When I follow exercise steps A to open nRF connect terminal,vs code will display issue as follow:
Whether some issues happened when I get nrf connect SDK?
How can I repair it?
It will happen until open a nrf conneect sdk project folder.
This is tricky because none of us have encountered this issue before, and we also cannot reproduce it at all.
Does it happen again after you have successfully used the extension once?
As in, after you open the SDK installation, and compile a sample there, would it start working properly from then on?
Also, which terminal profile are you configuring as the default for VS Code?
