extxip_smp_srv fails compiling for nrf5340dk non-secure target
Working on Ubuntu 22.04 with nRF Connect SDK 2.6.1 for the target nrf5340dk_nrf5340_cpuapp_ns (= with TF-M).
My application image became too large. I want to split the app image over internal and external memory. I'm using extxip_smp_svr as example. It compiles & runs for the target nrf5340dk_nrf5340_cpuapp.
When building this sample for the nrf5340dk_nrf5340_cpuapp_ns target (with TF-M), compilation fails:
In file included from /home/dev/nrf-official/v2.6.1/bootloader/mcuboot/boot/zephyr/include/sysflash/sysflash.h:10,
                 from /home/dev/nrf-official/v2.6.1/bootloader/mcuboot/boot/bootutil/src/bootutil_priv.h:33,
                 from /home/dev/nrf-official/v2.6.1/bootloader/mcuboot/boot/bootutil/src/tlv.c:24:
/home/dev/nrf-official/v2.6.1/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h: In function '__flash_area_ids_for_slot':
/home/dev/nrf-official/v2.6.1/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:49:37: error: 'PM_MCUBOOT_PRIMARY_2_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_PRIMARY_1_ID'?
   49 | #define FLASH_AREA_IMAGE_2_SLOTS    PM_MCUBOOT_PRIMARY_2_ID, PM_MCUBOOT_SECONDARY_2_ID
/home/dev/nrf-official/v2.6.1/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:59:29: note: in expansion of macro 'FLASH_AREA_IMAGE_2_SLOTS'
   59 |                             FLASH_AREA_IMAGE_2_SLOTS
/home/dev/nrf-official/v2.6.1/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:67:9: note: in expansion of macro 'ALL_AVAILABLE_SLOTS'
   67 |         ALL_AVAILABLE_SLOTS
What do I need to change in this sample to make it compile for the non-secure target?
(PS my current project fails compiling with the same error when trying to add support for a split application image. That's why I looked into Nordic's sample to find how that is configured differently. Unfortunately it fails too. I saw the same error in the past when experimenting with CONFIG_BOOT_UPGRADE_ONLY=n in a multi-image build)
Thank you!
francis
  • Are you still using pm_static.yml with removed RAM section or all generated?
  • Hello Amanda,
    Sorry for coming back late ...
    You are right, there is the original pm_static.yml that is reused for the "ns" target.
    If I move that aside, and thereby fall-back on the generated build/partition.yml, the build fails (I guess you're seeing this as well).
    At first eye-sight there are considerable differences between the resulting build/partition.yml and that original pm_static.yml for the "ns" target case.
    Until now, I've not changed this pm_static.yml (e.g. removed the RAM section). I only added CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=y to boards/nrf5340dk_nrf5340_cpuapp_ns.conf.
    1. I try to see if I can make sense out of these two files and reconcile these.
    2. I would assume that the generated build/partition.yml should not make the build fail. Might this be an issue internal to the NCS and require an internal ticket?
    francis
  • Hello Amanda,
    I've tried to reconcile the pm_static.yml (the one included in the sample) with the build/partiontion.yml (after compiling for non-secure). Here is that new version:
    ### Ext. flash
    # The app update image
    mcuboot_secondary:
      address: 0x0
      device: MX25R64   # Is this better: DT_CHOSEN(nordic_pm_ext_flash)
      end_address: 0xe0000
      placement:
        align:
          start: 0x4
      region: external_flash
      share_size:
      - mcuboot_primary
      size: 0xe0000    # TODO check size mcuboot_primary
    # The network update image
    mcuboot_secondary_1:
      address: 0xe0000
      end_address: 0x120000
    # Since verything is aligned, do see the purpose of this EMPTY_1 partition
    # EMPTY_1:
    #   address: 0x114000
    #   device: MX25R64
    #   end_address: 0x120000
    #   region: external_flash
    #   size: 0xc000
    mcuboot_primary_2:      # for app part running in ext. flash
      address: 0x120000
      device: MX25R64
      end_address: 0x160000
    mcuboot_secondary_2:    # for the app part in ext. flash update
      address: 0x160000
      device: MX25R64
      end_address: 0x1a0000
    external_flash:
      address: 0x1a0000
      device: MX25R64
      end_address: 0x800000
    ### Int. flash (primary)
    # The bootloader
    mcuboot:
      address: 0x0
      end_address: 0x10000
      placement:
        before:
        - mcuboot_primary
      region: flash_primary
    # Everything except the bootloader & settings storage space
    mcuboot_primary:
      address: 0x10000
      end_address: 0xf0000
      orig_span: &id001
      - mcuboot_pad
      - tfm
      - app
      span: *id001
    tfm_secure:
      address: 0x10000
      end_address: 0x20000
      orig_span: &id007
      - mcuboot_pad
      - tfm
      span: *id007
    mcuboot_pad:
      address: 0x10000
      end_address: 0x10200
      placement:
        align:
          start: 0x4000
        before:
        - mcuboot_primary_app
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - tfm
      - app
      span: *id002
    tfm:
      address: 0x10200
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x20000
      orig_span: &id006
      - app
      span: *id006
    app:
      address: 0x20000
