NRF5340 Audio net core app update
I developing an Hearing aid accessory with nrf5340 audio and STM32.
I do not have external flash so I need to use the nrf5340 internal flash.
I'm using the 2.5.0 SDK and I succeeded to update the application image with the mcumgr over the USB CDC ACM connected to the nrf5340.
Is it possible to update the network image without external flash and by the serial port?
If yes, Do you have any example for it?
  • I found out the solution - I had to add the bootloader also to the network processor.
    Thanks.
  • Hi Amanda,
    We still have a problem.
    I use nRF5340 Audio application on 2 nRF5340 Audio DK - one as Headset and the other as Gateway.
    I add the CONFIG_AUDIO_DFU = 1 only to the Gateway application and flash the merged_domains.hex.
    While the Headset application was build and flash without the DFU.
    After boot I get in the Gateway application fault as following:
    *** Booting nRF Connect SDK v2.5.0 ***
    GW [00:00:00.005,249] <inf> fw_info:
             nRF5340 Audio nRF5340 Audio DK cpuapp
             NCS base version: 2.5.0
             Cmake run : Tue Jul 23 15:24:34 2024
    GW [00:00:00.005,249] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.005,249] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.015,869] <inf> board_version: Compatible board/HW version found: 1.0.0
    GW [00:00:00.056,091] <inf> bt_mgmt_ctlr_cfg: Controller: LL_ACS_NRF53. Version: 3393
    GW [00:00:00.057,983] <inf> bt_mgmt: Local identity addr: DB:F2:56:E1:7D:2E (random)
    GW [00:00:01.257,904] <err> bt_mgmt_ctlr_cfg: Controller not responsive
    GW [00:00:01.257,934] <err> bt_mgmt_ctlr_cfg: ERR_CHK Err_code: [-116] @ line: 146
    GW [00:00:01.257,934] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000002
    GW [00:00:01.257,934] <err> os: r3/a4:  0x20005890 r12/ip:  0x20008168 r14/lr:  0x0001a779
    GW [00:00:01.257,934] <err> os:  xpsr:  0x41100025
    GW [00:00:01.257,934] <err> os: s[ 0]:  0x00000001  s[ 1]:  0x20003e64  s[ 2]:  0x20016260  s[ 3]:  0xffffffff
    GW [00:00:01.257,965] <err> os: s[ 4]:  0x20016260  s[ 5]:  0x000000cd  s[ 6]:  0x2000392c  s[ 7]:  0x00000000
    GW [00:00:01.257,965] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x0001379b  s[10]:  0x00000150  s[11]:  0x00000000
    GW [00:00:01.257,965] <err> os: s[12]:  0x00000000  s[13]:  0x000000cd  s[14]:  0x00000004  s[15]:  0x00071e50
    GW [00:00:01.257,965] <err> os: fpscr:  0xffffff8c
    GW [00:00:01.257,995] <err> os: Faulting instruction address (r15/pc): 0x000137a8
    GW [00:00:01.257,995] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    GW [00:00:01.257,995] <err> os: Fault during interrupt handling
    GW [00:00:01.258,026] <err> os: Current thread: 0x20008058 (idle)
    GW [00:00:01.258,026] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
    It looks that once we use the merged_domains.hex file there is a communication problem between the application core and the network core.
    Can you please verify that there is a problem in the hex file and suggest a solution.
    Regards.
    Do you program the net core?
    If DFU is enabled, the subsystem’s binary file will be generated in the build/zephyr/ directory and will be called net_core_app_signed.hex.
    We are currently understaffed due to the summer vacation period, so delayed replies must be expected. I am sorry about any inconvenience this might cause.
    -Amanda H.
  • Hi Amanda,
    Yes I use the programmer v4.4.0 to program both the net core and the app core.
    I program the net core and app core by merged_domains.hex file that includes both images with boot loader,
    and I also program the net core by net_core_app_signed.hex file and the app core by merged.hex file.
    In both cases I got the same error.
