and OS Services # # CONFIG_BINDESC is not set # CONFIG_BT is not set # # Controller Area Network (CAN) bus subsystem # # end of Controller Area Network (CAN) bus subsystem # CONFIG_CONSOLE_SUBSYS is not set # # System Monitoring Options # # CONFIG_THREAD_ANALYZER is not set # end of System Monitoring Options # # Debugging Options # # CONFIG_DEBUG is not set # CONFIG_STACK_USAGE is not set # CONFIG_STACK_SENTINEL is not set CONFIG_PRINTK=y CONFIG_EARLY_CONSOLE=y CONFIG_ASSERT=y CONFIG_ASSERT_LEVEL=2 CONFIG_SPIN_VALIDATE=y # CONFIG_FORCE_NO_ASSERT is not set CONFIG_ASSERT_VERBOSE=y # CONFIG_ASSERT_NO_FILE_INFO is not set # CONFIG_ASSERT_NO_COND_INFO is not set # CONFIG_ASSERT_NO_MSG_INFO is not set # CONFIG_ASSERT_TEST is not set # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set # CONFIG_DEBUG_INFO is not set # CONFIG_DEBUG_THREAD_INFO is not set # CONFIG_DEBUG_COREDUMP is not set # end of Debugging Options CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y # CONFIG_MCUBOOT_SHELL is not set CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y CONFIG_IMG_BLOCK_BUF_SIZE=512 # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y CONFIG_IMG_MANAGER_LOG_LEVEL=3 # CONFIG_DISK_ACCESS is not set # CONFIG_DSP is not set # CONFIG_EMUL is not set # CONFIG_CHARACTER_FRAMEBUFFER is not set # # File Systems # # CONFIG_FILE_SYSTEM is not set CONFIG_FCB=y # CONFIG_FCB_ALLOW_FIXED_ENDMARKER is not set # CONFIG_NVS is not set # end of File Systems # # Inter Processor Communication # # CONFIG_RPMSG_SERVICE is not set # CONFIG_IPC_SERVICE is not set # end of Inter Processor Communication # CONFIG_JWT is not set # CONFIG_LLEXT is not set # # Logging # CONFIG_LOG=y CONFIG_LOG_CORE_INIT_PRIORITY=0 CONFIG_LOG_MODE_DEFERRED=y # CONFIG_LOG_MODE_IMMEDIATE is not set # CONFIG_LOG_MODE_MINIMAL is not set # CONFIG_LOG_FRONTEND is not set # CONFIG_LOG_FRONTEND_OPT_API is not set # CONFIG_LOG_CUSTOM_HEADER is not set # CONFIG_LOG_MULTIDOMAIN is not set # # Logging levels filtering # CONFIG_LOG_RUNTIME_FILTERING=y CONFIG_LOG_DEFAULT_LEVEL=3 CONFIG_LOG_OVERRIDE_LEVEL=0 CONFIG_LOG_MAX_LEVEL=4 # end of Logging levels filtering # # Processing # CONFIG_LOG_PRINTK=y CONFIG_LOG_MODE_OVERFLOW=y # CONFIG_LOG_BLOCK_IN_THREAD is not set CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10 CONFIG_LOG_PROCESS_THREAD=y CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0 CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000 CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048 # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y # CONFIG_LOG_TIMESTAMP_64BIT is not set # CONFIG_LOG_SPEED is not set # end of Processing # # Output Formatting # # # Prepend non-hexdump log message with function name # # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y # end of Prepend non-hexdump log message with function name # CONFIG_LOG_MIPI_SYST_ENABLE is not set # CONFIG_LOG_THREAD_ID_PREFIX is not set # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set CONFIG_LOG_TAG_MAX_LEN=0 # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set # end of Output