LWM2M Errors when first connecting to server - Normal behavior?
I'm using the asset tracker example code with the LWM2M overlay to connect to the Coiote server.
This seems to work fine, and messages do get through. But when booting the device I always get several errors as shown below. Is this normal behavior for a first time connection process?
*** Booting nRF Connect SDK 3758bcbfa5cd ***
[00:00:00.271,270] <inf> at_host: UART check failed: 12. Dropping buffer and retrying.
[00:00:00.282,135] <inf> app_event_manager: APP_EVT_START
[00:00:00.511,749] <inf> app_event_manager: MODEM_EVT_INITIALIZED
[00:00:00.647,613] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
[00:00:00.710,296] <inf> lwm2m_firmware: Image is confirmed OK
[00:00:01.324,432] <inf> app_event_manager: DATA_EVT_CONFIG_INIT
%CESQ: 60,3,14,2
+CEREG: 2,"56BD","019B5501",7
[00:00:02.229,003] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
+CSCON: 1
+CGEV: ME PDN ACT 0,0
[00:00:03.768,615] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
[00:00:03.769,622] <inf> net_lwm2m_rd_client: Start LWM2M Client: urn:imei:xxxx
[00:00:03.770,141] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:xxxx' with client lifetime 43200 using server object 0
+CNEC_ESM: 50,0
%MDMEV: SEARCH STATUS 2
+CEREG: 5,"56BD","019B5501",7,,,"00001111","11100000"
+CEDRXP: 4,"0000","0000","0000"
%XTIME: "80","42609121624280","01"
[00:00:03.983,581] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
[00:00:03.984,191] <inf> app_event_manager: MODEM_EVT_LTE_EDRX_UPDATE
[00:00:03.984,771] <inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED
[00:00:04.068,054] <inf> lwm2m_security: Need to write credentials, requesting LTE and GNSS offline...
[00:00:04.068,572] <inf> app_event_manager: CLOUD_EVT_LTE_DISCONNECT
+CGEV: ME PDN DEACT 0
[00:00:04.163,146] <inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED
+CEREG: 0
[00:00:04.263,427] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
+CGEV: ME DETACH
%CESQ: 255,0,255,0
+CSCON: 0
[00:00:07.849,975] <inf> lwm2m_security: Requesting LTE and GNSS online
[00:00:07.850,494] <inf> app_event_manager: CLOUD_EVT_LTE_CONNECT
[00:00:07.892,150] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
%CESQ: 61,3,18,2
[00:00:09.451,354] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
+CSCON: 1
[00:00:09.852,111] <err> net_lwm2m_engine: Failed to enable TLS_DTLS_CID: -22
[00:00:09.852,569] <err> net_lwm2m_engine: Cannot connect UDP (-114)
[00:00:09.852,813] <err> net_lwm2m_rd_client: Cannot init LWM2M engine (-114)
[00:00:09.853,149] <err> net_lwm2m_rd_client: sm_do_network_error, retries 0
[00:00:09.853,393] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:xxxx' with client lifetime 43200 using server object 0
[00:00:09.853,698] <err> net_lwm2m_message_handling: Unable to resolve address
[00:00:09.853,729] <err> net_lwm2m_rd_client: Cannot init LWM2M engine (-2)
[00:00:09.853,942] <err> net_lwm2m_rd_client: sm_do_network_error, retries 1
%CESQ: 56,2,16,2
%CESQ: 52,2,11,1
[00:00:10.854,827] <err> net_lwm2m_rd_client: sm_do_network_error, retries 1
[00:00:10.855,072] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:xxxx' with client lifetime 43200 using server object 0
[00:00:10.855,407] <err> net_lwm2m_message_handling: Unable to resolve address
[00:00:10.855,407] <err> net_lwm2m_rd_client: Cannot init LWM2M engine (-2)
[00:00:10.855,743] <err> net_lwm2m_rd_client: sm_do_network_error, retries 2
[00:00:11.447,906] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
+CNEC_ESM: 50,0
%XTIME: "80","42609121621380","01"
%CESQ: 47,2,12,1
[00:00:11.759,948] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
%CESQ: 52,2,12,1
[00:00:12.855,682] <err> net_lwm2m_rd_client: sm_do_network_error, retries 2
[00:00:12.855,957] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:xxxx' with client lifetime 43200 using server object 0
[00:00:12.938,385] <err> net_lwm2m_engine: Failed to enable TLS_DTLS_CID: -22
[00:00:13.376,739] <inf> net_lwm2m_engine: Connected, sock id 2
[00:00:13.853,363] <inf> net_lwm2m_rd_client: Registration Done (EP='urn:imei:xxxx')
[00:00:13.854,156] <inf> app_event_manager: CLOUD_EVT_CONNECTED
So the specific error that I'm talking about are:
%CESQ: 56,2,16,2
%CESQ: 52,2,11,1
Appart from those error during the first connection I also get some errors during use after that, when it tries to connect again. Is this also normal or something that I should look into?
