OpenThread RCP Dongle USB hang
I am using NCS 2.6.1 and have programmed a nrf52840dongle (USB Dongle) with the build result of nrf/samples/openthread/coprocessor
The problem I am having is that normally if I power up the border router the device will be detected okay. However, if I reboot the border router I am using, the device is hung. I am suspecting it is a problem (bug?) with the openthread dongle firmware for a few reasons:
1) If I unplug and re-plug the device it enumerates without issue
2) If I press the side button on the dongle, the red light immediately starts pulsing and I see the device enumerate in the DFU bootloader mode
Here is the output on a reboot:
[   22.203362] usb 1-7: device descriptor read/64, error -110
[   37.819340] usb 1-7: device descriptor read/64, error -110
[   38.059182] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[   53.435342] usb 1-7: device descriptor read/64, error -110
[   69.051332] usb 1-7: device descriptor read/64, error -110
[   69.163504] usb usb1-port7: attempt power cycle
[   69.579164] usb 1-7: new full-speed USB device number 4 using xhci_hcd
[   85.051516] usb 1-7: device descriptor read/8, error -110
[  100.667550] usb 1-7: device descriptor read/8, error -110
[  100.907174] usb 1-7: new full-speed USB device number 5 using xhci_hcd
[  116.283543] usb 1-7: device descriptor read/8, error -110
And it never recovers without removing power from the dongle. Of course this is not acceptable for use in a remote border router unit that will be rebooted from time to time.
The border router is a Linux box.
  • Hi Amanda,
    I'm encountering a consistent issue with the pca10059 ncs2.6.1 thread coprocessor sample on my setup, which includes:
    - Linux pve 6.9.8-x64v3-xanmod1 #0~20240705.g77bcbc2 SMP PREEMPT_DYNAMIC Fri Jul 5 16:18:13 UTC x86_64 GNU/Linux
    - An Intel NUC where I pass through the dongle to Home Assistant as a Thread dongle.
    Whenever I use the ncs2.6.1 thread coprocessor sample, it frequently results in errors like these:
    [10998.074483] usb 1-2: new full-speed USB device number 16 using xhci_hcd
    [11013.454063] usb 1-2: device descriptor read/64, error -110
    [11091.915835] usb 1-2: device descriptor read/8, error -110
    [11092.023888] usb usb1-port2: unable to enumerate USB device
    This problem occurs every time without fail.
    However, when I switch to using github.com/.../ot-nrf528xx, there are no issues at all.
  • I have forward it to the internal. Thanks for the report.
