Connection using old pairing information saved
I am running an experiment to use a static keys for pairing information without breaking the existing flow of pairing/bonding.
What I am doing is I am storing the pairing info of my central device and storing it into a structure and then erasing the flash to remove those information, and after reset I am retrieving those bonding information and connecting again using the same central devices but I am getting "Peer removed bonding info" response on my phone.
void store_ltk_in_zephyr(void)
    int id, err;
    struct bt_keys pairing_info = {
    .addr = {
        .type = BT_ADDR_LE_PUBLIC,
        .a.val = {0x43,0x82,0x5E,0xC7,0xE8,0xF4,0xFD}
    .irk = {0x8A, 0x27, 0x1E, 0xA7, 0x92, 0x2A, 0xF0, 0x15, 0x41, 0x69, 0x48, 0xDD, 0xC0, 0x7E, 0xDD, 0xF7},
    .ltk = {
        .val = {0xc0, 0xe6, 0x9a, 0x0a, 0xf7, 0x4b, 0xdc, 0xb7, 0x7d, 0x23, 0xf4, 0xb4, 0x89, 0x8d, 0x96, 0x02},
        .ediv = {0x00,0x00},
        .rand = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
    // Store the keys using the settings API
    err = bt_keys_store(&pairing_info);
    if (err) {
        printk("Failed to store keys (err %d)\n", err);
    } else {
        printk("Keys stored successfully\n");
In main, I am calling like this to load the info onto the flash-
  settings_subsys_init();
  //smp_bt_register();
	bt_conn_auth_cb_register(&auth_cb_display);
  bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
    k_sleep(K_MSEC(100));
		err = bt_enable(NULL);                                      //Trying one more time after this system reset
    if(err) NVIC_SystemReset();
  store_ltk_in_zephyr();
  if (IS_ENABLED(CONFIG_SETTINGS)) {
    settings_load();
And on connect I am using like this-
  bt_conn_set_security(conn, BT_SECURITY_L1|BT_SECURITY_FORCE_PAIR);
Do let me know, how can I connect with the same bonding info which I have made a copy of from the same bonding structure.
  •  These changes I already had in my code, been testing and sending you logs from that only-
    static void pre_shared_bond_set(void)
    	int err;
    	int bond_num = 0;
    	struct bt_keys *pairing_info;
    	bt_foreach_bond(BT_ID_DEFAULT, bond_cb, &bond_num);
    	if (bond_num) {
    		return;
    	bt_addr_le_t addr = {
    	    .a.val = {0x43,0x82,0x5E,0xC7,0xE8,0xF4}
    	struct bt_ltk ltk = {
    	    .val = {0x31, 0x30, 0xca, 0x16, 0x8d, 0x53, 0x73, 0x7c, 0x89, 0xee, 0x42, 0x58, 0x61, 0x47, 0x03, 0xb4},//{0xcb, 0xea, 0xd5, 0xea, 0xe1, 0xab, 0x7c, 0x36, 0x91, 0x1b, 0xe7, 0xd3, 0x31, 0xd1, 0xf8, 0xbc},
    	    .ediv = {0},
    	    .rand = {0}
    	struct bt_irk irk = {
    		.val = {0xF7, 0xDD, 0x7E, 0xC0, 0xDD, 0x48, 0x69, 0x41, 0x15, 0xF0, 0x2A, 0x92, 0xA7, 0x1E, 0x27, 0x8A},
    		.rpa.val = {0}
      /**Copying the retrieved values from the memory onto the relevant array to pass the pairing infos*/
      memcpy(&addr.a.val[0],keys_addr,6);
      memcpy(&irk.val[0],irk_val,16);
      memcpy(&ltk.val[0],ltk_val,16);
      memcpy(&ltk.ediv[0],ltk_ediv,2);
      memcpy(&ltk.rand[0],ltk_rand,8);
    	pairing_info = bt_keys_get_addr(0, &addr);
    	if (pairing_info == NULL) {
    		printk("Failed to get keyslot\n");
      memcpy(&pairing_info->periph_ltk, &ltk, sizeof(pairing_info->ltk));
    	//memcpy(&pairing_info->ltk, &ltk, sizeof(pairing_info->ltk));
    	memcpy(&pairing_info->irk, &irk, sizeof(pairing_info->irk));
    	pairing_info->flags = 0;
    	pairing_info->enc_size = 16;
    	pairing_info->keys = BT_KEYS_IRK | BT_KEYS_PERIPH_LTK;
    	err = bt_keys_store(pairing_info);
        if (err) {
        } else {
    void reverse_copy_bytes(uint8_t* src, uint8_t* dst, size_t size) {
        if (size != 2) {
            printf("Error: Function is intended for size 2.\n");
            return;
        // Reverse the bytes during copy
        dst[0] = src[1];
        dst[1] = src[0];
    void retrieve_pairing_keys(void)
      const volatile uint32_t *ptr = (const volatile uint32_t *)(0xf5100); //Workaround to read back the pairing info from the old SDK
      uint8_t reversed_ltk_ediv[2]; // Array to store reversed bytes
      uint8_t reversed_ltk_val[16];
      uint8_t reversed_ltk_rand[8];
      memcpy(&irk_val[0],((uint8_t*)ptr),16);
      memcpy(&keys_addr[0],((uint8_t*)ptr+16+1),6);
      memcpy(&reversed_ltk_val[0],((uint8_t*)ptr+16+6+1),16);
      memcpy(&reversed_ltk_ediv[0],((uint8_t*)ptr+16+6+16+1+2),2);
      memcpy(&reversed_ltk_rand[0],((uint8_t*)ptr+16+6+16+2+1+2),8);
      // memcpy(&ltk_val[0],((uint8_t*)ptr+16+6+1),16);
      // memcpy(&ltk_ediv[0],((uint8_t*)ptr+16+6+16+1+2),2);
      // memcpy(&ltk_rand[0],((uint8_t*)ptr+16+6+16+2+1+2),8);
      // Perform the reverse copy
      reverse_bytes(&ltk_ediv[0], &reversed_ltk_ediv[0], 2);
      reverse_bytes(&ltk_val[0], &reversed_ltk_val[0], 16);
      reverse_bytes(&ltk_rand[0], &reversed_ltk_rand[0], 8);
      for(uint8_t i =0;i<16;i++)
        printk(" %02x",reversed_ltk_val[i]);
      printk("Successfully copied pairing info from the memory\n");
    Needed help from the nrf5SDK side, if anything in copying I missed. I will also share ble sniffer trace tomorrow(But I dont remember seeing EDIV and RAND related logs in sniffer trace ,btw I use wireshark for BLE sniffing).