Formatting # # Backends # # CONFIG_LOG_BACKEND_NET is not set # CONFIG_LOG_BACKEND_UART is not set # CONFIG_LOG_BACKEND_IPC_SERVICE is not set # end of Backends # # Misc # CONFIG_LOG_DOMAIN_ID=0 # CONFIG_LOG_CMDS is not set CONFIG_LOG_USE_VLA=y CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y # CONFIG_LOG_ALWAYS_RUNTIME is not set # CONFIG_LOG_FMT_SECTION is not set # CONFIG_LOG_MEM_UTILIZATION is not set CONFIG_LOG_FAILURE_REPORT_PERIOD=1000 # end of Misc CONFIG_LOG_OUTPUT=y # end of Logging CONFIG_MEM_ATTR=y # # Device Management # # # Host command handler subsystem # # CONFIG_EC_HOST_CMD is not set # end of Host command handler subsystem # CONFIG_MCUMGR is not set # CONFIG_OSDP is not set # end of Device Management # CONFIG_MODBUS is not set # CONFIG_MODEM_MODULES is not set # # Networking # CONFIG_NET_BUF=y # CONFIG_NET_BUF_LOG is not set # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set # CONFIG_NET_BUF_LOG_LEVEL_INF is not set # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y CONFIG_NET_BUF_LOG_LEVEL=3 # CONFIG_NET_BUF_POOL_USAGE is not set CONFIG_NETWORKING=y # CONFIG_NET_HOSTNAME_ENABLE is not set # # Link layer options # # CONFIG_NET_L2_DUMMY is not set # CONFIG_NET_L2_BT_SHELL is not set # CONFIG_NET_L2_VIRTUAL is not set # CONFIG_NET_L2_PPP is not set # CONFIG_NET_L2_OPENTHREAD is not set # CONFIG_NET_L2_CUSTOM_IEEE802154 is not set # CONFIG_NET_L2_CANBUS_RAW is not set # CONFIG_NET_L2_WIFI_MGMT is not set # CONFIG_NET_L2_WIFI_SHELL is not set # CONFIG_NET_L2_PTP is not set # end of Link layer options # # IP stack # CONFIG_NET_IP=y # CONFIG_NET_NATIVE is not set # CONFIG_NET_OFFLOAD is not set CONFIG_NET_OFFLOADING_SUPPORT=y CONFIG_NET_INIT_PRIO=90 CONFIG_NET_IP_DSCP_ECN=y CONFIG_NET_IPV4=y CONFIG_NET_INITIAL_TTL=64 CONFIG_NET_IF_MAX_IPV4_COUNT=1 CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1 CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1 # CONFIG_NET_ICMPV4_ACCEPT_BROADCAST is not set # CONFIG_NET_IPV4_ACCEPT_ZERO_BROADCAST is not set # CONFIG_NET_IPV4_IGMP is not set # CONFIG_NET_DHCPV4 is not set # CONFIG_NET_IPV4_HDR_OPTIONS is not set # CONFIG_NET_IPV4_FRAGMENT is not set CONFIG_NET_IPV4_LOG_LEVEL=0 CONFIG_NET_ICMPV4_LOG_LEVEL=0 # CONFIG_NET_SHELL is not set CONFIG_NET_TC_RX_COUNT=1 # CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set CONFIG_NET_TC_THREAD_COOPERATIVE=y # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set CONFIG_NET_TC_NUM_PRIORITIES=16 CONFIG_NET_TC_MAPPING_STRICT=y CONFIG_NET_TX_DEFAULT_PRIORITY=1 CONFIG_NET_RX_DEFAULT_PRIORITY=0 # CONFIG_NET_ALLOW_ANY_PRIORITY is not set CONFIG_NET_IP_ADDR_CHECK=y CONFIG_NET_MAX_ROUTERS=1 # CONFIG_NET_TCP is not set CONFIG_NET_TCP_REJECT_CONN_WITH_RST=y # CONFIG_NET_TEST_PROTOCOL is not set CONFIG_NET_UDP=y CONFIG_NET_UDP_MISSING_CHECKSUM=y CONFIG_NET_UDP_LOG_LEVEL=0 CONFIG_NET_MAX_CONN=4 CONFIG_NET_MAX_CONTEXTS=6 # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set CONFIG_NET_CONTEXT_SYNC_RECV=y CONFIG_NET_CONTEXT_CHECK=y # CONFIG_NET_CONTEXT_PRIORITY is not set # CONFIG_NET_CONTEXT_TXTIME is not set # CONFIG_NET_CONTEXT_RCVTIMEO is not set # CONFIG_NET_CONTEXT_SNDTIMEO is not set # CONFIG_NET_CONTEXT_RCVBUF is not set # CONFIG_NET_CONTEXT_SNDBUF is not set CONFIG_NET_CONTEXT_DSCP_ECN=y CONFIG_NET_CONTEXT_REUSEADDR=y CONFIG_NET_CONTEXT_REUSEPORT=y # CONFIG_NET_TEST is not set CONFIG_NET_BUF_RX_COUNT=16 CONFIG_NET_BUF_TX_COUNT=16 CONFIG_NET_BUF_FIXED_DATA_SIZE=y # CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set CONFIG_NET_BUF_DATA_SIZE=128 CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4 CONFIG_NET_DEFAULT_IF_FIRST=y # CONFIG_NET_DEFAULT_IF_UP is not set CONFIG_NET_INTERFACE_NAME=y # CONFIG_NET_PROMISCUOUS_MODE is not set # CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set # # Stack usage # # end of Stack usage # CONFIG_NET_MGMT is not set # CONFIG_NET_STATISTICS is not set # CONFIG_NET_LOG is not set CONFIG_NET_PKT_LOG_LEVEL=0 # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0 # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set CONFIG_NET_CORE_LOG_LEVEL=0 CONFIG_NET_IF_LOG_LEVEL=0 CONFIG_NET_TC_LOG_LEVEL=0 CONFIG_NET_UTILS_LOG_LEVEL=0 CONFIG_NET_CONTEXT_LOG_LEVEL=0 CONFIG_NET_CONN_LOG_LEVEL=0 CONFIG_NET_ROUTE_LOG_LEVEL=0 # end of IP stack # # Network Packet Filtering # # CONFIG_NET_PKT_FILTER is not set # end of Network Packet Filtering # # Network Protocols # CONFIG_COAP=y # CONFIG_COAP_TEST_API_ENABLE is not set # CONFIG_COAP_WELL_KNOWN_BLOCK_WISE is not set CONFIG_COAP_EXTENDED_OPTIONS_LEN=y CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=40 CONFIG_COAP_RANDOMIZE_ACK_TIMEOUT=y CONFIG_COAP_ACK_RANDOM_PERCENT=150 CONFIG_COAP_MAX_RETRANSMIT=4 CONFIG_COAP_BACKOFF_PERCENT=200 CONFIG_COAP_URI_WILDCARD=y # CONFIG_COAP_KEEP_USER_DATA is not set # CONFIG_COAP_CLIENT is not set # CONFIG_COAP_SERVER is not set CONFIG_COAP_LOG_LEVEL=0 # CONFIG_DNS_SD is not set # CONFIG_MQTT_LIB is not set # CONFIG_MQTT_SN_LIB is not set # CONFIG_TFTP_LIB is not set # CONFIG_HTTP_PARSER is not set CONFIG_HTTP_PARSER_URL=y # CONFIG_HTTP_PARSER_STRICT is not set # CONFIG_HTTP_CLIENT is not set # CONFIG_HTTP_SERVER is not set CONFIG_NET_HTTP_LOG_LEVEL=0 # CONFIG_WEBSOCKET_CLIENT is not set CONFIG_LWM2M=y # CONFIG_LWM2M_LOG_LEVEL_OFF is not set # CONFIG_LWM2M_LOG_LEVEL_ERR is not set # CONFIG_LWM2M_LOG_LEVEL_WRN is not set # CONFIG_LWM2M_LOG_LEVEL_INF is not set CONFIG_LWM2M_LOG_LEVEL_DBG=y # CONFIG_LWM2M_LOG_LEVEL_DEFAULT is not set CONFIG_LWM2M_LOG_LEVEL=4 # # Protocol versions # # CONFIG_LWM2M_VERSION_1_0 is not set CONFIG_LWM2M_VERSION_1_1=y # CONFIG_LWM2M_SECURITY_OBJECT_VERSION_1_0 is not set CONFIG_LWM2M_SECURITY_OBJECT_VERSION_1_1=y # CONFIG_LWM2M_SERVER_OBJECT_VERSION_1_0 is not set CONFIG_LWM2M_SERVER_OBJECT_VERSION_1_1=y # end of Protocol versions # # Engine features # CONFIG_LWM2M_DTLS_SUPPORT=y CONFIG_LWM2M_DNS_SUPPORT=y # CONFIG_LWM2M_COAP_BLOCK_TRANSFER is not set # CONFIG_LWM2M_CANCEL_OBSERVE_BY_PATH is not set CONFIG_LWM2M_QUEUE_MODE_ENABLED=y CONFIG_LWM2M_QUEUE_MODE_UPTIME=4 # CONFIG_LWM2M_QUEUE_MODE_NO_MSG_BUFFERING is not set CONFIG_LWM2M_TLS_SESSION_CACHING=y CONFIG_LWM2M_DTLS_CID=y # CONFIG_LWM2M_RD_CLIENT_SUPPORT_BOOTSTRAP is not set # CONFIG_LWM2M_RD_CLIENT_CLOSE_SOCKET_AT_IDLE is not set # CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE is not set CONFIG_LWM2M_RD_CLIENT_STOP_POLLING_AT_IDLE=y # CONFIG_LWM2M_RD_CLIENT_LISTEN_AT_IDLE is not set CONFIG_LWM2M_TICKLESS=y # CONFIG_LWM2M_INTERVAL is not set CONFIG_LWM2M_SERVER_DEFAULT_SSID=101 CONFIG_LWM2M_PEER_PORT=5686 CONFIG_LWM2M_FIRMWARE_PORT_NONSECURE=5683 CONFIG_LWM2M_FIRMWARE_PORT_SECURE=5684 CONFIG_LWM2M_SERVER_DEFAULT_PMIN=10 CONFIG_LWM2M_SERVER_DEFAULT_PMAX=3000 CONFIG_LWM2M_RD_CLIENT_MAX_RETRIES=5 # CONFIG_LWM2M_RESOURCE_DATA_CACHE_SUPPORT is not set # end of Engine features # # Memory and buffer size configuration # CONFIG_LWM2M_ENGINE_STACK_SIZE=6144 CONFIG_LWM2M_ENGINE_MAX_MESSAGES=30 CONFIG_LWM2M_COAP_BLOCK_SIZE=512 CONFIG_LWM2M_ENGINE_MESSAGE_HEADER_SIZE=48 CONFIG_LWM2M_COAP_MAX_MSG_SIZE=1280 CONFIG_LWM2M_ENGINE_VALIDATION_BUFFER_SIZE=64 CONFIG_LWM2M_ENGINE_MAX_PENDING=30 CONFIG_LWM2M_ENGINE_MAX_REPLIES=30 CONFIG_LWM2M_ENGINE_MAX_OBSERVER=30 CONFIG_LWM2M_RD_CLIENT_ENDPOINT_NAME_MAX_LENGTH=33 CONFIG_LWM2M_SECURITY_KEY_SIZE=33 CONFIG_LWM2M_SECURITY_DTLS_TLS_CIPHERSUITE_MAX=5 CONFIG_LWM2M_SECURITY_INSTANCE_COUNT=1 CONFIG_LWM2M_SERVER_INSTANCE_COUNT=1 CONFIG_LWM2M_NUM_BLOCK1_CONTEXT=3 CONFIG_LWM2M_SWMGMT_PACKAGE_URI_LEN=128 CONFIG_LWM2M_COMPOSITE_PATH_LIST_SIZE=10 # CONFIG_LWM2M_DEVICE_ERROR_CODE_SETTINGS is not set CONFIG_LWM2M_DEVICE_PWRSRC_MAX=5 CONFIG_LWM2M_DEVICE_ERROR_CODE_MAX=10 CONFIG_LWM2M_DEVICE_EXT_DEV_INFO_MAX=5 CONFIG_LWM2M_NUM_ATTR=20 # end of Memory and buffer size configuration # # Content format supports # CONFIG_LWM2M_RW_OMA_TLV_SUPPORT=y CONFIG_LWM2M_RW_JSON_SUPPORT=y CONFIG_LWM2M_RW_SENML_JSON_SUPPORT=y CONFIG_LWM2M_RW_CBOR_SUPPORT=y CONFIG_LWM2M_RW_SENML_CBOR_SUPPORT=y CONFIG_LWM2M_RW_SENML_CBOR_RECORDS=55 # end of Content format supports CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=43260 CONFIG_LWM2M_UPDATE_PERIOD=14400 CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=60 CONFIG_LWM2M_SHELL=y # CONFIG_LWM2M_ACCESS_CONTROL_ENABLE is not set CONFIG_LWM2M_ACCESS_CONTROL_INSTANCE_COUNT=50 CONFIG_LWM2M_CONN_MON_OBJ_SUPPORT=y # CONFIG_LWM2M_CONNMON_OBJECT_VERSION_1_0 is not set CONFIG_LWM2M_CONNMON_OBJECT_VERSION_1_2=y # CONFIG_LWM2M_CONNMON_OBJECT_VERSION_1_3 is not set CONFIG_LWM2M_CONN_MON_APN_MAX=1 CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_SUPPORT=y # CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_SUPPORT_MULTIPLE is not set CONFIG_LWM2M_FIRMWARE_UPDATE_OBJ_INSTANCE_COUNT=1 CONFIG_LWM2M_FIRMWARE_UPDATE_PULL_SUPPORT=y # CONFIG_LWM2M_FIRMWARE_UPDATE_PULL_COAP_PROXY_SUPPORT is not set # CONFIG_LWM2M_LOCATION_OBJ_SUPPORT is not set # CONFIG_LWM2M_SWMGMT_OBJ_SUPPORT is not set CONFIG_LWM2M_PORTFOLIO_OBJ_SUPPORT=y # CONFIG_LWM2M_BINARYAPPDATA_OBJ_SUPPORT is not set # CONFIG_LWM2M_EVENT_LOG_OBJ_SUPPORT is not set # CONFIG_LWM2M_GATEWAY_OBJ_SUPPORT is not set CONFIG_LWM2M_IPSO_SUPPORT=y CONFIG_LWM2M_IPSO_TEMP_SENSOR=y CONFIG_LWM2M_IPSO_TEMP_SENSOR_INSTANCE_COUNT=2 # CONFIG_LWM2M_IPSO_TEMP_SENSOR_VERSION_1_0 is