      end_address: 0xf0000   # in NCS doc ex. this does not complete uses all space (until 0xe4000)
    settings_storage:
      address: 0xf0000
      end_address: 0x100000
    ### OTP
    otp:
      address: 0xff8100
      end_address: 0xff83fc
      region: otp
    ### RAM flash
    ram_flash:
      address: 0x40000
      end_address: 0x40000
      region: ram_flash
    mcuboot_primary_1:    # for the network core update
      address: 0x0
      device: nordic_ram_flash_controller
      region: ram_flash
    ### SRAM
    mcuboot_sram:
      address: 0x20000000
      end_address: 0x20080000
      orig_span: &id003
      - pcd_sram
      - tfm_sram
      - sram_primary
      - rpmsg_nrf53_sram
      region: sram_primary
      span: *id003
    sram_secure:
      address: 0x20000000
      end_address: 0x2000a000
      orig_span: &id005
      - pcd_sram
      - tfm_sram
      span: *id005
    pcd_sram:
      address: 0x20000000
      end_address: 0x20002000
      placement:
        before:
        - tfm_sram
    tfm_sram:
      address: 0x20002000
      inside:
      - sram_secure
      placement:
        after:
        - start
    sram_nonsecure:
      address: 0x2000a000
      orig_span: &id004
      - sram_primary
      - rpmsg_nrf53_sram
      span: *id004
    sram_primary:
      address: 0x2000a000
      end_address: 0x20070000
    rpmsg_nrf53_sram:
      address: 0x20070000
      placement:
        before:
        - end
    The linker_arm_extxip.ld is not changed as the offset in ext. flash did not change. The resulting memory report:
      external_flash (0x800000 - 8192kB):
    | 0x0: mcuboot_secondary (0xe0000 - 896kB)        |
    | 0xe0000: mcuboot_secondary_1 (0x40000 - 256kB)  |
    | 0x120000: mcuboot_primary_2 (0x40000 - 256kB)   |
    | 0x160000: mcuboot_secondary_2 (0x40000 - 256kB) |
    | 0x1a0000: external_flash (0x660000 - 6528kB)    |
      flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0x10000 - 64kB)                    |
    +---0x10000: mcuboot_primary (0xe0000 - 896kB)-----+
    +---0x10000: tfm_secure (0x10000 - 64kB)-----------+
    | 0x10000: mcuboot_pad (0x200 - 512B)              |
    +---0x10200: mcuboot_primary_app (0xdfe00 - 895kB)-+
    | 0x10200: tfm (0xfe00 - 63kB)                     |
    +---0x20000: tfm_nonsecure (0xd0000 - 832kB)-------+
    | 0x20000: app (0xd0000 - 832kB)                   |
    | 0xf0000: settings_storage (0x10000 - 64kB)       |
      otp (0x2fc - 764B):
    | 0xff8100: otp (0x2fc - 764B) |
      ram_flash (0x40000 - 256kB):
    | 0x0: mcuboot_primary_1 (0x40000 - 256kB) |
    | 0x40000: ram_flash (0x0 - 0B)            |
      sram_primary (0x80000 - 512kB):
    +---0x20000000: mcuboot_sram (0x80000 - 512kB)---+
    +---0x20000000: sram_secure (0xa000 - 40kB)------+
    | 0x20000000: pcd_sram (0x2000 - 8kB)            |
    | 0x20002000: tfm_sram (0x8000 - 32kB)           |
    +---0x2000a000: sram_nonsecure (0x76000 - 472kB)-+
    | 0x2000a000: sram_primary (0x66000 - 408kB)     |
    | 0x20070000: rpmsg_nrf53_sram (0x10000 - 64kB)  |
     CPUNET flash_primary (0x40000 - 256kB):
    +---0x1000000: b0n_container (0x8800 - 34kB)-+
    | 0x1000000: b0n (0x8580 - 33kB)             |
    | 0x1008580: provision (0x280 - 640B)        |
    +---0x1008800: app (0x37800 - 222kB)---------+
    | 0x1008800: hci_ipc (0x37800 - 222kB)       |
     CPUNET sram_primary (0x10000 - 64kB):
    | 0x21000000: sram_primary (0x10000 - 64kB) |
    Unfortunately I still end up with the mcuboot error:
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    I: MCUBOOT main!
    I: Starting bootloader ...
    I: Image index: 0, Swap type: none
    I: Image index: 1, Swap type: none
    I: Image index: 2, Swap type: none
    E: Unable to find bootable image
    Could you have a look what might be wrongly configured? Thank you.
    For bothe the secure and non-secure variants, I have a question on the app image that goes on the external flash. Is this the qspi_flash.hex? When I open this with the desktop programmer, it only shows 9232 bytes while the pm_static.yml seems to reserve 256k. Is there something wrong? (the programmer is showing the correct address 0x1012.0200)
    francis
  • Hello Amanda,
    I looked further into my issue.
    Added logging in the MCUBoot shows the bootloader fails in boot_validate_slot() (and reports this in context_boot_go()).
    The memory map with west build -t partition_manager_report -d build looks fine (see earlier message).
    However looking into the GENERATED_CP_APPLICATION_merged_domains.hex image with the programmer v4.4.0 the image header section seems missing (the section which should go into 0x10000: mcuboot_pad (0x200 - 512B)).
    The next section, after the MCUBoot loader section, starts at address 0x0001.0200 (which is: 0x10200: mcuboot_primary_app (0xdfe00 - 895kB) also named 0x10200: tfm (0xfe00 - 63kB)). There's nothing flashed at 0x10000 according to the image.
    I assume this is the reason that the bootloader does not find a bootable image? Do you see the same? Are your colleagues back from holiday season?
    PS for building the NS variant, I also added these lines to prj.conf:
    CONFIG_BUILD_WITH_TFM=y
    CONFIG_TFM_PROFILE_TYPE_MINIMAL=y
    Thanks
    Kind regrards,
    francis
