Unable to flash new firmware with DFU because of 'invalid address'
Hello, I am reaching out to you because I am trying to implement a DFU OTA in my project in order to be able to update my firmware with Bluetooth. I have been spending some time on it as the implementation is not an easy task. For a long time, I wasn't able to build, then I wasn't able to boot, and it is just recently that I managed to correctly flash and have access to the logs. I was able to connect to my board thanks to the 'Device Manager' app, but when trying to upload a 'dfu_application.zip' file with the firmware update, I had error 10 on the app and had the following logs on my board:
00> [00:01:18.563,446] <err> flash_nrf: invalid address: 0x001bbff0:16
00> [00:01:18.563,446] <inf> mcuboot_util: Secondary image of image pair (0.) is unreachable. Treat it as empty
00> [00:01:18.563,446] <inf> mcuboot_util: Image index: 0, Swap type: none
00> [00:01:18.671,234] <err> flash_nrf: invalid address: 0x001bbff0:16
00> [00:01:18.671,234] <inf> mcuboot_util: Secondary image of image pair (0.) is unreachable. Treat it as empty
00> [00:01:18.671,234] <inf> mcuboot_util: Image index: 0, Swap type: none
00> [00:01:18.671,264] <err> flash_nrf: invalid address: 0x001bbff0:16
00> [00:01:18.671,264] <inf> mcuboot_util: Secondary image of image pair (0.) is unreachable. Treat it as empty
00> [00:01:18.671,264] <inf> mcuboot_util: Image index: 0, Swap type: none
00> [00:01:18.671,417] <err> STREAM_FLASH: Incorrect parameter
00> [00:01:18.671,417] <err> mcumgr_img_grp: Irrecoverable error: flash write failed: 10
As for my configuration it goes as follow:
Here is what our project directory looks like: build/  build-mcuboot/  child_image/  CMakeLists.txt  HC_v4.overlay  Kconfig  prj.conf  README.md  src/  utils/
Here is our child_image/mcuboot.conf:
CONFIG_NORDIC_QSPI_NOR=n
CONFIG_SPI_NOR=n
CONFIG_MULTITHREADING=y
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x32000
CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
CONFIG_BOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem"
CONFIG_BOOT_MAX_IMG_SECTORS=1024
CONFIG_SERIAL=y
CONFIG_LOG=y
CONFIG_PRINTK=y
CONFIG_USE_SEGGER_RTT=y
Here is what I added to our prj.conf to use the DFU:
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_FLASH_SIZE=1792
CONFIG_FLASH=y
CONFIG_SPI_NOR=n
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
Here is the totality of our prj.conf if it is of any help:
7357.prj.conf
What element am I missing ? Please feel free to ask if you need any additional informations. Once again thank you very much for your time and have a great day.