[00:05:13.858,337] <err> net_lwm2m_location_assist: Temporary error in location services retry scheduled
[00:05:13.858,337] <err> cloud_module: cloud_wrap_cloud_location_send, err: -120
+CSCON: 0
%XT3412: 46799999
%XT3412: 0
+CSCON: 1
%CESQ: 59,2,13,1
+CSCON: 0
%XT3412: 46799999
%XT3412: 0
+CSCON: 1
%CESQ: 53,2,11,1
%CESQ: 58,2,10,1
+CSCON: 0
%XT3412: 46799999
[00:06:14.030,426] <err> net_lwm2m_location_assist: No response error in location services
[00:06:14.030,487] <err> net_lwm2m_obj_gnss_assistance: Result code 2
%CESQ: 255,0,255,0
%CESQ: 61,3,14,2
%XT3412: 0
+CSCON: 1
%CESQ: 56,2,12,1
+CSCON: 0
%XT3412: 46799999
%CESQ: 255,0,255,0
[00:07:46.751,037] <wrn> net_lwm2m_rd_client: Registration Update Timeout
[00:07:46.751,129] <inf> lwm2m_rai: RAI disabled
[00:07:46.751,159] <wrn> lwm2m_integration: LWM2M_RD_CLIENT_EVENT_REG_TIMEOUT
[00:07:46.751,800] <inf> app_event_manager: CLOUD_EVT_CONNECTING
[00:07:46.759,429] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:350457794446409' with client lifetime 43200 using server object 0
%CESQ: 63,3,19,2
%XT3412: 0
+CSCON: 1
%CESQ: 56,2,12,1
[00:07:47.666,717] <err> net_lwm2m_engine: Failed to enable TLS_DTLS_CID: -22
[00:07:47.779,113] <inf> net_lwm2m_engine: Connected, sock id 2
[00:07:47.942,321] <inf> net_lwm2m_rd_client: Registration Done (EP='urn:imei:350457794446409')
[00:07:47.945,068] <inf> lwm2m_rai: RAI enabled
[00:07:47.945,434] <inf> app_event_manager: CLOUD_EVT_CONNECTED
[00:07:48.178,253] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
[00:07:48.178,375] <inf> net_lwm2m_rd_client: Update Done
[00:07:48.221,069] <inf> lwm2m_rai: Ongoing traffic, RAI disabled
+CSCON: 0
%XT3412: 46799999
%CESQ: 60,3,17,2
[00:08:11.398,925] <err> net_lwm2m_location_assist: No response error in location services
[00:08:11.398,956] <err> net_lwm2m_obj_ground_fix: Result code 2
  • Hi Dejan,
    After adding those Kconfigs is stil get errors unfortunately:
    [00:00:00.271,118] <inf> at_host: UART check failed: 12. Dropping buffer and retrying.
    [00:00:00.281,982] <inf> app_event_manager: APP_EVT_START
    [00:00:00.511,810] <inf> app_event_manager: MODEM_EVT_INITIALIZED
    [00:00:00.638,854] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
    [00:00:00.698,913] <inf> lwm2m_firmware: Image is confirmed OK
    [00:00:01.308,471] <inf> app_event_manager: DATA_EVT_CONFIG_INIT
    [00:00:01.641,387] <inf> app_event_manager: SENSOR_EVT_MOVEMENT_ACTIVITY_DETECTED
    %CESQ: 60,3,20,2
    +CEREG: 2,"7EF6","011ED70D",7
    +CSCON: 1
    [00:00:03.762,817] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
    [00:00:04.966,644] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
    [00:00:04.967,742] <inf> net_lwm2m_rd_client: Start LWM2M Client: urn:imei:350457794446409
    [00:00:04.968,383] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:350457794446409' with client lifetime 43200 using server object 0
    +CNEC_ESM: 50,0
    +CEREG: 1,"7EF6","011ED70D",7,,,"00001111","11100000"
    %XTIME: "80","42704090010180","01"
    [00:00:05.272,552] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
    [00:00:05.273,254] <inf> app_event_manager: MODEM_EVT_LTE_EDRX_UPDATE
    [00:00:05.273,895] <inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED
    [00:00:05.340,240] <inf> lwm2m_security: Need to write credentials, requesting LTE and GNSS offline...
