BLE interfering with pstorage_update?
Hello everyone,
I have a problem using pstorage_update. Normally it does as it should, but once i call ble_stack_init(); on my code, pstorage_update doesn't work anymore, it just doesn't take action, does anybody know why? I even reinitialized the softdevice before using pstorage_update but it was no use. I'm using the ble stack init provided in the sdk example codes.
/**@brief Function for the S110 SoftDevice initialization.
 * @details This function initializes the S110 SoftDevice and the BLE event interrupt.
    uint32_t err_code;
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
    // Enable BLE stack.
    ble_enable_params_t ble_enable_params;
    memset(&ble_enable_params, 0, sizeof(ble_enable_params));
#if (defined(S130) || defined(S132))
    ble_enable_params.gatts_enable_params.attr_tab_size   = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
    ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    err_code = sd_ble_enable(&ble_enable_params);
    // Subscribe for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
  • Hi.
    Yes, I am aware it's a dirty hack and that's precisely why I'm asking for help. The changes consisted in making an extra custom function inside softdevice_handler.c, which sets m_ble_evt_handler to NULL as I already explained (I call this function in my main code since it's my only way to reset the m_ble_evt_handler pointer). if i don't use this function to set the pointer to NULL, pstorage never completes the update. I precisely need help to understand why this is happening as this is all I'm doing with the code.
    In other words, you could say that my dirty hack reverts the line err_code = softdevice_ble_evt_handler_set(&ble_evt_dispatch).
    Good, then we are on the same page. The next step is to try to understand the root cause of this issue, for which more information and debuggis is needed. Can you by sharing which chagnes you did that introduced this issue?
  • I already explained that. As i said, this is the function i added, which i call in my main code:
    void custom_function_null_ble_handler(void){
        m_ble_evt_handler = NULL;
    I added this function in softdevice_handler.c with the corresponding header in softdevice_handler.h
    When i use my custom function i get tu use pstorage_update correctly. this is the only thing i changed as i already explained.
  • That was you intended fix/workaround, was it not? What did you do that indtroduced the issue? (This question is based on the assumption that as you are using a very old SDK this must be legacy code, please let me know if that is not the case).
  • well i did that because i checked example codes that use BLE, and even though they work, this lines makes pstorage unable to update memory.
    Literally second line makes everything go wrong, so when i checked the implementation of that function, i saw that i just sets m_ble_evt_handler.
    uint32_t softdevice_ble_evt_handler_set(ble_evt_handler_t ble_evt_handler)
        if (ble_evt_handler == NULL)
            return NRF_ERROR_NULL;
        m_ble_evt_handler = ble_evt_handler;
        return NRF_SUCCESS;
    so i manually point m_ble_evt_handler to NULL to revert the changes after using ble. I did this because when the pointer points to a handler function my code doesn't work, but it does when it stops pointing.