not set CONFIG_LWM2M_IPSO_TEMP_SENSOR_VERSION_1_1=y # CONFIG_LWM2M_IPSO_GENERIC_SENSOR is not set CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR=y CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR_INSTANCE_COUNT=2 # CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR_VERSION_1_0 is not set CONFIG_LWM2M_IPSO_HUMIDITY_SENSOR_VERSION_1_1=y # CONFIG_LWM2M_IPSO_PRESSURE_SENSOR is not set # CONFIG_LWM2M_IPSO_LIGHT_CONTROL is not set # CONFIG_LWM2M_IPSO_ACCELEROMETER is not set # CONFIG_LWM2M_IPSO_BUZZER is not set # CONFIG_LWM2M_IPSO_TIMER is not set # CONFIG_LWM2M_IPSO_ONOFF_SWITCH is not set CONFIG_LWM2M_IPSO_PUSH_BUTTON=y CONFIG_LWM2M_IPSO_PUSH_BUTTON_INSTANCE_COUNT=1 # CONFIG_LWM2M_IPSO_PUSH_BUTTON_VERSION_1_0 is not set CONFIG_LWM2M_IPSO_PUSH_BUTTON_VERSION_1_1=y # CONFIG_LWM2M_IPSO_CURRENT_SENSOR is not set CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR=y CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR_INSTANCE_COUNT=1 # CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR_VERSION_1_0 is not set CONFIG_LWM2M_IPSO_VOLTAGE_SENSOR_VERSION_1_1=y # CONFIG_LWM2M_IPSO_FILLING_SENSOR is not set # CONFIG_LWM2M_UCIFI_SUPPORT is not set # # Deprecated flags # # CONFIG_LWM2M_RD_CLIENT_SUPPORT is not set # end of Deprecated flags # CONFIG_SOCKS is not set CONFIG_SNTP=y CONFIG_SNTP_LOG_LEVEL=0 # end of Network Protocols # # Network Libraries # CONFIG_NET_CONFIG_AUTO_INIT=y CONFIG_NET_CONFIG_INIT_PRIO=95 CONFIG_NET_CONFIG_INIT_TIMEOUT=30 # CONFIG_NET_CONFIG_NEED_IPV4 is not set CONFIG_NET_CONFIG_LOG_LEVEL=0 # CONFIG_NET_CONFIG_SETTINGS is not set # CONFIG_NET_CONFIG_CLOCK_SNTP_INIT is not set CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50 CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000 CONFIG_NET_SOCKET_MAX_SEND_WAIT=10000 # CONFIG_NET_SOCKETS_SERVICE is not set # CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set CONFIG_NET_SOCKETS_TLS_PRIORITY=45 CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40 # CONFIG_NET_SOCKETS_OFFLOAD_DISPATCHER is not set # CONFIG_NET_SOCKETS_PACKET is not set # CONFIG_NET_SOCKETS_CAN is not set CONFIG_NET_SOCKETPAIR=y # CONFIG_NET_SOCKETPAIR_STATIC is not set CONFIG_NET_SOCKETPAIR_HEAP=y CONFIG_NET_SOCKETS_LOG_LEVEL=0 # CONFIG_TLS_CREDENTIALS is not set # end of Network Libraries # # Network additional services # # CONFIG_NET_CAPTURE is not set # CONFIG_NET_DHCPV4_SERVER is not set # CONFIG_NET_TRICKLE is not set # CONFIG_NET_ZPERF is not set # end of Network additional services # CONFIG_NET_CONNECTION_MANAGER is not set # end of Networking # # Power Management # # CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set # CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set # CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set # CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set # CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y CONFIG_PM_DEVICE_LOG_LEVEL=3 CONFIG_PM_DEVICE_POWER_DOMAIN=y # CONFIG_PM_DEVICE_RUNTIME is not set # end of Power Management # # Portability # # end of Portability # # Random Number Generators # # CONFIG_TEST_RANDOM_GENERATOR is not set CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789 CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set CONFIG_CSPRNG_ENABLED=y CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y # end of Random Number Generators # CONFIG_RTIO is not set # # SD # # CONFIG_MMC_STACK is not set # CONFIG_SDMMC_STACK is not set # CONFIG_SDIO_STACK is not set # end of SD CONFIG_SETTINGS=y # CONFIG_SETTINGS_LOG_LEVEL_OFF is not set # CONFIG_SETTINGS_LOG_LEVEL_ERR is not set # CONFIG_SETTINGS_LOG_LEVEL_WRN is not set # CONFIG_SETTINGS_LOG_LEVEL_INF is not set # CONFIG_SETTINGS_LOG_LEVEL_DBG is not set CONFIG_SETTINGS_LOG_LEVEL_DEFAULT=y CONFIG_SETTINGS_LOG_LEVEL=3 # CONFIG_SETTINGS_RUNTIME is not set CONFIG_SETTINGS_DYNAMIC_HANDLERS=y CONFIG_SETTINGS_FCB=y # CONFIG_SETTINGS_CUSTOM is not set # CONFIG_SETTINGS_NONE is not set CONFIG_SETTINGS_FCB_NUM_AREAS=8 CONFIG_SETTINGS_FCB_MAGIC=0xc0ffeeee # CONFIG_SETTINGS_SHELL is not set CONFIG_SHELL=y # CONFIG_SHELL_LOG_LEVEL_OFF is not set # CONFIG_SHELL_LOG_LEVEL_ERR is not set # CONFIG_SHELL_LOG_LEVEL_WRN is not set # CONFIG_SHELL_LOG_LEVEL_INF is not set # CONFIG_SHELL_LOG_LEVEL_DBG is not set CONFIG_SHELL_LOG_LEVEL_DEFAULT=y CONFIG_SHELL_LOG_LEVEL=3 CONFIG_SHELL_BACKENDS=y CONFIG_SHELL_BACKEND_SERIAL=y CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=0 CONFIG_SHELL_PROMPT_UART="uart:~$ " CONFIG_SHELL_BACKEND_SERIAL_INTERRUPT_DRIVEN=y # CONFIG_SHELL_BACKEND_SERIAL_API_POLLING is not set CONFIG_SHELL_BACKEND_SERIAL_API_INTERRUPT_DRIVEN=y # CONFIG_SHELL_BACKEND_SERIAL_API_ASYNC is not set CONFIG_SHELL_BACKEND_SERIAL_TX_RING_BUFFER_SIZE=8 CONFIG_SHELL_BACKEND_SERIAL_RX_RING_BUFFER_SIZE=64 CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_TIMEOUT=100 CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_SIZE=512 CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DEFAULT=y # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DBG is not set # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_INF is not set # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_WRN is not set # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_ERR is not set # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_NONE is not set CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL=5 # CONFIG_SHELL_BACKEND_DUMMY is not set # CONFIG_SHELL_MINIMAL is not set # CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set CONFIG_SHELL_STACK_SIZE=2048 CONFIG_SHELL_BACKSPACE_MODE_DELETE=y CONFIG_SHELL_CMD_BUFF_SIZE=256 CONFIG_SHELL_PRINTF_BUFF_SIZE=30 CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80 CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24 CONFIG_SHELL_ARGC_MAX=20 CONFIG_SHELL_TAB=y CONFIG_SHELL_TAB_AUTOCOMPLETION=y CONFIG_SHELL_ASCII_FILTER=y CONFIG_SHELL_WILDCARD=y CONFIG_SHELL_ECHO_STATUS=y # CONFIG_SHELL_START_OBSCURED is not set CONFIG_SHELL_VT100_COMMANDS=y CONFIG_SHELL_VT100_COLORS=y # CONFIG_SHELL_GETOPT is not set CONFIG_SHELL_METAKEYS=y CONFIG_SHELL_HELP=y CONFIG_SHELL_HELP_OPT_PARSE=y CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=y