SAADC PPI trigger channels separately
Hello, I'm working on an application with precise timing requirements. Basically I need to generate a short pulse and sample two channels during the pulse. In addition, I would like to use a third channel for a slower/low-priority battery monitor task.
I already have implemented the GPIO control for the pulse via Timers and PPI, and I was planning to use it as well to trigger ADC acquisitions during the pulse. However, I have two doubts:
  • Since the pulses happen with high frequency, I would like the ADC to store samples in a buffer autonomously. While the ADC supports buffering, it's unclear to me if I can still trigger manually each acquisition (via PPI) when using this feature (nrf_drv_saadc_buffer_convert or similar), or if the ADC just samples on its own time. For me, it's critical that the trigger is controlled for each sample by the PPI. To clarify with an example, I would like to setup a buffer (eg: 10 samples), then trigger via PPI 10 single acquisitions and only after the 10th get the callback/read the ADC buffered data. Is this possible?
  • Secondly, I would like to add a third channel that I can trigger occasionally for battery monitoring, independent of the time-sensitive application.
If not, what approach do you suggest?
Thank you!
  • Hi Andrea
    I tested the saadc example in the SDK (examples/peripheral/saadc), and I have no problems running the example with only one buffer configured. This example is doing something quite similar, using a timer to trigger sampling over PPI. If I comment out the second call to nrf_drv_saadc_buffer_convert(..) in the saadc_init() function the example works just as well as when both buffers are used.
    Possibly you are configuring the SAADC driver in a different way?
    Best regards
    Torbjørn
    If you update the buffer in the callback, doesn't the ADC continue sampling? In my setup I want it to stop once that buffer is full, and later retrieve the data and trigger manually.
    To reproduce my setup you would need to comment out the same function also in the saadc_callback.
    In your setup, are you getting the FINISHED event as well?
    Does it make sense?
  • Hi Andrea
    Updating the buffer will start the SAADC module, true, but it won't sample it. Sampling is handled through PPI as mentioned earlier.
    If you want it should certainly be possible not to set the buffers automatically in the callback, but rather do that at a later point in time when you want to run a new sample sequence.
    I am getting the END event, yes, if that is what you mean by finished?
    I enabled logging for the nrfx_saadc module, and I can't spot any important differences when changing from two buffers to one.
    Best regards
    Torbjørn
  • Hi Torbjørn
    No, with FINISHED I mean NRFX_SAADC_EVT_FINISHED as in the enum below.
    /** @brief SAADC driver event types. */
    typedef enum
        NRFX_SAADC_EVT_DONE,          ///< Event generated when the buffer is filled with samples.
        NRFX_SAADC_EVT_LIMIT,         ///< Event generated when one of the limits is reached.
        NRFX_SAADC_EVT_CALIBRATEDONE, ///< Event generated when the calibration is complete.
        NRFX_SAADC_EVT_BUF_REQ,       ///< Event generated when the next buffer for continuous conversion is requested.
        NRFX_SAADC_EVT_READY,         ///< Event generated when the first buffer is acquired by the peripheral and sampling can be started.
        NRFX_SAADC_EVT_FINISHED,      ///< Event generated when all supplied buffers are filled with results.
    } nrfx_saadc_evt_type_t;
    This triggers when all the buffers are filled.
    Did you remove the nrf_drv_saadc_buffer_convert from the callback to replicate my setup?
  • Hi Andrea
    Which SDK version are you using? I tested this in v17.1.0 of the nRF5 SDK, where the nrfx_saadc_evt_type_t enum does not include the NRFX_SAADC_EVT_FINISHED definition.
    If you let me know which version you are using I can test it again, and also try to call nrf_drv_saadc_buffer_convert from outside the callback.
    Best regards
    Torbjørn
