BTLE Fundamentals - Lesson 6, Exercise 2 - LL_PHY_REQ response is 2 LL_REJECT_EXT_IND and then nothing, however COM logging on the app indicates success
I am working through BTLE Fundamentals, Lesson 6, Exercise 2, and running the code from blefund_less3_exer2 per the instructions and it all looks good on the app COM log:
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
[00:00:00.000,274] <inf> Lesson3_Exercise2: Starting Lesson 3 - Exercise 2
[00:00:00.000,671] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
36 f0 e5 0e 87 68 48 fb 02 fd 9f 82 cc 32 e5 7b |6....hH. .....2.{
91 b1 5c ed |..\.
[00:00:00.002,593] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.002,624] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.002,655] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
[00:00:00.003,540] <inf> bt_hci_core: Identity: EA:F7:95:23:3C:04 (random)
[00:00:00.003,570] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
[00:00:00.003,601] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
[00:00:00.003,601] <inf> Lesson3_Exercise2: Bluetooth initialized
[00:00:00.004,486] <inf> Lesson3_Exercise2: Advertising successfully started
[00:00:15.846,984] <inf> Lesson3_Exercise2: Connected
[00:00:15.847,015] <inf> Lesson3_Exercise2: Connection parameters: interval 45.00 ms, latency 0 intervals, timeout 5000 ms
[00:00:15.915,740] <inf> Lesson3_Exercise2: MTU exchange successful
[00:00:15.915,771] <inf> Lesson3_Exercise2: New MTU: 244 bytes
[00:00:16.050,872] <inf> Lesson3_Exercise2: Data length updated. Length 251/27 bytes, time 2120/328 us
[00:00:16.275,756] <inf> Lesson3_Exercise2: PHY updated. New PHY: 1M
[00:00:16.501,007] <inf> Lesson3_Exercise2: Connection parameters updated: interval 7.50 ms, latency 0 intervals, timeout 5000 ms
[00:00:16.755,737] <inf> Lesson3_Exercise2: Connection parameters updated: interval 45.00 ms, latency 0 intervals, timeout 5000 ms
[00:00:21.270,660] <inf> Lesson3_Exercise2: Connection parameters updated: interval 1000.00 ms, latency 0 intervals, timeout 4000 ms
But in the sniffer output, I'm getting an error in response to the LL_PHY_REQ, and I have retried it many times:
Time
Source Protocol Length Flags Channel Index Delta time (start to start) RSSI Info
1472.562202 Slave_0xd2f6322c LE LL 29 0x01 31 326µs -26 dBm Control Opcode: LL_PHY_REQ
1472.607106 Slave_0xd2f6322c ATT 52 0x01 26 230µs -23 dBm Rcvd Read By Group Type Response, Attribute List Length: 1, Unknown
1472.607544 Master_0xd2f6322c LE LL 29 0x03 26 438µs -45 dBm Control Opcode: LL_REJECT_EXT_IND
1472.651875 Master_0xd2f6322c LE LL 29 0x03 30 44331µs -42 dBm Control Opcode: LL_REJECT_EXT_IND
I was trying to see if there was something I was missing, and ran into the definition of the 0x2a Different Transaction Collision error. It looks like you should wait for a response before sending out another request, and the exercise code doesn't do that. One comment I found mentioned that starting another request while one is in process is a spec violation. So I'm wondering if this is generally true for all requests, and for guidance on how best to accomplish this.
I modified the code as follows add a 1 sec sleep before the next request, and it eliminated the collision:
	/* STEP 7.2 - Update the PHY mode */
	update_phy(my_conn);
	// wait for a second - RLS
	k_sleep(K_MSEC(1000));
	/* STEP 13.5 - Update the data length and MTU */
	update_data_length(my_conn);
	update_mtu(my_conn);
So it looks like that may be something missing in the exercise, and I might want to send these async requests out awaiting the previous one to complete.
Can anyone comment on best practices for doing this?
I am not new to async programming or to C, but this is my first time around BTLE programming.
    Sorry for the late reply.
    What are you using as your BLE central? A phone? Computer? Another nRF?
    Have you tried another central, to see if the issue persists?
    I find it strange that the central/master replies with "Different Transaction Collision", because it doesn't look like this is actually the case. Each device can have one Link Layer operation ongoing at once, but the previous LL transaction initiated from the peripheral is done (initiated in packet 6524 and response in packet 6528).
    Therefore, without knowing more, I would say that it looks like it is the central that is misbehaving with an incorrect "Different Transaction Collision" reply.
    Edvin
  • I was running the device under test and the sniffer were both running on nRF52840-DK boards. I have moved on, so maybe we can just leave it be. I did think it strange that the request seemed successful while an error was reported. I'm not overly concerned, but just wanted to let you know it happened.
    Thanks for taking a look!
  • Just to inform, that I experience exactly the same behaviour, as the original author of this post. The LL_PHY_REQ never gets its UPDATE in the wireshark, I see the same collision errors and LL_REJECT_EXT_IND and the peripheral outputs, that the selected PHY is 1M.
    The setup:
    Peripheral - 52840DK v3
    Sniffer - 52840 Dongle v3
    Central - Android phone with nrf Connect Mobile application