    [00:00:05.340,728] <inf> app_event_manager: CLOUD_EVT_LTE_DISCONNECT
    [00:00:05.512,084] <inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED
    +CEREG: 0
    +CGEV: ME DETACH
    [00:00:05.612,609] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
    %CESQ: 255,0,255,0
    +CSCON: 0
    [00:00:07.792,297] <inf> lwm2m_security: Requesting LTE and GNSS online
    [00:00:07.792,816] <inf> app_event_manager: CLOUD_EVT_LTE_CONNECT
    [00:00:07.847,259] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
    %CESQ: 58,2,20,2
    [00:00:09.349,365] <inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
    +CSCON: 1
    [00:00:09.794,616] <err> net_lwm2m_engine: Cannot connect UDP (-114)
    [00:00:09.794,891] <err> net_lwm2m_rd_client: Cannot init LWM2M engine (-114)
    [00:00:09.795,227] <err> net_lwm2m_rd_client: sm_do_network_error, retries 0
    [00:00:09.795,440] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:350457794446409' with client lifetime 43200 using server object 0
    [00:00:09.795,776] <err> net_lwm2m_message_handling: Unable to resolve address
    [00:00:09.795,776] <err> net_lwm2m_rd_client: Cannot init LWM2M engine (-2)
    [00:00:09.795,989] <err> net_lwm2m_rd_client: sm_do_network_error, retries 1
    [00:00:10.309,814] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
    +CNEC_ESM: 50,0
    %XTIME: "80","42704090015180","01"
    [00:00:10.511,932] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
    [00:00:10.796,722] <err> net_lwm2m_rd_client: sm_do_network_error, retries 1
    [00:00:10.796,966] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'urn:imei:350457794446409' with client lifetime 43200 using server object 0
    [00:00:11.176,452] <inf> net_lwm2m_engine: Connected, sock id 2
    [00:00:11.326,385] <inf> net_lwm2m_rd_client: Registration Done (EP='urn:imei:350457794446409')
    [00:00:11.327,209] <inf> app_event_manager: CLOUD_EVT_CONNECTED
    [00:00:11.328,155] <inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, MOD_STAT, BAT, ENV, LOCATION)
    [00:00:11.328,948] <inf> app_event_manager: LOCATION_MODULE_EVT_ACTIVE
    [00:00:11.331,756] <inf> app_event_manager: LOCATION_MODULE_EVT_AGNSS_NEEDED
    [00:00:11.334,167] <inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY
    [00:00:11.334,777] <inf> app_event_manager: SENSOR_EVT_FUEL_GAUGE_READY
    +CEREG: 1,"7EF6","011ED70D",7,,,"00001111","00101101"
    [00:00:11.380,737] <inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
    [00:00:11.411,346] <inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY
    [00:00:11.491,363] <inf> net_lwm2m_obj_gnss_assistance: Requesting A-GNSS data, mask 0x000001ff
    [00:00:11.491,485] <inf> net_lwm2m_location_assist: Send A-GNSS request
    [00:00:11.494,232] <inf> net_lwm2m_message_handling: Send op to server (/dp)
    [00:00:11.532,470] <inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY
    [00:00:11.555,877] <inf> net_lwm2m_message_handling: Send done!
    +CSCON: 0
    %XT3412: 46799999
    %CESQ: 58,2,15,2
    %CESQ: 60,3,22,3
    %CESQ: 60,3,15,2
    [00:00:43.990,570] <inf> lwm2m_rai: RAI enabled
    %CESQ: 61,3,20,2
    %CESQ: 255,0,255,0
    [00:01:04.249,359] <inf> app_event_manager: SENSOR_EVT_MOVEMENT_INACTIVITY_DETECTED
    %CESQ: 59,2,9,1
    %CESQ: 60,3,18,2
    %XT3412: 0
    +CSCON: 1
    %CESQ: 59,2,23,3
    %CESQ: 59,2,17,2
    [00:01:17.033,905] <inf> app_event_manager: SENSOR_EVT_MOVEMENT_ACTIVITY_DETECTED
    %CESQ: 58,2,12,1
    %CESQ: 58,2,18,2
    %CESQ: 58,2,23,3
    %CESQ: 59,2,17,2
    %CESQ: 59,2,22,3
    %CESQ: 58,2,17,2
    %CESQ: 56,2,22,3
    %CESQ: 54,2,16,2
    %CESQ: 52,2,21,3
    %CESQ: 52,2,16,2
    %CESQ: 51,2,21,3
    +CSCON: 0
    %XT3412: 46799999
    The server is just the normal Coiote server, set up as per the link that you gave. So I added the device to the Coiote server fist (via the management server, no bootstrap), then programmed the asset tracker with the PSK and server address.
     What exact information on the server do you need?
    Apart from what you already provided, there is no need for additional information at this point. I will let you know if more information is needed.
    We will look into this issue internally. I will get back to you by the end of the next week. Please note that delayed replies can be expected due to reduced staffing during the holiday season.
    Dejan
  • Thank you Dejan,
    I'll await your response then.
    Have a nice weekend!
    Have a nice weekend too!
    Dejan
    CID error might happen if you use old modem firmware version. You could try to update modem firmware.
    Problem with location services might happen if you have not properly set up location services on the cloud side.
    Dejan
