When testing the power consumption of the product with main IC 52832, we found that under the condition of 0dBm 1000ms, the peak current of beacon with PPK2 is about 15mA, while the data manual is about 5mA, we asked XUNTON (Nordic supplier found that they use the power analyser to test the TX peak in the vicinity of 5mA and said that the peak current is not permitted when the sample rate of PPK2 is adjusted to the maximum, and the peak current is permitted when the sample rate is adjusted to the second higher gear). maximum, the measured peak current is not accurate, when the sampling rate is adjusted to the second highest gear, the peak current is accurate). I wonder know is that right?What sample rate should we use to test the average current and which sample rate should we use to measure the peak current? Why is the difference in measurement results between ppk2 for a higher sampling rate and a power analyser greater ?
①average current
②One pulse amplification
