Analog Read and print on emulator
I need help with a simple example code to read analog pin 5 and either control brightness of the LED or print value on terminal.
I found this example but it didn't work for me>
I made a custom board and programemd with nRF52 DK. I tested blink led code as well that is working fine
I am in a learning stage.
I guess this example not working becasue my hardware is not connected with UART to a com port. so the best approach for me is to control an LED connected with digital pin using fade function
Can someone help me with it plz?
Thanks
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup nrf_adc_example main.c
 * @ingroup nrf_adc_example
 * @brief ADC Example Application main file.
 * This file contains the source code for a sample application using ADC.
 * @image html example_board_setup_a.jpg "Use board setup A for this example."
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SAMPLES_IN_BUFFER 5
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    ret_code_t err_code;
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    uint32_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    saadc_init();
    saadc_sampling_event_init();
    NRF_LOG_INFO("SAADC HAL simple example started.");
    while (1)
        nrf_pwr_mgmt_run();
        NRF_LOG_FLUSH();
  • Which SDK version are you using?
    regards
    Jared
  • Hi
    I downloaded nRF5_SDK_17.1.0_ddde560
    The above code i downloaded from the link you prvoided to convert UART to RTT
    I also have on board UART pins available.
    UART_RTS
    UART_RX
    UART_TX
    UART_CTS
    Let me know if i can use these pins to readout UART data through FT232 module
    Also, i am using 3rd party module BL652
    I contacted them. They told me that i am developing code based on nRF52 SDK or DK so i need to consult Nordic. I don't want to buy their proprietary DVK because i want to get familiarize with Nordic chips to use in the future projects
  • Hi
    Can you give me your feedback for the basic solution please?
    Thanks
  • I write this UART code to test on nRF52 DVK.
    After resolving many issues by following previous threads. I was able to compile it but i am not getting anything on putty
    Do i need something on board to make it work?
    I didn't change anything by default
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "nrf.h"
    #include "bsp.h"
    #include "nrf_uart.h"
    //#define ENABLE_LOOPBACK_TEST  /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
    //#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
    void uart_error_handle(app_uart_evt_t * p_event)
    #ifdef ENABLE_LOOPBACK_TEST
    /* Use flow control in loopback test. */
    #define UART_HWFC APP_UART_FLOW_CONTROL_ENABLED
    /** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
    static void show_error(void)
        bsp_board_leds_on();
        while (true)
            // Do nothing.
    /** @brief Function for testing UART loop back.
     *  @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
     *  @note  @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
    static void uart_loopback_test()
        uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
        uint8_t   rx_data;
        // Start sending one byte and see if you get the same
        for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
            uint32_t err_code;
            while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
            nrf_delay_ms(10);
            err_code = app_uart_get(&rx_data);
            if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
                show_error();
        return;
    #else
    /* When UART is used for communication with the host do not use flow control.*/
    #define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
    uint32_t err_code;
    const app_uart_comm_params_t com_params =
    RX_PIN_NUMBER,
    TX_PIN_NUMBER,
    CTS_PIN_NUMBER,
    RTS_PIN_NUMBER,
    UART_HWFC,
    false,
    NRF_UART_BAUDRATE_115200
    APP_UART_FIFO_INIT(&com_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_error_handle, APP_IRQ_PRIORITY_LOWEST, err_code);
    printf("Hello pc from!!\r\n");
    while(true)
    uint8_t cr;
    while(app_uart_get(&cr) != NRF_SUCCESS);
    if(cr == 't')
    printf("Leds Turned On!!\r\n");
    if(cr == 'k')
    bsp_board_leds_off();
    printf("Leds Turned off !!\r\n");