  • Just read the comments in the code, I`ll test with these changes and let you know.
    Thanks
  • Here is an updated version of the pre_shared_bond_set() function which should handle legacy pairing
    Still disconnecting after the changes,but the EDIV and RAND are matching now-
    00> 8a 27 1e a7 92 2a f0 15 41 69 48 dd c0 7e dd f7 [00:00:08.474,365] <inf> bt_keys: Legacy LTK: 0x81ee0de3848ec6bf4d9d9d4cb98de928 (peripheral)
    00> Connected
    00> [00:00:08.672,668] <dbg> bt_keys: bt_keys_find: type 32 F4:E8:C7:5E:82:43 (public)
    00> [00:00:08.672,851] <dbg> bt_keys: bt_keys_find: type 1 F4:E8:C7:5E:82:43 (public)
    00> [00:00:08.672,851] <dbg> bt_smp: bt_smp_request_ltk: Its inside this loop now 3
    00>
    00> RAND from key : 12030894171999848549
    00> RAND from HCI buf: 12030894171999848549
    00> EDIV from key : 64060
    00> EDIV from HCI buf : 64060
    00> [00:00:08.762,512] <dbg> bt_smp: bt_smp_disconnected: chan 0x20003ce8 cid 0x0006
    00> [00:00:08.762,847] <dbg> bt_keys: bt_keys_find_addr: F4:E8:C7:5E:82:43 (public)
    00> [00:00:08.763,031] <dbg> bt_keys: bt_keys_find_addr: F4:E8:C7:5E:82:43 (public)
    00> Disconnected (reason 0x13)
  • Still disconnecting after the changes,but the EDIV and RAND are matching now-
     Recheck it again by simply copying the values directly in the structure and still not able to connect.
    00> 8a 27 1e a7 92 2a f0 15 41 69 48 dd c0 7e dd f7 [00:00:08.060,668] <inf> bt_keys: Legacy LTK: 0x863be25911d3af286101dad5dab01db1 (peripheral)
    00> Connected
    00> [00:00:08.060,699] <dbg> bt_smp: smp_send_security_req:
    00> [00:00:08.060,882] <dbg> bt_keys: bt_keys_get_addr: F4:E8:C7:5E:82:43 (public)
    00> [00:00:08.061,065] <dbg> bt_smp: smp_init: prnd 37a95cfba06b8f8ed4dbabde26d4bdc6
    00> [00:00:08.228,851] <dbg> bt_smp: bt_smp_request_ltk: Its inside this loop now 3
    00>
    00> RAND from key : 14895755191182585488
    00> RAND from HCI buf: 14895755191182585488
    00> EDIV from key : 2479
    00> EDIV from HCI buf : 2479
    Logs from nrf5SDK version-
    00>  F7 DD 7E C0 DD 48 69 41 15 F0 2A 92 A7 1E 27 8A<info> app: Address:
    00>
    00>  43 82 5E C7 E8 F4 42<info> app: LTK:
    00>
    00>  B1 1D B0 DA D5 DA 01 61 28 AF D3 11 59 E2 3B 86<info> app: LTK others:
    00>
    00> <info> app:  9AF
    00>
    00> <info> app: RAND:
    00>
    00>  90 6E 9E DF 6C 5A B8 CE
  •  I have made it work now, whole copy LTK,EDIV and RAND endianess was the issue.
    But after this device got conencted but there is one more major issue, services and characteristics are still showing up like nRFSDK one, as in the order of services and characteristics are different on nRFSDK version and the one on Zephyr.
    But the UUIDs are same, with this issue if I am trying to read the relevant values then I am seeing garbage values.
    Two of the services which were meant for only nRF5SDK versions i.e., Buttonloess DFU are still visible on the Zephyr version, I think the services are not getting refreshed.