CONFIG_SHELL_HISTORY=y CONFIG_SHELL_HISTORY_BUFFER=512 CONFIG_SHELL_STATS=y CONFIG_SHELL_CMDS=y CONFIG_SHELL_CMDS_RESIZE=y # CONFIG_SHELL_CMDS_SELECT is not set CONFIG_SHELL_CMD_ROOT="" CONFIG_SHELL_LOG_BACKEND=y CONFIG_SHELL_LOG_FORMAT_TIMESTAMP=y CONFIG_SHELL_AUTOSTART=y CONFIG_SHELL_CMDS_RETURN_VALUE=y CONFIG_KERNEL_SHELL=y CONFIG_KERNEL_SHELL_REBOOT_DELAY=0 CONFIG_DEVICE_SHELL=y CONFIG_DATE_SHELL=y CONFIG_DEVMEM_SHELL=y # CONFIG_STATS is not set # # Storage # CONFIG_FLASH_MAP=y # CONFIG_FLASH_MAP_SHELL is not set # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set # CONFIG_FLASH_MAP_LABELS is not set CONFIG_STREAM_FLASH=y CONFIG_STREAM_FLASH_ERASE=y # CONFIG_STREAM_FLASH_PROGRESS is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y CONFIG_STREAM_FLASH_LOG_LEVEL=3 # end of Storage # CONFIG_TASK_WDT is not set # # Testing # # CONFIG_ZTEST is not set # CONFIG_ZTEST_MOCKING is not set # CONFIG_ZTRESS is not set # CONFIG_TEST is not set CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384 # CONFIG_FORCE_COVERAGE is not set # CONFIG_TEST_USERSPACE is not set # end of Testing # CONFIG_TIMING_FUNCTIONS is not set # CONFIG_TRACING is not set # CONFIG_USB_DEVICE_STACK is not set # CONFIG_USB_DEVICE_STACK_NEXT is not set # CONFIG_USB_HOST_STACK is not set # CONFIG_USBC_STACK is not set # CONFIG_ZBUS is not set # end of Subsystems and OS Services CONFIG_TOOLCHAIN_ZEPHYR_0_16=y CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y # # Build and Link Features # # # Linker Options # # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set CONFIG_LINKER_ORPHAN_SECTION_WARN=y # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set CONFIG_HAS_FLASH_LOAD_OFFSET=y CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y CONFIG_LD_LINKER_TEMPLATE=y # CONFIG_CMAKE_LINKER_GENERATOR is not set # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set CONFIG_KERNEL_ENTRY="__start" CONFIG_LINKER_SORT_BY_ALIGNMENT=y CONFIG_SRAM_OFFSET=0 # # Linker Sections # # CONFIG_LINKER_USE_BOOT_SECTION is not set # CONFIG_LINKER_USE_PINNED_SECTION is not set CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y CONFIG_LINKER_LAST_SECTION_ID=y CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015 CONFIG_LINKER_USE_RELAX=y # end of Linker Sections CONFIG_LINKER_DEVNULL_SUPPORT=y # CONFIG_LINKER_DEVNULL_MEMORY is not set # end of Linker Options # # Compiler Options # # CONFIG_CODING_GUIDELINE_CHECK is not set # CONFIG_COMPILER_FREESTANDING is not set CONFIG_SIZE_OPTIMIZATIONS=y # CONFIG_SPEED_OPTIMIZATIONS is not set # CONFIG_DEBUG_OPTIMIZATIONS is not set # CONFIG_NO_OPTIMIZATIONS is not set # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set # CONFIG_COMPILER_SAVE_TEMPS is not set CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y CONFIG_COMPILER_COLOR_DIAGNOSTICS=y # CONFIG_FORTIFY_SOURCE_NONE is not set CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set CONFIG_COMPILER_OPT="" # CONFIG_MISRA_SANE is not set # end of Compiler Options # CONFIG_ASSERT_ON_ERRORS is not set # CONFIG_NO_RUNTIME_CHECKS is not set