How to get the MQTT publisher example working on the nrf7002DK? I also want to test the TLS after that.
I am trying to get the MQTT publisher example working on my nrf7002DK board. For this, i have done the following things
- SDK version: 2.6.1
- Board selected: nrf7002dk_nrf5340_cpuapp
- Include the prj.conf, overlay-nrf700x.conf and overlay-sample.conf(not sure if this is required)
- Updated the KConfig entries CONFIG_WIFI_CREDENTIALS_STATIC_SSID and CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD, with my SSID and password
- Build and run the code
This is my terminal output
*** Booting nRF Connect SDK v3.5.99-ncs1 ***
[00:00:00.465,911] <inf> net_config: Initializing network
[00:00:00.465,911] <inf> net_config: Waiting interface 1 (0x20000888) to be up...
uart:~$
[00:00:30.466,583] <inf> net_config: Running dhcpv4 client...
[00:00:30.466,827] <err> net_config: Timeout while waiting network interface
[00:00:30.466,827] <err> net_config: Network initialization failed (-115)
[00:00:30.466,888] <inf> net_mqtt_publisher_sample: attempting to connect:
[00:00:30.467,285] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:00:33.468,048] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:00:33.968,536] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:00:36.969,299] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:00:37.469,757] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:00:40.470,489] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:00:40.970,977] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:00:43.971,740] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:00:44.472,198] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:00:47.472,961] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:00:47.973,419] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:00:50.974,182] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:00:51.474,670] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:00:54.475,433] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:00:54.975,891] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:00:57.976,654] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:00:58.477,111] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:01:01.477,874] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:01:01.978,363] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:01:04.979,125] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:01:05.479,248] <inf> net_mqtt_publisher_sample: try_to_connect: -22 <ERROR>
[00:01:05.479,248] <inf> net_mqtt_publisher_sample: attempting to connect:
[00:01:05.479,644] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:01:08.480,407] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:01:08.980,865] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:01:11.981,628] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:01:12.482,116] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:01:15.482,879] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:01:15.983,337] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
[00:01:18.984,100] <inf> net_mqtt_publisher_sample: mqtt_connect: -116 <ERROR>
[00:01:19.484,588] <dbg> net_mqtt_sock_tcp: mqtt_client_tcp_connect: (main): Created socket 9
my prj.conf
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_TCP=y
CONFIG_NET_LOG=y
CONFIG_MQTT_LOG_LEVEL_DBG=y
CONFIG_NET_IPV6_RA_RDNSS=y
CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=3
CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=2
CONFIG_PRINTK=y
CONFIG_STDOUT_CONSOLE=y
# Enable IPv6 support
CONFIG_NET_IPV6=n
# Enable IPv4 support
CONFIG_NET_IPV4=y
# Enable the MQTT Lib
CONFIG_MQTT_LIB=y
CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_NET_CONFIG_MY_IPV6_ADDR="2001:db8::1"
CONFIG_NET_CONFIG_PEER_IPV6_ADDR="2001:db8::2"
CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.0.2.1"
CONFIG_NET_CONFIG_PEER_IPV4_ADDR="192.0.2.2"
CONFIG_MAIN_STACK_SIZE=2048
# For IPv6
CONFIG_NET_BUF_DATA_SIZE=256
CONFIG_NET_SHELL=y
CONFIG_ENTROPY_GENERATOR=y
CONFIG_TEST_RANDOM_GENERATOR=y
my overlay-nrf700x.conf
# Wi-Fi
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
CONFIG_WPA_SUPP=y
CONFIG_NET_L2_ETHERNET=y
# DHCPv4
CONFIG_NET_CONFIG_MY_IPV4_ADDR=""
CONFIG_NET_CONFIG_NEED_IPV4=y
CONFIG_NET_DHCPV4=y
# Connection manager
CONFIG_NET_CONNECTION_MANAGER=y
# Credentials
CONFIG_WIFI_CREDENTIALS=y
CONFIG_WIFI_CREDENTIALS_STATIC=y
CONFIG_WIFI_CREDENTIALS_STATIC_SSID="MySSID"
CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="MyPassword"
  • No. I just took the .zip file that you posted approx. 3 hours ago:
    Arjun Kariat said:
    I have created a mosquitto_ca_cert.h file using the python script provided in the git link. This is the .h file created from the crt file of the ca certificate of the test.mosquitto.org.
    Here is the updated code
    /cfs-file/__key/communityserver-discussions-components-files/4/5228.wifistaMqtt.zip
    Please Note: I have only added the subscribe part here right now.
    Please let me know if you want to know anything else
    Håkon
  • Its working thanks a lot Slight smile
    Updated prj.conf
    # Copyright (c) 2022 Nordic Semiconductor ASA
    CONFIG_WIFI=y
    # WPA supplicant
    CONFIG_WPA_SUPP=y
    # Below configs need to be modified based on security
    # CONFIG_STA_KEY_MGMT_NONE=y
    CONFIG_STA_KEY_MGMT_WPA2=y
    # CONFIG_STA_KEY_MGMT_WPA2_256=y
    # CONFIG_STA_KEY_MGMT_WPA3=y
    CONFIG_STA_SAMPLE_SSID="YourSSID"
    CONFIG_STA_SAMPLE_PASSWORD="Your_Password"
