How to disable location services in asset tracker with lwm2m
Hi All,
I'm trying to fully disable all location services with the asset tracker in v2.6.1 while using lwm2m (so I have the lwm2m overlay enabled in the build settings).
However, as you can see below, setting CONFIG_LOCATION=n in my prj.conf does not seem enough to disable the location services.
[00:00:13.241,333] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
+CSCON: 1
%CESQ: 54,2,17,2
[00:00:13.673,095] <err> net_lwm2m_engine: Failed to enable TLS_DTLS_CID: -22
[00:00:13.673,492] <err> net_lwm2m_engine: Cannot connect UDP (-114)
[00:00:13.673,919] <err> net_lwm2m_rd_client: Cannot init LWM2M engine (-114)
[00:00:13.674,255] <err> net_lwm2m_rd_client: sm_do_network_error, retries 0
[00:00:13.674,499] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:350457794446409' with client lifetime 43200 using server object 0
[00:00:13.674,896] <err> net_lwm2m_message_handling: Unable to resolve address
[00:00:13.674,896] <err> net_lwm2m_rd_client: Cannot init LWM2M engine (-2)
[00:00:13.675,231] <err> net_lwm2m_rd_client: sm_do_network_error, retries 1
%XTIME: "80","42608151931180","01"
[00:00:14.675,811] <err> net_lwm2m_rd_client: sm_do_network_error, retries 1
[00:00:14.676,055] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:350457794446409' with client lifetime 43200 using server object 0
[00:00:14.676,391] <err> net_lwm2m_message_handling: Unable to resolve address
[00:00:14.676,422] <err> net_lwm2m_rd_client: Cannot init LWM2M engine (-2)
[00:00:14.676,727] <err> net_lwm2m_rd_client: sm_do_network_error, retries 2
+CGEV: ME PDN ACT 0,0
[00:00:15.095,703] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
+CNEC_ESM: 50,0
%MDMEV: SEARCH STATUS 2
+CEREG: 5,"56BD","019B5502",7,,,"00001111","11100000"
[00:00:15.297,576] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
[00:00:16.676,696] <err> net_lwm2m_rd_client: sm_do_network_error, retries 2
[00:00:16.676,971] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:350457794446409' with client lifetime 43200 using server object 0
[00:00:16.767,211] <err> net_lwm2m_engine: Failed to enable TLS_DTLS_CID: -22
[00:00:17.259,887] <inf> net_lwm2m_engine: Connected, sock id 2
[00:00:17.410,156] <inf> net_lwm2m_rd_client: Registration Done (EP='urn:imei:350457794446409')
[00:00:17.410,919] <inf> app_event_manager: CLOUD_EVT_CONNECTED
[00:00:17.411,773] <inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, MOD_STAT, BAT, ENV, LOCATION)
[00:00:17.412,506] <inf> app_event_manager: LOCATION_MODULE_EVT_ACTIVE
[00:00:17.415,313] <inf> app_event_manager: LOCATION_MODULE_EVT_AGNSS_NEEDED
[00:00:17.417,419] <inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY
[00:00:17.518,798] <inf> app_event_manager: SENSOR_EVT_FUEL_GAUGE_READY
+CEREG: 5,"56BD","019B5502",7,,,"00001111","00101101"
[00:00:17.529,266] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
[00:00:17.592,864] <inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY
[00:00:17.595,489] <inf> net_lwm2m_obj_gnss_assistance: Requesting A-GNSS data, mask 0x000001ff
[00:00:17.595,611] <inf> net_lwm2m_location_assist: Send A-GNSS request
[00:00:17.598,205] <inf> net_lwm2m_message_handling: Send op to server (/dp)
[00:00:17.634,460] <inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY
[00:00:17.713,470] <inf> net_lwm2m_message_handling: Send done!
%CESQ: 54,2,12,1
+CSCON: 0
%XT3412: 46799999
%CESQ: 57,2,18,2
[00:00:53.133,392] <inf> lwm2m_rai: RAI enabled
%CESQ: 255,0,255,0
When I look at the build results, it seems that CONFIG_LOCATION is still set to "y" so it must be forced by some other variable that I'm unaware of.
What would be the correct way to disable all location services?