CONFIG_RUNTIME_ERROR_CHECKS=y # # Build Options # CONFIG_KERNEL_BIN_NAME="zephyr" CONFIG_OUTPUT_STAT=y # CONFIG_OUTPUT_SYMBOLS is not set # CONFIG_OUTPUT_DISASSEMBLY is not set CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set # CONFIG_BUILD_NO_GAP_FILL is not set # CONFIG_BUILD_OUTPUT_EXE is not set # CONFIG_BUILD_OUTPUT_S19 is not set # CONFIG_BUILD_OUTPUT_UF2 is not set # CONFIG_BUILD_OUTPUT_STRIPPED is not set # CONFIG_BUILD_ALIGN_LMA is not set # CONFIG_APPLICATION_DEFINED_SYSCALL is not set # CONFIG_MAKEFILE_EXPORTS is not set CONFIG_BUILD_OUTPUT_META=y # CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set CONFIG_BUILD_OUTPUT_STRIP_PATHS=y CONFIG_CHECK_INIT_PRIORITIES=y # CONFIG_EMIT_ALL_SYSCALLS is not set # end of Build Options CONFIG_WARN_DEPRECATED=y CONFIG_ENFORCE_ZEPHYR_STDINT=y # end of Build and Link Features # # Boot Options # # CONFIG_IS_BOOTLOADER is not set # CONFIG_BOOTLOADER_BOSSA is not set # end of Boot Options # end of Zephyr Kernel CONFIG_APP_PRIOT_i2_CIRCUIT_BOARD_SENSORS=y CONFIG_APP_DAMO=y CONFIG_WATER_SENSOR_LOG_LEVEL=3 # CONFIG_WATER_SENSOR is not set # CONFIG_APP_WATER_SENSOR_PRIOT is not set CONFIG_PRIOT_DAMO_SENSORS=y # CONFIG_PRIOT_REG_UPDATE_WATCHDOG is not set CONFIG_PRIOT_UI=y CONFIG_PRIOT_REGULAR_REBOOT=y CONFIG_PRIOT_FEATURE_5=y # CONFIG_PRIOT_KILL_UART is not set CONFIG_PRIOT_CONNECTION_DEBUGGING=y
Testing our device under harsh conditions has shown that the lwm2m client sample can enter a state in which it continuously tries to connect to the network, leading to incredibly high power draw.
Steps to reproduce:
1. mfw 1.3.6
2. Toolchain version 2.6.0
3. LwM2M client sample
4. Let device register normally, then take it to a location with no network connectivity.
Result:
The power usage seems to follow regular intervals, so it might be something configurable?:
- There are ~300 s between the end of the power draw and the start of the next
- Most "attempts" are ~100 s, some are ~10 s, some are ~200 s
- Our device logs show, that the lwm2m engine was suspended:
[16:52:05.363,525] <dbg> app_lwm2m_client: debug_connection_work_cb: current client_state: 4 [16:52:05.363,586] <dbg> app_lwm2m_client: debug_connection_work_cb: current retry_state: 100 [16:52:05.363,586] <dbg> app_lwm2m_client: debug_connection_work_cb: last lwm2m_rd_client_event: 11 [16:52:05.363,616] <dbg> app_lwm2m_client: debug_connection_work_cb: last lte_lc_nw_reg_status: 4 [16:52:05.363,647] <dbg> app_lwm2m_client: debug_connection_work_cb: modem_connected_to_network: 0 [16:52:05.363,647] <dbg> app_lwm2m_client: debug_connection_work_cb: current_uptime: 60725363 [16:52:05.363,677] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_complete: 11735 [16:52:05.363,708] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_reg_update: 14411734 [16:52:05.363,708] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_rx_off: 15612 [16:52:05.363,739] <dbg> app_lwm2m_client: debug_connection_work_cb: ts_last_engine_suspended: 14454261
I will try to reproduce this overnight and get a modem trace in addition to the joulescope capture.