    # System settings
    CONFIG_NEWLIB_LIBC=y
    CONFIG_NEWLIB_LIBC_NANO=n
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_LOG=y
    # CONFIG_MQTT_LOG_LEVEL_DBG=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_IPV6=n
    CONFIG_NET_UDP=y
    CONFIG_NET_TCP=y
    CONFIG_NET_DHCPV4=y
    CONFIG_NET_PKT_RX_COUNT=8
    CONFIG_NET_PKT_TX_COUNT=8
    # Below section is the primary contributor to SRAM and is currently
    # tuned for performance, but this will be revisited in the future.
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NET_BUF_DATA_SIZE=128
    CONFIG_HEAP_MEM_POOL_SIZE=153600
    CONFIG_NET_TC_TX_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_MAX_CONTEXTS=5
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_INIT_STACKS=y
    CONFIG_NET_CONFIG_INIT_TIMEOUT=0
    CONFIG_NET_SOCKETS_POLL_MAX=10
    # Memories
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_NET_TX_STACK_SIZE=4096
    CONFIG_NET_RX_STACK_SIZE=4096
    # Debugging
    CONFIG_STACK_SENTINEL=y
    CONFIG_DEBUG_COREDUMP=y
    CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
    CONFIG_SHELL_CMDS_RESIZE=n
    # Kernel options
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_BUFFER_SIZE=2048
    CONFIG_POSIX_CLOCK=y
    CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.99"
    CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.255.0"
    CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1"
    # printing of scan results puts pressure on queues in new locking
    # design in net_mgmt. So, use a higher timeout for a crowded
    # environment.
    CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
    #MQTT
    CONFIG_MQTT_LIB=y
    CONFIG_MQTT_LIB_TLS=y
    CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
    CONFIG_MQTT_KEEPALIVE=5
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_HEAP_SIZE=81920
    CONFIG_TLS_CREDENTIALS=y
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y
    CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y
    For nrf7002DK board:
    • Board selected: nrf7002dk_nrf5340_cpuapp
    For nrf7002EK Board
    • Board selected: nrf5340dk_nrf5340_cpuapp
    • Extra Cmake Argument: -DSHIELD="nrf7002ek"
    Great to hear that it is working as expected! Always happy to help out.
    Hope you have a wonderful day!
    Håkon
  • Hi @
    I was trying to add TLS client certificate support to this code. i am getting an error
    [00:00:10.666,046] <inf> mqtt: Connecting to MQTT broker
    [00:00:11.825,683] <err> net_pkt: Data buffer (1035) allocation failed.
    [00:00:11.825,714] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=987
    [00:00:11.973,724] <err> net_pkt: Data buffer (1110) allocation failed.
    [00:00:11.973,754] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1062
    [00:00:12.177,917] <err> net_pkt: Data buffer (1110) allocation failed.
    [00:00:12.177,917] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1062
    [00:00:12.177,917] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:12.656,158] <err> net_pkt: Data buffer (1110) allocation failed.
    [00:00:12.656,158] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1062
    [00:00:12.656,158] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:13.323,364] <err> net_pkt: Data buffer (1110) allocation failed.
    [00:00:13.323,364] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1062
    [00:00:13.323,364] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:14.273,559] <err> net_pkt: Data buffer (1110) allocation failed.
    [00:00:14.273,559] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1062
    [00:00:14.273,559] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:15.648,803] <err> net_pkt: Data buffer (1328) allocation failed.
    [00:00:15.648,803] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1280
    [00:00:15.648,834] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:17.661,041] <err> net_pkt: Data buffer (1328) allocation failed.
    [00:00:17.661,041] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1280
    [00:00:17.661,071] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:20.629,272] <err> net_pkt: Data buffer (1328) allocation failed.
    [00:00:20.629,302] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1280
    [00:00:20.629,302] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:25.031,494] <err> net_pkt: Data buffer (1328) allocation failed.
    [00:00:25.031,494] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1280
    [00:00:25.031,524] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:31.584,716] <err> net_pkt: Data buffer (1328) allocation failed.
    [00:00:31.584,747] <err> net_tcp: conn: 0x20050ba4 packet allocation failed, len=1280
    [00:00:31.584,747] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:00:31.837,738] <err> mqtt: Error in mqtt_connect: -5
    This is my updated code: /cfs-file/__key/communityserver-discussions-components-files/4/2570.wifistaMqtt.zip
    Please let me know if you want any thing else
    in brief
    i added the client certificate as well as the private key files
    static const unsigned char ca_certificate[] = {
    #include "mosquitto_ca_cert.h"
    static const unsigned char client_certificate[] = {
    #include "mosquitto_client_cert.h"
    static const unsigned char priv_key[] = {
    #include "mosquitto_priv_key.h"
    I have called the tls_credential_add as shown below
        // CA Certificate
        err = tls_credential_add(MQTT_TLS_SEC_TAG, TLS_CREDENTIAL_CA_CERTIFICATE, ca_certificate, sizeof(ca_certificate));
    	if (err < 0)
    		LOG_ERR("Failed to add TLS credentials CA Certificate, err: %d", err);
    		return err;
    	// Client Certificate
        err = tls_credential_add(MQTT_TLS_SEC_TAG, TLS_CREDENTIAL_SERVER_CERTIFICATE, client_certificate, sizeof(client_certificate));
    	if (err < 0)
    		LOG_ERR("Failed to add TLS credentials Client Certificate, err: %d", err);
    		return err;
    	// Private Key
        err = tls_credential_add(MQTT_TLS_SEC_TAG, TLS_CREDENTIAL_PRIVATE_KEY, priv_key, sizeof(priv_key));
    	if (err < 0)
    		LOG_ERR("Failed to add TLS credentials Private Key, err: %d", err);
    		return err;
    Updated the Broket Port to 8884
    I have used this link to create the client certificate: test.mosquitto.org/.../
